I have spoken with Stephen smyth and there should be some pictures of both final units on their website in the next 2-3 weeks and they are still well on course to deliver everything by the end of the year. Probably quicker
Modérateurs: Modération Forum Univers Casques, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 24 invités
Smyth Realiser A16 (màj)
D'après un internaute sur le forum Head-fi.org, Stephen Smyth lui aurait dit qu'il diffusera dans les 2-3 semaines qui viennent des photos des deux modèles terminés. Je croise les doigts pour que les délais soient tenus !
- mr.fox
- Inscription Forum: 27 Juin 2002 13:14
News Kickstarter et pour les photos --> https://www.kickstarter.com/projects/19 ... ts/1950017
All aspects of the production are proceeding well. Mass production of the metalwork for both 2U and headstand (HS) will be completed in the next couple of weeks. Pre-production samples of both types have now been reviewed and we are happy to say the manufacturing quality is good. When we get the first production samples back from China (with final silk screen) we will post a complete set of photos.
The A16 board assembly will begin August and we should have these back in the UK mid September at the latest. The HDMI 2.0b hardware is also in manufacture and due for delivery to us early September. We would like to think that final assembly and test will begin before the end of September.
On the software side we are focused mostly on preparing for Dolby and DTS certification. We plan to submit sample A16s to both companies by the end of August. Approval often takes 3-4 weeks but it may take longer if compliance issues arise. Since the A16 design allows for firmware updates, assembly can proceed regardless and we can update prior to shipping as required.
We have two minor developments to report. First, we employed an English woodworking company to make us some trial side panels for the 2U enclosure. They connect to where the rack-mount wings go so you can only fit one or the other. Our feeling is that we probably need at least 4 different wood types to give owners a decent choice if we do decide to offer these panels for sale. The photographs show oak and walnut, both with an oil finish.
2U with oak side panels 2U with oak side panels
2U with walnut side panels 2U with walnut side panels
2U with rack-mount wings 2U with rack-mount wings
Second, we will be including a differential headphone output mode for driving balanced headphones using both User A and User B headphone output jacks together. This mode is intended for single user operation. The photo shows a typical connection for the Sennheiser HD800 using a balanced Custom Cans dual ¼” stereo jack cable where the User A jack drives the left-ch transducer and User B jack the right-ch transducer.
Balanced headphone drive using ganged headphone outputs Balanced headphone drive using ganged headphone outputs
Please note that the enclosures used in these photographs are pre-production and their silk screening differs from the final production units.
We will provide a further progress report at the end of August. Hopefully you will see some photos of the production units before that.
Thank you for your patience.
Stephen Smyth
Stephen Smyth
- chasseur73
- Inscription Forum: 05 Oct 2007 11:18
2° info du jour sur les sorties casques :
juste le lien, ce sera plus simple --> https://www.kickstarter.com/projects/19 ... ts/1950248
Il sera donc possible d'alimenter un "gros" casque en utilisant le A16 seul et la sortie A sur le transducteur gauche et la B sur l'autre.
- chasseur73
on le trouve ou ce cable pour le HD800 ? j'ai beau chercher sur customcans.co.uk, je ne le trouve pas.
en tout cas tres jolie les models de préproduction par contre, ont risque de ne pas être livré en septembre au vus des news j'ai tellement hâte d'avoir ce Realiser...
- Falcon666
- Inscription Forum: 25 Aoû 2016 11:42
Le cable c'est celui la non https://customcans.co.uk/s/s/index.php/ ... apter.html
et il faut choisir les bonnes options.
- chasseur73
c'est bon j'ai trouvé je pense : https://customcans.co.uk/s/s/index.php/ ... cable.html
il faut prendre si je ne me trompe pas ( je vais demandé confirmation ), l'embout 2 X 6.35mm TRS Jacks. ça reviendra moins chers que de prendre le câble "officiel" et l'adaptateur qui vas bien.
En tout cas plus d'inquiétude à avoir pour les casques a forte impédance et ça c'est chouette
- Falcon666
C'est bien ça Falcon666 !
ci-joint le post du jour https://www.kickstarter.com/projects/19 ... ect_update
- chasseur73
Voilà les dernières photos de l'usine du Realiser A16, version boîtier :
- pecman32
- Inscription Forum: 27 Déc 2006 1:39
Voilà les derniers visuels depuis l'usine du Smyth Realiser A16, dans sa version support pour casque (non fourni) :
- pecman32
La finition semble très bonne allez plus que la certification Dolby et DTS à passé et notre précieux devrait pouvoir nous rejoindre
- Falcon666
Pas tres jojo le boitier
Finalement la version casque est plus belle
- thebird69
- Inscription Forum: 27 Mai 2007 19:44
thebird69 a écrit:Pas tres jojo le boitier
Moi aussi, je trouve la version boitier plutôt moche (en même temps, le A8 ne risquait pas non plus de gagner un prix pour son design...
J'ai opté pour la version casque.
Dommage que les Smyth n'aient pas profité de ce courrier d'info pour faire un point de situation sur l'état de la production et surtout sur la date estimée de livraison.
- mr.fox
mr.fox a écrit:thebird69 a écrit:Pas tres jojo le boitier
tout a fait d'accord, je pense qu'ils sont allé à l'essentiel pour conserver des prix compétitifs, après, suivant le succès ou pas, m'étonnerait pas qu'ils sortent une version "deluxe"
- m4kh4r4
- Inscription Forum: 06 Aoû 2014 2:34
Un design classe ou moderne pour le boîtier entraînerait-il vraiment un surcoût si important ?
- mr.fox
Quelqu'un aurait une photo de la nouvelle télécommande ?
- TSW
- Inscription Forum: 08 Aoû 2015 12:44
Retourner vers Amplificateurs Casques
