Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 24 invités
Lecteurs Blu-Ray
Nouveaux camescopes Panasonic HDC-SD100 et HDC-HS100
Message » 19 Juin 2008 9:05
Panasonic vient d'annoncer au Japon ses deux nouveaux caméscopes AVCHD.
Un tri-CMOS remplace le Tri-CCD. On dessends à 2 lux .
Je sens que ca sera mon cadeau de noel....
Voici l'annonce pour l'instant en version US : http://www2.panasonic.com/webapp/wcs/st ... 8020838075
Secaucus, NJ (June 18, 2008) – Panasonic today expanded its High Definition (HD) suite of products, with the announcement of two new full-HD camcorders, the HDC-SD100 and HDC-HS100, the world’s first* AVCHD camcorders with a 3MOS system which provides superb video image quality. The HDC-SD100 records to SD Memory Card, while the hybrid HDC-HS100 records to both SD Memory Card and to its internal 60 GB* hard drive. Both models include manual functions for the user wanting more precise control over zoom, focus, iris, shutter speed and white balance. The models also include Panasonic’s new Intelligent Auto (iA) mode, an intuitive set of technologies that automatically activate, making video shooting an easy, seamless process.
“The camcorder market is moving swiftly to High Definition and superior image quality is now a must-have feature. Moreover, many consumers are also demanding higher-level features, and the ability to be more creative,” said Zoe Susice, Group Manager, Imaging, Panasonic Consumer Electronics Company. “For these users, we introduce two new full-HD 3MOS models – the HDC-SD100 and HDC-HS100 – with manual functions that give users the power to create dramatic, artistic images. At the same time, we also have our Intelligent Auto mode, which activates several technologies automatically, so the user doesn’t need to make any adjustments, and shooting video is an easy and enjoyable experience.”
The world's first AVCHD camcorders with a 3MOS system are newly developed by Panasonic and based on the company’s 3CCD technology, an already-established and renowned system that provides excellent color reproduction. With their expanded light-receiving areas, the MOS sensors also significantly improve image quality, even in low lighting. The three MOS sensors process the red, green, and blue components of incoming light separately, so color reproduction is superb. These sensors also have about double** the light-receiving area of CCD sensors, so image quality when shooting in low light is much higher. Compared with a conventional 1MOS, Panasonic's new 3MOS system captures more vibrant, true-to-life colors, greater detail and richer gradation. This high-precision imaging element is first in the world*** to shoot in lighting as low as 2 lux and helps the SD100 and HS100 capture exceptionally clear, bright images.
Adding to the 3MOS sensor, Panasonic HD Advanced Pure Color Engine and a new Leica**** Dicomar lens – helps the SD100 and HS100 deliver the outstanding images in full-HD 1920 x 1080 recording*****. Full-HD recording, with its total of 2,070,000 pixels, provides exceptional image details and rich colors. The Leica Dicomer lens system used in camcorders comprise 12 lenses in 9 groups, including aspherical lenses to improve resolution and contrast and an LD (low-dispersion) lens to help prevent color bleeding. Also, a special multi-coating process is applied to all lens elements to minimize chromatic aberration, so images are crisp, clear, and free of flare and ghosting. The use of a highly-refractive lens also made it possible to have both 12x zoom power and a compact body.
To maximize the capabilities of the new HD-level 3MOS sensor featured in the SD100 and HS100, Panasonic further enhanced the company’s renowned Advanced Pure Color Engine image processor with the introduction of the new HD Advanced Pure Color Engine. A noise reduction circuit combines with the Intelligent Contrast Control circuit to boost image quality while reducing power consumption. The dynamic range is also about twice that in previous Panasonic models, which helps prevent blown highlights and blocked shadows and allows more natural color expression. Offering both higher image quality and longer battery life, the HD Advanced Pure Color Engine takes camcorder performance to new heights.
Panasonic’s iA mode, automatically activates several convenient shooting functions at once, so the user does not have to manually change any settings. These include:
· Advanced O.I.S. (Optical Image Stabilization) detects hand-shake and then triggers the lens to shift to correctly align the optical axis, helping to ensure videos are sharp and reduce blur. This happens at a rate of 4,000 times per second.
· Face Detection automatically adjusts the exposure, contrast, skin complexion effect, and focus so that faces are always clear. Face Detection can detect up to 15 faces in a frame.
· Intelligent Contrast Control continually measures the ambient light intensity and adjusts the contrast as it changes, helping to prevent a washed-out look in bring parts of an image and black-outs in parts with shadows.
· Intelligent Scene Selection which determines the shooting environment and automatically selects the appropriate scene setting for optimal results.
Both camcorders come packaged with HD Writer 2.6 software for Windows, and also support iMovie '08 for Apple, which let users directly edit the high-quality full-HD moving pictures they capture with their camcorders. The SD100 and HS100 are compatible with Panasonic's VIERA LinkTM, allowing users to connect the camcorder to a VIERA HDTV via an HDMI cable, and operate the camcorder using the TV remote control, and following on-screen prompts. Furthermore, users can also take the SD Memory Cards from the camcorders and slip it into the SD card slot on a Panasonic PZ850 series VIERA HDTV, or a Panasonic BD50 or BD30 Blu-ray DiscTM Player, and enjoy easy, instant large-screen viewing of stunning HD video.
Users can also copy their video content to DVDs for quick, convenient playback. A Panasonic VW-BN1 DVD Burner (optional) can be used to burn HD images onto a DVD disc in the original AVCHD format; no need to use a PC. The copied DVD discs can then be easily played with the VW-BN1 and sent via the SD100 or HS100 to a HDTV.
Other features of both the HDC-SD100 and HDC-HS100 include:
· Quick Power-On ensures the camcorders are in recording standby and can shoot in just 1.9 seconds, making it easy to catch spur-of-the-moment shots, while being conservative of the battery.
· Digital Cinema Color mode automatically switches the camcorder to the optimum setting for the Digital Cinema Color mode, available on Panasonic’s VIERA Plasma HDTVs, providing a theater-like viewing experience.
· Intelligent Shooting Selection Playback automatically detects scenes that have serious flaws – such as images that are completely out of focus or shots of the ground taken inadvertently – and automatically skips them during playback. Viewers see only high-quality, mistake-free moving images.
· 5-Microphone, 5.1-Channel Surround Sound System allows users to feel surrounded by clear, detailed sound during playback on a 5.1-channel home cinema. A Zoom Mic function links the microphone’s capabilities to connect to what the camcorder is recording. A Focus Mic function picks up the sounds from sources in the area in front of the camcorder, regardless of whether the lens is focusing on a near or distant object.
· Mic Input and Headphone Jack allows the camcorders to connect to an external mic or headphones.
· High-Speed Burst Shooting lets the camcorders snap up to 24 consecutive 2.1 MB resolution still images in a second, or up to approximately 72 consecutive shots in 3 seconds.
· Pre-Rec enables the camcorder to continuously record three seconds (while in the Pre-Rec mode) internal buffer memory. Then, when the Record button is actually pressed, the three seconds immediately prior are added at the beginning of the clip.
· Wide-Viewing-Angle LCD has 300,000 dots and a 170-degree viewing angle both vertically and horizontally. This LCD provides extended viewing from both high and low angles.
Both Panasonic models will be available in September 2008 for manufacturer’s suggested retail prices of $1,299.95 for the HDC-SD100 and $1,099.95 for the HDC-HS100. For more information, please visit http://www.panasonic.com.
hf206
Inscription Forum: 09 Sep 2005 19:40
Message » 23 Juin 2008 18:37
Et le concurent chez sony : http://www.letsgodigital.org/fr/19283/s ... -hdr-cx11/
La guerre va être rude d'ici noel.
hf206
Message » 23 Juin 2008 18:46
hf206 a écrit:Et le concurent chez sony : http://www.letsgodigital.org/fr/19283/s ... -hdr-cx11/
Info reprise en Fr. Sony annonce l’arrivée en août de l’HDR-CX11 sur http://www.hdnumerique.com/actualite/ar ... -cx11.html
Idematoa
Inscription Forum: 10 Déc 2006 13:59
Message » 23 Juin 2008 18:49
Autre Réf. Sony - Sony HDR-CX12 AVCHD camcorder captures smiles and scowls for $900.
Lien : http://www.engadgethd.com/2008/06/19/so ... ls-for-90/
Idematoa
Message » 25 Juin 2008 5:56
salut,
aucune précision pour le 1080p ou i ?
c'est dure de trouver des infos valable sur les camescopes meme les constructeurs sont un peu flou.
y aurait peut etre le sony sc-hmx20c
http://www.hdnumerique.com/actualite/ar ... 1080p.html
57jerome
Inscription Forum: 06 Déc 2006 9:48
Message » 25 Juin 2008 13:09
ca risque d'être comme souvent du 1080i50 Hz pour les zone pal et eventuellement 1080p25
hf206
Message » 26 Juin 2008 2:05
j'ai commandé le samsung vp (et pas sc) hmx20c, je sais pas ce que ces 2 lettres changent , bref 1080i mais enregistre la vidéo en h.264, capteur CMOS 6.4 mega et un mode 300img/s pendant 10 sec pour filmer des explosions par exemple ?
57jerome
Message » 22 Sep 2008 15:30
hf206
Retourner vers Lecteurs Blu-Ray
