salut Alex, tu as quoi comme ampli Pio ? Et stp un CR au plan video et son qd tt ça sera reçu, merci.
a+
TEE
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: nicowboy, Zavie et 6 invités
Les Processeurs Vidéo (Scaler, Désentrelaceur, Enhancer) et tous les appareils traitant l'image (y compris les ampli HC)
Scaler Vantage HD
Trinnov et JVC NZ900 forever (hélas for this life only)
- transeuropexpress
- Administrateur Suppléant de l'Association
- Inscription Forum: 04 Sep 2003 22:08
voila un texte recuperé un site u.s qui est assez interressant. On y apprends notamment, qu'un nouveau firmware est prevu pour bientot, avec de nouveaux algorithmes, et que l'appareil est excellent sur des sources SD. Mais ca on pouvais s'en douter. Moi je testerais le mien ce week-end faute de temps aujourd'hui
Voila le texte :
Thanks for the detailed evaluation RobboNL (and others), I'm sure lots of
people will find it useful - including us. We discussed your findings here at
Calibre and would make the following comments;
i) A picture positional/size error on the RGBHV connection via a projector
suggests that the projector was not able to accept the 1080 mode from Vantage-HD
correctly, rather than being anything to do with Vantage-HD itself. This would
account for the lack of size, also the positional error and also would cause the
picture quality to suffer. The 1920x1080 output mode timings/settings are shown
towards the end of the Vantage-HD user manual so could be compared with those in
the projector manual to see where the differences are. It is certainly true that
Vantage-HD is primarily designed to work with digital display devices -
LCD/DLP/DILA/LCOS projectors, plasmas and LCDs. It does work with CRT
projectors, but that is not what its default settings are optimized for.
A later software release will allow user programmable output modes so that
conversely the default projector settings can be programmed into Vantage-HD.
This is not expected to be ready until at least July.
ii) Some DVD players actually de-interlace and re-interlace 480i/576i output
material which causes dreadful artifacts, but that does not sound like what was
seen, although it is still possible - the configuration of the DVD player should
be checked carefully and also its S-Video output should be tried out to see if
that actually gives a better image, strangely it can sometimes.
However, the usual reason for an over-processed look is that the MPEG or TNR
settings were much higher than the player or material required. Faroudja
2200/2300 do not do any motion adaptive temporal noise reduction, or any MPEG
noise reduction. So yes, in that comparison the signal really is processed less.
These filters can be turned off on Vantage-HD if desired.
There is also an upgrade due for release early June which includes an upgrade
to the internal Teranex processing algorithms, this will further improve all
processing, but in particular 480i.
When correctly configured, Vantage-HD will outperform all current Faroudja or
Gennum de-interlacing, but to do a like for like comparison you do have to be
careful to ensure that other processing or the display device/source themselves
are not affecting what is viewed.
We do make some of our professional products using the Faroudja 2200 device and
it is very good, but Vantage-HD is much better overall. Users may find also that
Faroudja 2200/2300 are easily able to get confused by broken cadences in
film-originated material and by mixed film/video material, whereas Vantage-HD
follows such changes and source material errors and automatically adapts its
processing quickly and accurately.
Also, the comment that Vantage-HD is very good with a very bad signal is
aaccurate, it is particularly effective on signals which are dreadful to start
with.
Anyone who wants to see how to best configure a Vantage-HD is welcome to visit
our booth at Infocomm in Orlando in June where we will be very pleased to give
user training/demonstrations. We'll also be at CEDIA in Denver in September
where the same service will be available. For those in the UK, we will be
supporting our UK Distributor, Invision, at CEDIA UK 20-22nd June.
Voila le texte :
with.
- cactus jack67
- Inscription Forum: 25 Sep 2005 9:51
cactus jack67 a écrit:Bonjour,
Voila le texte :
with.
Tu devrais lire les posts au dessus avant de poster
Alex_t a déjà fait un lien vers ce post d' AVS et j'ai déjà fait une traduction deux/trois posts plus haut de tout ça...
Richard.
- Richard Lemesle
- Inscription Forum: 26 Jan 2003 16:03
dis dont tu à le temps de surfer !!!mais tu as pas le temps de nous parler de ce VANTAGE
- vddan
- Inscription Forum: 04 Mar 2004 16:28
transeuropexpress a écrit:salut Alex, tu as quoi comme ampli Pio ? Et stp un CR au plan video et son qd tt ça sera reçu, merci.
a+
TEE
Mon ampli pioneer est assez vieux c'est le VSX-D810S, il décode le DTS et le DB5.1.
POur mon CR j'ai prévu de faire des tests audio/video avec les conf suivantes :
En entrée :
- DVD sony en YUV
- DVD pioneer en RVBS
En sortie :
- LCD HDMI 720p/1080i sans le son puis avec le son
- LCD VGA 720p/1080i et 1366x768 si atteignable
- video-projecteur d'un pote en HDMI 720p
- son en COAX vers ampli pio
- son en OPTIQUE vers ampli pio
Reste plus qu'à recevoir le BB
a+
- alex_t
- Membre HCFR Contributeur
- Inscription Forum: 29 Oct 2005 23:04
alors Cactus jack67 et ce VANTAGE tu nous en parle un peu!!!!tu l'as pas mis sous cloche quand meme .......il est comment extérieurement ? l'as tu branché ? etc......aller un petit CR,juste un petit.....cela me permettra de patienter le mien est partit d'allemagne mercredi je pense l'avoir début de semaine...
- vddan
Pas un CR, rien ?
Il marche si mal que ca
- shacard
- Inscription Forum: 16 Oct 2000 2:00
j'espère que non
- vddan
Ou alors il marche trop bien et il arrive plus à décoller le nez de son écran
- Richard Lemesle
De bonnes nouvelles de mon vendeur peut pas en dire plus pour le moment
A demain
A demain
- alex_t
alex_t a écrit:A demain
Nous sommes demain
- shacard
des C.R !!! des C.R.!!!
pensez a ceux comme moi qui n'en peuvent plus d'attendre les C.R. pour commender le leur !
didier
didier
- deparis
- Inscription Forum: 29 Avr 2005 11:11
Salut.
Je tiens à vous préciser que j'attends du vendeur son feu vert pour aller chercher le BB (en Belgique avec séance de moules-frites et HC programmées ).
Donc pas de CR pour ce week-end mais si tout va bien, le suivant vous aurez alors un CR avec photos si quelqu'un veut bien m'expliquer comment on ajoute des photos à son post, merci.
a+
a+
- alex_t
Mini Cr Vantage HD
Je profite d’un bref répit dans ma vie professionnelle pour vous faire part de mes premières impressions sur le vantage HD que j’ai acquis récemment. Je vous avais promis un CR dés la livraison, mais un emploi du temps extrêmement chargé ces temps ci m’en ont empêché. Ayant pu tester que trop rarement l’appareil depuis, je vous prie donc de bien vouloir excuser par avance de l’aspect rachitique de ce CR.
Le test a été fait un moniteur 24 » DELL , les sources étant de la SD sur le satellite ASTRA, avec les chaînes allemandes ARD, ZDF, SAT 1 et PRO 7 réputées pour ne pas être pingre sur la bande passante.
Au premier regard, on a le droit d’être un peu septique, l’appareil n’est pas un canon de beauté, et certains préféreront sûrement le dissimulé bien soigneusement tellement il peut être laid. De plus , à l’arrière de la façade, la connectique un peu limité n’inspire pas non plus une grande confiance, et sur le coup un grand doute c’est imité en moi sur l’intérêt de ce coûteux appareil ( 2150 € n’est pas une mince affaire quand même…).
Toutefois, les doutes ont été balayés en quelques dizaines de secondes une fois l’appareil en marche. Je dois avouer que je n’avais plus connu de telles émotions depuis mon premier comparatif entre une vidéo sd et une vidéo Hd. Incroyable, n’est pas de trop pour qualifier les prouesses dont est capable cet appareil. Pour résumer en une phrase je dirais qu’un voile recouvrait avant l’image et que le vantage vient de balayer celui-ci. Les visages sont extrêmement bien définis, d’une précision diabolique et surtout ils dégagent un relief qui n’existais pas avant. La fluidité ne souffre d’aucune lacune et l’on se prend à croire qu’on est entrain de regarder un film en HD. Et pourtant ce n’est que la SD….Je n’ose imaginer ce que l’appareil est capable de produire avec un signal HD. Autre point fort ; les effets d’escalier, bien présent sur les écrans plats et les LCD en particulier, ont été complètement gommé, et l’effet doit être encore plus accentué sur un vp ou la surface est bien plus grande.
Sur des sources vidéo comme le satellite l’image est étonnante, sur mes dvd, c’est complètement dément, et j’attends avec impatiente ce week end pour pouvoir brancher l’appareil sur mon VP.
Cette puce THDG, fait vraiment des merveilles, et les divers tests qu’on a pu lire a droite et a gauche, n’ont pas été pour une fois volontairement exagéré.
Cependant, c vrai que le tableau n’est pas tout blanc non plus, l’appareil est bruyant, un peu plus qu’un VP, mais une fois plongé dans un film vous l’entendez plus. Il y a bien aussi certaines fréquences de sortie qu’on aimerait voir apparaître a l’avenir mais je crois que cela est déjà prévu pour le prochain firmware, en même temps que de nouveaux algorithmes.
En résume, je ne peux que vous recommandez cet appareil et ce dernier deviendra rapidement le cœur de votre installation HC. A ce prix la, il faudrait être fou pour ne pas sauter dessus.
Cactus
Cactus
- cactus jack67
cactus jack67 a écrit:Je profite d’un bref répit dans ma vie professionnelle pour vous faire part de mes premières impressions sur le vantage HD que j’ai acquis récemment. Je vous avais promis un CR dés la livraison, mais un emploi du temps extrêmement chargé ces temps ci m’en ont empêché.
T'as pas pose des conges pour le tester ?
Heu... quel type de VP ? Parceque si il est aussi bruyant que mon 1292, je pars en courant
Merci pour ces premiers commentaires
- shacard
Retourner vers Processeurs Vidéo
