Type : fiches RCA
Marque :FURUTECH
Modèle et options : RCA FP-106 vissable ( set de 4 FICHES) / 2 sets à vendre
Prix de vente : 80€ le set de 4 fiches
Département où la marchandise est visible : 14
État de la marchandise : Neuf jamais monté
Prix neuf : autour de 150 euros ( analog seduction)
The FP-106 (Rhodium) is a high-quality, locking RCA plug with a unique copper silver copper rhodium plating process. The centre pin is a filament design using non-magnetic phosphor bronze which is then subjected to the 4 step plating process. The main body is also manufactured from Bronze which is then powder coated for long life. This entire assembly is non-magnetic to ensure that magnetic charge cannot colour the sound like other RCA connectors. Internally this connector is fully plated with rhodium with the wires being secured via non-magnetic screws, themselves gold plated. With a maximum cable diameter of 9.3mm this is the audio connector of choice for those not prepared to compromise.
As with most Furutech parts, it contains no magnetic parts and has been processed with Furutech’s Super Cryogenic & Demagnetize treatment.
Phosphor bronze a (Alpha) Filament center pin
• Brass body and locking collet • Teflon insulation
• Connections: Set screw
• Specified for cable diameters up to 9.3mm
• Dimensions: 13.8mm ± 0.1 diameter x 54mm ± 0.1mm overall length
Petites annonces pour Câbles divers (connecteurs spécifiques) et Ensembles composites.
Set de 4 fiches RCA FURUTECH RCA FP-106
- Fichiers joints
- 1247310124_fp-106r_l_w390_h390.jpg (8.82 Kio) Vu 4920 fois
- titi501
- Inscription Forum: 07 Oct 2008 19:32
18 messages
Retourner vers Divers et Ensembles
