Bonjour, savez-vous ce qu'il en est de l'activation simultanée du DBLE avec du contenu en Dolby vision ?
C'est toujours inactivable ?
Modérateurs: Modération Forum Home-Cinéma, Le CA de l’Association HCFR • Utilisateurs parcourant ce forum: ANGEL, BRASIL, brazilou, Chrislam54, danbach, dm, Morganita, Richard Lemesle, Sebastiii, subbreton et 61 invités
XGIMI HORIZON 20 ( 20/20 PRO/20 Max )
- Floriian.08
- Inscription Forum: 27 Mar 2024 21:07
ça sera réglé dans une prochaine mise à jour
"Dear HORIZON Community,
We are writing to provide a transparent update regarding the ongoing optimization for our new HORIZON 20 Series projectors.
We are aware of two specific issues that some users have reported:
1. Compatibility between Dolby Vision and DBLE: These two features cannot be enabled simultaneously at the moment.
2. Color deviation with DBLE: An unexpected color shift may occur when the DBLE feature is activated (especially during transitions between light and dark scenes).
Root Cause:
These issues are related to the integration of the advanced new hardware platforms in the HORIZON 20 Series—specifically, the latest TI chip and the MTK processor. Our engineers are working closely with our technical partners at TI and MTK to develop a stable solution.
Our Plan & Timeline:
Resolving these challenges is our top priority. We are committed to delivering an update that will fix both issues. We expect to have a solution ready and released around Thanksgiving Day.
The update will be provided via a USB installation process, and detailed instructions will be shared at that time.
We sincerely apologize for any inconvenience this may cause. Your patience and understanding are greatly appreciated as we work to ensure your HORIZON 20 Series projector delivers the exceptional experience you expect.
Thank you for your support."
Root Cause:
- Gatchan77
- Inscription Forum: 25 Aoû 2005 12:07
- nolemaled
- Inscription Forum: 29 Sep 2022 6:55
Gatchan77 a écrit:ça sera réglé dans une prochaine mise à jour
Root Cause:
Ah bah ça, c'est une bonne nouvelle !
- Floriian.08
Pour le problème eARC , je confirme avoir le même, ça fonctionne très bien en sortie depuis ma TV mais le HORIZON 20 PRO ne veut rien savoir quand il est sur Google TV.
Connexion en sortie d'un ampli Onkyo
J'ai aussi remarqué que l'image de mon lecteur blu ray sortait en 60 fps au lieu du 24p, avez vous eu le même problème ?
Je vais surveiller les forums officiels également.
- Nintenn
- Inscription Forum: 20 Juin 2010 9:06
Il n'est pas compatible 24p en sortie nativement, du coup ça doit être normal qu'il sorte du 60hz.
Sinon un test sympa en anglais (et il y a une video à la fin)
L'upscale des sources SD/HD via l'AISR a l'air particulièrement bon.
https://www.projectorjunkies.com/xgimi- ... th-review/
- Gatchan77
Un comparatif avec le Horizon 20 et d'autres projo dans la même gamme de prix (l'horizon 20 sort vainqueur)
https://www.youtube.com/watch?v=9QqnfJ0-I_s
Il y en a aussi un autre avec le max
https://www.youtube.com/watch?v=F6mFV7XQC3o
- Gatchan77
Gatchan77 a écrit:Un comparatif avec le Horizon 20 et d'autres projo dans la même gamme de prix (l'horizon 20 sort vainqueur)
Superbe vidéo qui met en avant le Horizon 20 base model. J'hésitais avec un Hisense C2 Pro, mais je risque de partir sur le premier. J'espère qu'il ne présentera pas trop de speckle laser.
https://fr.xgimi.com/pages/horizon-20
https://www.laurentwillen.be/gadgets/te ... /#local_17 COMPARATIF HORIZON 20 VS HORIZON 20 PRO VS HORIZON 20 MAX
https://youtu.be/9QqnfJ0-I_s This Projector Shouldn’t Cost Under $1500 – The Ultimate Value King
- Paull
- Inscription Forum: 22 Sep 2003 16:32
- Localisation: "For Those About To Rock (We Salute You)" - AC/DC
Pour les Hisense, il y a la gamme C3 qui doit arriver (c'est déjà dispo en chine).
- Gatchan77
Horizon 20 Pro reçu mercredi
1ères impressions : silencieux , très (trop) lumineux, surtout que l'intensité du laser rappasse à 10 quand on change la source (Netflix --> Canal+, etc) (j'espère que ce point sera corrigé par Xgimi)
j'ai testé "Les gardiens de la Galaxie" en Dolby Vision , la scène où Peter Quill vole l'Orbe sur Morag est très sombre mais tous les détails ressortent bien (bcp mieux qu'avec mon précédent projecteur) mon fils m'a dit "Ah , c'est comme au cinéma" !
J'ai également testé la 3D (un bout d'Avatar et The Walk). ça fonctionne très bien par contre, trouver l'option 3D pour l'activer est une plaie
Installation de Plex (en mode lecteur uniquement) sur l'Horizon, ça lit parfaitement tous les films que j'ai testés sans lag
@ulric : je ne suis pas un expert de l'eArc, mais j'ai l'impression qu'il fonctionne pour moi (si je lis un film depuis l'Horizon , ça envoie le son vers mon Ampli (au bon format) . si j'éteins l'Ampli, le son sort de l'Horizon.
A savoir que l'utilisation du LensShift désactive certaines options images et notamment la diminution de la luminosité quand on passe devant le projecteur . Pas documenté et on se demande bien pourquoi...
j'attends ce we pour d'autres tests (notamment l'installer non plus derrière mon canapé mais à gauche pour tester l'option LensShift (ainsi, il serait plus discret qu'en plein milieu du séjour...)
- SdavidS
- Inscription Forum: 15 Mai 2008 13:52
SdavidS a écrit:Horizon 20 Pro reçu mercredi
j'attends ce we pour d'autres tests (notamment l'installé non plus derrière mon canapé mais à gauche pour tester l'option LensShift (ainsi, il serait plus discret qu'en plein milieu du séjour...)
Merci d'avoir pris le temps de faire un retour !
Concernant ta lecture de film, as-tu testé de lire un film via un lecteur blu-ray ou une box TV type Shield qui serai branché sur ton ampli ? si oui le son était correctement décodé par ton ampli ?
Et as-tu pu testé le DBLE ?
- Floriian.08
Quand j'allume le projecteur, l'ampli s'allume automatiquement sur l'entrée TV. Pas de son sortant du projecteur, mais des enceintes connectées à l'ampli
si je bascule sur ma Shield (connectée sur HDMI eArc), l'ampli bascule automatiquement sur l'entrée Shield de l'ampli, pas de souci de son, ça correspond à la source que je lis
DBLE, je ne sais pas ce que sait, il y a tellement d'options de réglage d'image... Je sais juste qu'il ne faut pas activé l'option ALLM sinon l'option 3D est désactivée.
Précision complémentaire, j'ai regardé (quelques scènes) d'Alien (version 1978) en 720p. Depuis Plex de la Shield l'image est moyenn (c'est regardable, ce n'est pas non plus pixelisé, mais on voit du grain) . Les mêmes scènes lue depuis Plex du projo, avec l'option AISR , l'image est plus douce et semble mieux définie, plus agréable à regarder
- SdavidS
SdavidS a écrit:Quand j'allume le projecteur, l'ampli s'allume automatiquement sur l'entrée TV. Pas de son sortant du projecteur, mais des enceintes connectées à l'ampli
Ok donc tout semble fonctionner correctement concernant la partie son via un ampli c'est une bonne chose.
Et c'est bon à savoir pour l'image meilleur sur plex directement installé sur le projecteur.
Pour ce qui est du DBLE c'est le contraste dynamique du projecteur qui permet d'obtenir un ratio de contraste plus élevé que le contraste natif, cependant depuis la commercialisation du projecteur, le DBLE provoque de forte variation colorimétrique et il ne peut pas être activé avec du contenu dolby vision.
Mais étant donné que tu ne semble pas avoir de problème sur la partie e-arc, peut-être que tu n'as pas les problèmes du DBLE également lol
- Floriian.08
- sylvio50
- Inscription Forum: 22 Juin 2010 1:06
Floriian.08 a écrit:SdavidS a écrit:Quand j'allume le projecteur, l'ampli s'allume automatiquement sur l'entrée TV. Pas de son sortant du projecteur, mais des enceintes connectées à l'ampli
On est nombreux chez qui l'eARC ne fonctionne pas donc c'est étonnant, peut être que le projo préfère certaines marques, en tout cas en l'état il n'est pas abouti pour moi. Le coup des changements de luminosité et de désactivation du MEMC pour avoir un framerate correct m'a aussi posé problème. Je pense que je vais tester d'autres marques qui ont une approche plus home cinéma que jeu/media et je connecterai une clé HDMI dessus pour les services.
- Nintenn
