APC c'est aussi une marque réputée dans le domaine des onduleurs et de la protection électrique
Pour les câbles HP, il y a bien des différences sonores, je suis d'accord avec toi. J'en ai fait l'expérience moi aussi. Mais tu peux trouver le son que tu aimes sans dépenser une fortune.
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: alfan, CRS, frider, maniacos, thi et 406 invités
j'ai écouté un poppulse mais le bruit résiduel était assez pénible
ce nouveau venu est -il bruyant? ( ronflements/ buzz / souffle)
- jamesdu69
- Inscription Forum: 01 Mar 2009 11:03
Un avis sur le Populse (en anglais sorry):
par Stephan Date d'ajout : samedi 20 juin, 2009
I had my eye on this amp for quite a while since the "Poppulse T77" popped up on the market. I thought it was time to give it a try and find out what the rave is all about. My intention was to use it as a cool running amp for my second system comprising of a "Mac Mini" as music server wirelessly transmitting to an "AirPort Express" which is feeding a "Moodlab Dice DAC". Speakers are planar "Magnepan MMG-W's" (88 dB, nominal impedance 5 Ohm) running in stereo mode. The inevitable sub bass system comes from "BK electronics/ Great Britain - model XLS200" (they're built to order). Some months ago I hooked up my "Naim Nait 2" in between after ordering some Chord RCA/DIN cables plus Chord Rumour speaker cables. The "Naim Nait 2" is my back up amp for a pair of "Martin Logan CLS" which are commonly driven by "Leak TL/ 25 plus" mono tube amps. Huge output transformers serve enough current for the Logans. As you can google about the "Naim Nait 2" ain't no slouch at all - it drives the Logans (85 dB, going down from 4 to 1,6 Ohm) sufficiently but as a typical Naim product is from the "flat earth" type. It comes nowhere near to the Leak monos which make the instruments almost palpable in a 3D stage where speakers disappear.
So I took my chance and let the Poppulse burn in a few days as recommended by a lot of users. Just for fun I hooked the "Poppulse T150" up to the "Martin Logan CLS" and wasn't even surprised that the sound was rather thin and flattened. Turning up the volume knob (which is slightly out of center and therefore scratching at the edges of either turns) from mid-position to high did not change very much - music wasn´t getting louder. Turning up a little further or even to full extent brought the "Poppulse T150" to clipping or better "muting" (due to overcurrent protection).
I hooked the "Poppulse" to the "Magnepan MMG-W"-set hoping they were able to drive a not so heavy load (at least on paper!). All I can say is that this amp is not capable of driving the 88 dB Magnepan speaker to a satisfying level. To get a volume level that was recognizable I had to turn the volume knob half way round, turning it up to full extent did not change very much either (though not clipping this time). I couldn't concentrate very much on the musical presentation and the soundstage the amp threw in because it is insufficient to my ears - which makes all other t-amps suspicious too unless they exactly double their output from a 8 Ohm to a 4 Ohm load - which the "Poppulse" does NOT (77W @ 8Ohm an 150W @ 4 Ohm).
Rather disappointing: I don't think I will give it a try as a mono block since I have to order another one and I'm very curious it will not change the situation by any means.
Classement : [1 sur 5 étoiles !]
Mais il y a d'autres avis plus enthousiastes sur des enceintes à HP
- tkfu
- Inscription Forum: 17 Oct 2008 14:05
en gros il n'a pas assez de coffre, de réserve de puissance,
mais pour des enceintes au rendement confortable?
- jamesdu69
Cet avis (tueur) est unique. Les gens de chez Audiophonics l'ont laissé, gentiment. Maintenant, des Magnepan, c'est pas les enceintes les plus courantes !
- pode
- Inscription Forum: 18 Juil 2002 12:10
Quelqu'un pour le poppulse T 150 mk 2 ?
Nos amis québecois peut-ëtre ....
http://www.obadimports.com/catalog/item ... 829244.htm
Bluesound Node / SMSL M500 /McIntosh MA 5200 / Davis Monitor 1 /Mogami 3103HP.
autrichon gris - Modérateur Œuvres & Multimédia
- Inscription Forum: 21 Oct 2009 14:18
Au fait, pode, pas de bruits parasites sur les enceintes avec ton Poppulse ? Les propriétaires de HLLY TAMP-90 doté du même circuit TA2022 se plaignent de ce genre de bruit http://forum.hardware.fr/hfr/VideoSon/HiFi-HomeCinema/tamp-ta2022-essai-sujet_122926_1.htm.
- Mikele
- Inscription Forum: 17 Déc 2001 2:00
Salut Mikele,
Je viens de faire le test, source éteinte.
Il y a un petit bruit blanc, au dessus de 10k environ. Son volume ne varie pas avec la position du bouton de son. Je ne le perçois qu'à quelques cm, mais, mon fiston, jeune et musicien, le perçoit jusqu'à 20 cm environ en ambiance calme d'appartement (dans l'axe du tweeter). Vraiment pas méchant.
- pode
Pode
Quel est le rendement de tes enceintes ? Mes futures JBL sont à 92db. Peut-être que le bruit s'entendra un peu petit plus loin chez moi.
- Mikele
90 dB pour 2,83V à 1M (doc. Kef ; après calcul, cela correspond bien à la valeur classique en dB/W).
Franchement je ne pense pas qu'avec tes JBL cela fasse beaucoup de différence ; c'est très imperceptible.
- pode
bonjour à tous . Pensez vous que sur des Rogers 82 db ça peut marcher, y aura t il se bruit résiduel . Puis je avoir un lien du site marchand svp , pas trouvé . merci et bonne journée
- joulie17
- Inscription Forum: 10 Avr 2006 14:51
"audiophonics". Google it !!
Plus personne sur ce topic ? Est-ce bruit résiduel qui vous dissuade ? J'en ai eu sur tous mes amplis et celui-ci est bien plus faible (je répète, inaudible à 20 cm, même à fond !). Au bout de 15 jours de tests, toujours aussi content de cet achat et déjà un ami convaincu de remplacer son Naïm (je crois) par ce joujou...
- pode
Remplacer son Naim ? Euh... Avantageusement ?
En tout cas ça ma taraude ce poppulse. Ca va mal finir....
Il faut d'abord que j'aie mes enceintes avant de craquer pour le Poppulse...
- Mikele
