Une photo :
et les spécifications techniques :
Display Imaging Technology 0.74 3-LCD (with Micro Lens)
Brightness/Lumens 1200 ANSI Lumens
Native Resolution 1920 x 1080
Viewable Size 50-250 inches
Contrast Ratio 14000 : 1 (on/off)
Color Wheel N/A
Lens Lens Throw Ratio 1.6 -1.9
Zoom & Focus Adjustment Powered Focus & Zoom (Zoom Ratio 1.2:1)
Compatibility PC, MAC Compatibility Yes
Operation Scanning Frequency [H] 15 - 100 kHz, [V] 50 - 120 Hz, [Dot clock] max. 162 Mhz
Interface NTSC, PAL, SECAM NTSC / NTSC 4.43 / PAL (including PAL-M, N) / SECAM / PAL-60, Component Video: 480i/p(525i/p), 576i/p(625i/p), 720p(750p 50/60Hz), 1080i(1125i 50/60Hz), 1080p(1125p 24/50/60Hz), SCART (RGB + 1V sync)
Computer/Video Input Support PC: Mini D-Sub 15pin x 1, Video: HDMI x 2, RCA x 1 , S-VIDEO x 1, RCA (Y,PB/CB,PR/CR) x 1
Computer Monitor Loop-Out N/A
RS-232 Communication Support RS-232C ; D-Sub 9pin x 1
Audio Speaker/Audio Out N/A
USB Mouse Support N/A
Lamp Lamp Life 5000 hrs (low mode) hours (low mode)
Usage Replacement Lamp Replacement Lamp Bulb (VLT-HC5000LP)
Physical Weight 12.3 lbs.
Dimensions (W x H x D) 13.1 x 4.9" x 13.9"
Power Consumption 250W/2.5A
Power Requirements AC 100-240V, 50/60Hz
Service and Support 2-Years Limited Parts and Labor Warranty, 1-Year or 500hrs lamp warranty (whichever comes first)
Included Accessories AC Power cable, RGB cable, RS-232C cable, Remote Unit (incl. battery), User Manual CD, Safety Manual, External Air Filter, Lamp Replacement Tray
