Sur la page d'acceuil de sparkaudio.com il ya un ampli A-70T qui me semble nouveau.
ça ressemble à un A-88T avec des KT88 (et il y aurait une version avec des EL34...)
J'ai cru comprendre qu'il fonctionnait en classe A2 (??) avec 2*30W pour des KT88 en ultralinéaire,
(2*18 triode)
les seules infos que j'ai trouvé :
http://www.sanyue.net/front-news-show.asp?id=1653&mtype='%B9%A6%B7%C5'
avec une traduction babelfish ci-dessous:
quelqu'un en sait-il plus?
Outside ◆ the pure gallbladder, the pure hand-planted, entire machine used builds a shed the welding ◆ to use two high quality widths frequencies to make a sound the EI output transformer ◆ use specially to use two Russian 12AX7EH and two Russian 12AU7EH electron tube ◆ level after this machine development ring-like power transformer ◆ front level uses four KT88 electron tube to make a A2 kind of 推挽 power to enlarge ◆ provides sets at the power tube choice function. The T1-KT88 work way, is suitable KT88, 6,550, KT66, KT90, the KT100 electron tube. The T2-EL34 work way, is suitable EL34, 6CA7, the 7189A electron tube. ◆ provides the triode and the ultra linear choice function. The triode work way, the sound soft, pure and is smooth, suits appreciates the sounds of people, the stringed instruments of the same kind sound source; The ultra linear work way, the sound opens raises, boldly, the imposing manner is good, suits the appreciation magnificent scene, the greatly dynamic of the same kind sound source. After ◆ selects the Japanese ALPS motor potentiometer ◆ to have the pure level function ◆ to have the remote control function ◆ opening machine time delay function (approximately 30 seconds) ◆ to use 厚层 the silver-plating signal lead wire * The output 2×30W (RMS, ultra linear connection, the KT88 tube) 2×18W (RMS, triode connection, the KT88 tube) 2×28W (RMS, ultra linear connection, the EL34 tube) 2×15W (RMS, triode connection, after the EL34 tube) * the frequency response 15Hz~48kHz ±3dB * total harmonic distortion 1% (1kHz) * input sensitivity 380mV (merge type input) 800mV (pure level input) * signal to noise ratio 90dB * the input impedance 100k Omega * output impedance 4 Omega, 8 Omega, * the volume (width * high * is deep) 440×210×397mm □* the weight 26.5kg * maximum work to consume 280W
7 messages • Page 1 sur 1
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: aqua35, rod93 et 246 invités
Spark / Cayin : A-70T remplace le A-88T ?
- micmrs
- Inscription Forum: 12 Sep 2004 17:27
Je pense plutot a une declinaison de l a88t en moins puissant qu à un remplacant.Il me semble que le a88t à été remplacé par le I88t ( pas sur de la reference similair au a88t mais pas d entré processeur) il y a tres peu.
Donc il serait étonnant que Cayin rechange deja.
Perso j opterai plus pour un model un gamme en dessous au a88t( du fait qu il est une puissance de 28W la ou le a88t en propose 50).
Mais bon simple supposition, merci por l info.
Rani
Rani
- ranix
- Inscription Forum: 17 Déc 2003 21:53
it88 pour le nouveau a88t vendu en allemagne
- SoulMan
- Inscription Forum: 04 Juin 2004 10:23
question peut être idiote, pourquoi l'appelles tu a-70t ?
- SoulMan
斯巴克合并式/纯后级真空管声频功率放大器 A70T
dans les news il ets presnté de cette facon.
A l afin il y a ecri A70T on peu presumer que c est la reference du model.
- ranix
oki
j'avais pas vu...
j'avais pas vu...
- SoulMan
ranix a écrit:斯巴克合并式/纯后级真空管声频功率放大器 A70T
traduction automatique de ce titre avec babelfish:
"After merge type/pure level vacuum tube audio-frequency power amplifier A-70T"
D'après les infos sur ce forum, l'IT88 n'apporte rien par rapport à l'A-88T,
au contraire on perd l'entée "pré-in".
- micmrs
7 messages
