Type : Switch HDMI 3*1
Marque : Oppo
Modèle et options : OPPO HM-31
Prix de vente : 60 euros fdpin
Département où la marchandise est visible : 33
Montant des frais d'expédition : inclus dans le prix de vente
Première main : non
Prix neuf : 131$
Facture disponible : oui
Date et lieu d'achat : 1/04/08 USA
Garantie et date d'expiration : ?
Numéro de série : il y en a un
Description générale : Switch HDMI 3*1 de la marque Oppo. Certifié 1080p, HDMI 1.3
The OPPO HM-31 Advanced 3x1 HDMI Switch is able to expand a single HDMI input port on your HDTV to connect up to three HDMI sources, such as DVD, Blu-ray or HD-DVD players, cable or satellite receivers, and gaming consoles. No longer bound by the limited HDMI connectivity on most HDTVs, home theater users can expand the number of source devices thanks to the OPPO HDMI switch.
The OPPO HM-31 HDMI Switch is among the very few HDMI switches to pass the official HDMI 1.3 certification test. The certification ensures that the HM-31 HDMI Switch is compatible with all HDTV resolutions up to 1080p and PC resolutions up to 1920x1200. Equipped with advanced HDMI 1.3 features such as Deep Color, higher bandwidth and a signal equalizer, the HM-31 HDMI Switch is ready to support the latest generation of home theater products.
The HM-31 HDMI Switch transmits rich, vibrant images and sound while maintaining the highest in video and audio quality. It is EIA/CEA-861D, DVI 1.0, and HDCP 1.1 compliant and supports DDC and HPD switching to ensure maximum device compatibility. Equipped with a remote control, this switch provides the option of resting on a table-top or mounted on a wall. Custom home theater installers will find the IR input and RS232 remote control convenient options for integration. With the worries of HDMI connectivity problems put behind by the HM-31 HDMI Switch, it’s now the time to enjoy your HD entertainment, whether it’s from your favorite OPPO up-converting DVD player or any other HDMI source.
FeaturesHDMI
* Easy and convenient selection from up to three HDMI sources
* HDMI 1.3 specification with DDC and HPD switching
* Fully supports 1080p, Deep Color , and all HDTV resolutions
* EIA/CEA-861D, DVI 1.0, HDCP 1.1 compliant
* Long cable support with built-in equalizer
* Maintains highest video and audio quality
* Remote control
* Custom installation options – external IR input and RS-232C port
Specifications:
Standard Compliance : HDMI 1.3, EIA/CEA-861D, DVI 1.0, HDCP 1.1
HDMI Output Port : 1
HDMI Input Ports : 3
Signal Range : Up to 1080p@60Hz or 720p/1080i@120Hz with 12-bit color depth
Remote Control : yes
Built-in IR Sensors: 2
External IR Sensor: optional
RS-232C: optional
Power Supply : 5V DC
Power Consumption : 3 Watts (max)
Power Adapter : oui pour prise française
Input: ~ 100V – 240V, 50/60Hz AC
Output: 5V DC, 1A max
Operating Temperature : 5°C - 35°C
Operating Humidity : 15% - 75%
Dimensions : 7-3/8" x 4-1/2" x 1-1/16", 187mm x 116mm x 27mm
Weight : 9oz or 0.25kg
Site web du constructeur : http://www.oppodigital.com
Commentaires : Je le vends car finalement pas utile : je n'ai plus que ma PS3 branchée donc plus besoin d'un switch
Pour toute question ou photo n'hésitez pas à me contacter.
4 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 12 invités
Petites annonces pour Switch et Adaptateurs.
A clôturer svp. Vente annulée.
- Invite17
4 messages
Retourner vers Switch et Adaptateurs |
