Sorry for writing in English as I cannot speak French. It is me, LovingDVD, from the AVS Forums. I have been trying for weeks to get my EyeOne Monitor to work with HCFR 2.1. Previously I used this device with HCFR 2.01 on Windows XP. So i do not know if the issue is with the HCFR 2.1, or whether I have a problem with the driver on Vista x64. I also tried on Windows 7 x64 with the same result.
When I try to take a measurement HCFR responds with "EyeOne.dll returned an error during initialization. Device not connected".
The device is plugged in and Device Manager shows this listed under "X-Rite Devices" then under that, "i1 Monitor". Driver version shows as 2.40.0.1315.
I have tried installing the X-Rite driver from other sources and it always installs as this version.
I also tried the instructions here: http://www.marcelpatek.com/hcfr.html and got the 3.4.0.131 eyeone.dll from the Eyeone Match 3 and put that into the base ColorHCFR folder but it made no difference.
I also installed the i1 Diagnostics tool from X-Rite. That tool works just fine, communicates with the EyeOne Monitor OK, runs all the tests and comes back and says the meter is working good.
I have been trying to get help on AVS Forums, but things they suggest have not worked. See http://www.avsforum.com/avs-vb/showthre ... st17045144 .
I've been at this for over a week. Hopefully someone here can tell me what I am doing wrong please?
Merci beaucoup!! (that much I do remember from high school French class
