Après bien des soucis (Blight a vu partir en fumée son forum sans pouvoir faire quoi que ce soit), la nouvelle version de ZP est sortie.
Les nouveautés :
* Zoom Player Professional has been split into a third version.
"Zoom Player WMV Professional" is a seperate version of Zoom
Player which is capable of playing DRM encoded Windows Media
files.
Due to the licensing fees involved in playing DRM content files,
Zoom Player WMV Professional requires a purchase upgrade from any
previous version of Zoom Player.
In order to play DRM files you must first obtain the DRM license
by using Windows Media Player 9 to obtain the license, or with
certain WM-DVD discs, just by inserting the disc in the drive
for the first time (note that license can expire after several
sessions).
You must also download this patch from microsoft which fixes
important issues with Windows Media DRM playback:
http://support.microsoft.com/default.as ... -us;823738
Furthermore, you must have a Display Card capable of working
in Video Mixing Renderer 9 (VMR9) mode.
* The Navigator Interfaces have been rewritten from scratch.
Most of the functionality has remained the same, but the
graphical elements have a clearer look and are now skinnable.
Here are the usability changes:
- The File Navigator
1. Switching between the file and drive listing is now done
using the left/right (directions switched).
2. The right direction in the file navigator will go up a
directory where possible.
3. The current path is now always visible.
- The Play List Navigator:
1. The design has changed entirely, the display is now split
into three regions, the main play list, the current directory
for the highlighted file and a mini file browser.
2. When the Play List items are active, pressing the Left button
will remove the currently highlighted item from the list.
3. When using the Up/Down buttons within the Play List items,
the file browser will automatically switch the current location
of the highlighted file.
4. The Right button switches between the Play List items and the
File Browser.
5. Pressing Enter in the file browser will add a highlighted file
or enter a directory.
6. Pressing the Left button in the file browser will add an
entire directory or all the files in the directory if a file
is highlighted
- The Media Library Navigator:
1. Similar to the File Navigator design, the media categories are
now visible on the left pane at all times.
2. The Right/Left buttons always switch between categories and the
active category is highlighted on the left pane.
* Double clicking on the file name area will now switch between
Audio mode and DVD Mdoe.
* New Setting (Advanced Options / Control Bar / Settings) allowing
you to limit the control bar so that it only shows up on mouse
movement when in fullscreen mode.
* Two new skin variables "tLineFontHeight" and "cBarFontHeight"
which are superseding "tLineFontSize" and "cBarFontSize" which
were ill suited for Large Fonts. Support for the older variable
remains to keep compatibility with old fonts.
* Zoom Player can now associate and play CellPhone 3GPP (.3GP)
s263 video files (Must have QuickTime installed for it to play).
* You can now associate the OptimFROG (.OFR) extension and play
OptimFROG files once you the decoder installed. OptimFROG is
yet another lossless audio compression format (in the nature of
APE and FLAC). You can get the OptimFROG decoder here:
http://www.inmatrix.com/zplayer/formats/optimfrog.shtml
+ Audio DSP should take less CPU power, especially under SSE/SSE2
capable processors.
+ The playback from archive formats now has a checkbox which allows
you to select whether the file extension should be looked at to
determine if the file is an archive, or if the whole file name
should be evaluated (in a case where the file name might actually
contain the string, such as "my_music_albw.mp3" or "audio.zip.mp3").
+ The Segment Matching Code has been enhanced to support "*" masking.
This new method only works when used at the end of the mask. For
example, a mask of "x??.*" would match the following:
Andromeda.4x01.answers_given_to_questions_never_asked.avi
Andromeda.4x02.pieces_of_eight.mpg
Andromeda.4x03.waking_the_tyrants_device.avi
And so forth ...
+ SHOUTcast Playback should now be more reliable, Zoom Player will
now try the alternate servers if one fails to connect.
+ The "System" Options dialog entry has been replaced with a "Formats"
entry. The content of the previous "System" dialog has been moved to
the "System Overview" tab within the new "Formats" section. Another
tab on the formats section now contains a list of detected missing
playback components with links to where you can download and get
more information about each component/format.
+ Zoom Player can now detect if Flash or QuickTime is missing and
inform you on the "Missing Formats" page.
+ New "function" parameter on the "DrawExText" skinning function
allowing you to specify a double-click function for text labels.
+ If Windows Animation is enabled (in windows), Zoom Player will no
longer animate the window when going fullscreen or when minimizing
as it's not very elegant.
+ Vowel decimation is now used to ensure ID3 display fits within the
display area.
+ The Resize Navigator now displays the current Video Aspect Ratio.
+ You can now select the Custom Mouse Wheel function from a list
instead of manually typing it in.
- Extracting from archive didn't work for unicode archive names.
- Using Zoom Player to execute external files could cause
certain Zoom Player features to stop responding.
- The Control Bar and TimeLine fonts should now appear properly when
Windows is set to 120dpi Large Fonts.
A télécharger ici
1 message • Page 1 sur 1
Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 30 invités
ZP 4.00 beta3
- Christophe Elecson KLS
- Inscription Forum: 23 Sep 2000 2:00
1 message
Retourner vers Matériel PC Home-cinéma |
