hum quelle est belle !
pas vraiment compliqué pour le plan avec l'interrieur en photo
WOOF !
Specifications:
Frequency Response: 24 hz - 25 khz
Sensitivity: 94 db - 1 watt @ 1 M
Impedance: 14 ohms
Power Requirements: 7 watts - 500 watts
Dimensions: 52" H x 9" W x 22" D
Weight:165 lbs ea.
Tweeter: Scanspeak Revelator
Specially selected version of the superb Scanspeak Revelator which is capable of very high SPL’s at vanishingly low distortion.
Midranges: SEAS P17RCY pas sur ! a confirmer !
Two 6 1/2 " composition drivers with very large magnet structures with cones that are once once light (low mass) yet incredibly rigid. These units have been optimized for performance in the range of 100hz - 3000 hz. No more, nor not any less.
Woofers: SEAS P25REX pas sur ! a confirmer !
The dual side firing woofers are the 10" versions of the 8" units used in the Super Eclipses. Their magnet assemblies are almost doubled and these woofers were specifically designed and manufactured to reproduce only low frequencies from 125 hz down to 24 hz with less than .5% IM distortion at 24 hz @ 110 db. These woofers in the Total Eclipse enclosure provide true sub woofer performance yet sonically blend seamlessly with the mids and highs.
bon @+ je v faire les plans ! bye
