Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: Bing [Bot] et 20 invités
ZP 4.50 Final
Message » 06 Juil 2005 18:40
http://www.inmatrix.com/files/zoomplayer_download.shtml
Changes from v4.50rc2:
CODE
* Ctrl+C now copies the content of a Red error message to the clipboard.
* New Comm API messages (1020,1021) indicating Fast Forward
and Rewind states.
* New Customized Media Playback profiles for LPCM MPEG Audio.
+ The "External" tab on the Advanced Options page has been updated to
support the latest version of the WinDVD Decoder.
- Loading ASX Playlists would only add the first file in the list.
- The default web navigator file setting was not being saved properly.
- The Internal Screen Saver will now cover the entire screen area and
not just the screen area active by the current Aspect Ratio (navigator
interfaces were not hidden by the screen saver). Also, file names
appearing in the screen saver can now contain unicode characters.
- Setting the Player Thread Priority would not have an effect until
the player was restarted. Now the effect is instant.
- When specifting a default file navigator starting path, the starting
file index was not always correct.
- When set to only show an icon on the system-tray, a task bar button
could have appeared when double-clicking on a media file from an
external program (such as explorer).
- Loading GraphEdit ".GRF" files will no longer throw an error when
Customized Media Playback mode is enabled.
- The DVD Title on the skin was not center-aligned.
Christophe Elecson KLS
Pro-Commercant
Pro-Commercant
Inscription Forum: 23 Sep 2000 2:00
Message » 06 Juil 2005 22:28
quelles sont les differences entre la version Zoom Player WMV Professional et la Zoom Player Professional ?
a+
gigi44.
Inscription Forum: 04 Mar 2003 12:34
Message » 07 Juil 2005 8:13
WMV = support pour les décodeur DVD + Lecture des WMV
Pro = support pour les décodeur DVD
http://www.inmatrix.com/zplayer/pro/wmv_why.shtml
jeffaries
Inscription Forum: 07 Jan 2005 17:45
Message » 07 Juil 2005 8:47
par lecture des WMV il faut comprendre gestion des DRM de M$
car la version pro sait lire des fichiers encodés en WM9 sans DRM.
Danam
Inscription Forum: 12 Fév 2002 2:00
Message » 07 Juil 2005 8:52
ok merci pour vos reponses :)
gigi44.
Message » 07 Juil 2005 21:51
Tu entends par la que zp wmv pourrait me lire mon DVD des rivieres pourpres 2 en wmvhd ?
Alex
AlexLeCoooool
Inscription Forum: 05 Sep 2001 2:00
Message » 08 Juil 2005 11:25
C'est la 1ère fois que je vois cette possibilité de lire les .GRF :o
Quelqu'un a déjà pratiqué cette solution ? Comment la met on en musique ?
Emmanuel Piat
Contributeur HCFR 2016
Inscription Forum: 10 Oct 2000 2:00
Message » 08 Juil 2005 12:49
Emmanuel Piat a écrit:>- Loading GraphEdit ".GRF" files will no longer throw an error when
Je viens juste de faire le test, ça marche. Tu mets ton graphe généré par Graphedit dans le dossier de DVDgraph de Zplayer, il est reconnu automatiquement.
Par contre il faut rajouter avant à la main les lignes de définition de filtre.
Désolé si mon explication est alambiquée, mais j'ai lançé Graphedit pour la première fois il y à 30 minutes. Avec le tuto du site Inmatrix, c'est du velour. :wink:
Lansing
Inscription Forum: 23 Mai 2005 21:01
Message » 08 Juil 2005 17:40
AlexLeCoooool a écrit:Tu entends par la que zp wmv pourrait me lire mon DVD des rivieres pourpres 2 en wmvhd ?
Alex
Oui c'est bien ça et ça marche !
Alex727
Inscription Forum: 10 Déc 2002 16:32
Message » 08 Juil 2005 21:07
Ce qui semble interessant à tester c'est le VMR9 renderless...
DTSman
Contributeur HCFR 2022
Message » 09 Juil 2005 0:19
DTSman a écrit:Ce qui semble interessant à tester c'est le VMR9 renderless...
Je viens de mater un film et des extraits de concert avec le filtre Nvidia et le render en VMR9 renderless.
Adopté ! je n'ai jamais eu une image de concert comme celle-là. Pour info, j'utilise le filtre windvd audio avec les réglages de base de registre kivonbien et ça marche fort également. :D
Lansing
Message » 09 Juil 2005 13:35
c'est quoi en français, le vmr9 sans rendu, à d'accord.
OUi il a l'a
dadamen
Inscription Forum: 22 Jan 2004 19:58
Message » 09 Juil 2005 13:37
de bien marcher, sur le principe c'est quoi par rapport au vmr9 fenêtré ou non fenêtré, parceque la conso cpu est inchangé.
Ca travaille sur quoi?
Ce zp 4.50 final je pense qu'il va être bonnard.
dadamen
Message » 09 Juil 2005 14:03
faudrait quand même qu'il puisse voir le décodeur MPEG2 de ffdshow pour être quasi parfait :(
DTSman
Message » 09 Juil 2005 15:39
Oui mais bon il est comment de décodeur mpeg2 de ffdshow, il est à la hauteur, moi nvidia me convient très bien.
dadamen
