Modérateurs: Modération Forum DIY, Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: coucouse, Solitaire555 et 18 invités
Tout l'univers du pilotage et des télécommandes
HARMONY, les réglages et leur effets
Message » 27 Juin 2012 18:40
Sujet en cours de rédaction
ne pas poster ici pour l'instant SVP
Ça fait un moment que je voulais commencer à compiler les infos sur ce thème
au moins 15 jours, déjà !
en même temps je n'ai ma 1er Telco All In One que depuis 3 semaines
avant j'y connaissais rien.........
LOL
POWER_ON Delay
INTER_KEY Délay
SOURCE_INPUT Delay
INTER_DEVICE Delay
PRESS_ACTION Delay
HOLD_ACTION Delay
PRESS_ACTION & HOLD_ACTION INTIMEMENT LIÉS
Je viens de découvrir un sujet en anglais sur le forum Logitech traitant de la même chose ---- ici -----
dont je copie le texte ci-dessous :
If your device doesn’t react to a command from the Harmony, it may be because the delay setting needs to be adjusted. By default, different devices take different amounts of time to react to a command from a remote control. To accommodate these differences in your devices, the Harmony uses several types of delays, or speed settings, to control your devices.
Power On Delay
The Power On Delay is the amount of time that a device needs to “warm up” before receiving another command. For instance, when you turn on a device, you may notice that the device needs a certain amount of time before it can receive another command from the remote.
Example:
Every time I turn on my system with an Activity, my TV powers on but doesn’t go to the correct input. However, it does go to the correct input when switching between Activities when the TV is already on. The Help button fi xes it each time, but I don’t want to use the Help button every time.
Inter-Key Delay
The Inter-Key Delay is the amount of time allotted for commands to be sent between button presses.
Example:
Any time I press volume up multiple times in a row for my AV Receiver, it takes a long time to increase the volume. I would like my devices to respond quicker to these presses.
Input Delay
The Input Delay is the amount of time that the remote takes when switching between inputs. Many devices need a certain amount of time before changing to the next input in the input list.
Example:
My TV doesn’t always go to the correct input when switching between Activities and I have already verifi ed that the input list is correct.
Inter-Device Delay
The Inter-Device Delay is the amount of time between commands for different devices when you start an Activity. The Inter-Device Delay is also the time between the next sequence of commands that are sent to other devices within an Activity.
Example:
My DVD player doesn’t always turn on when I start the Activity. I can get the DVD player to turn on by using the Help button, however I don’t want to use Help every time.
Repeats
The Repeats are the number of times the remote repeats a command for a device to properly respond to the command. For instance, many devices need longer or shorter command repetitions to respond properly.
Example:
Any time I press channel up, my Digital Set Top Box skips two channels at a time.
blues93
Inscription Forum: 08 Nov 2010 16:59
Localisation: XTreamer MK1, Harmony 900/700/300/200 +Blaster_RF to IR +PS3Ext_IR to BT, TS-509Pro +SB_Touch
POWER_ON Delay
Message » 27 Juin 2012 18:42
Qui Quoi Comment > Latence nécessaire pour la Mise en Route du 1er Dispositif
• POWER_ON Delay = délai laissé au dispositif type TV pour s'allumer avant de lui envoyer une autre Cde IR
- délai utilisé dans l' Activité "Watch TV" où tout autres activités incluant l'allumage de la TV
blues93
INTER_KEY Delay
• INTER_KEY Délay = délai entre envoi successif de commandes IR
- délai que la télécommande respectera lors de l'envoi de chiffres successifs formant un n° chaîne de TV
Ex: chaine favorite 123 -> 1+2+3 = 1 + Inter Key Delay + 2 Inter Key Delay + Inter Key Delay + 3
et aussi
- délai minimale à respecter entre l'appui sur deux touches pour qu'elles soient prisent en compte par la télécommande
blues93
SOURCE_INPUT Delay
Message » 27 Juin 2012 19:22
• SOURCE_INPUT Delay = délai avant envoi de la commande IR de changement de l'entrée source vidéo
- Commande(s) IR = Next Video Input
blues93
INTER_DEVICE Delay
Message » 30 Juin 2012 1:25
• INTER_DEVICE Delay = délai séparant l'envoi de 2 commandes IR vers 2 Dispositifs différents
- délai respecté dans les Activités et les séquences (à vérifier) entre 2 signaux IR envoyé successivement
mais à destination de 2 dispositifs différents, pour s'assurer que le 2nd dispositif soit en mesure de prendre en compte la commande IR qui en suit une autre
Les états IR d'un Dispositif nécessaire pour la prise en compte d'une commande IR prennent du temps
Les différentes étapes sont "Cde IR - Prêt" > " Cde IR - Réception en cours" > "Cde IR - Traitement" > "Cde IR - Prêt"
Qui Quoi Comment > Durée entre 2 dispositifs
• Qui : à qui se réglage s'applique t'il ?
• Quoi :
• Comment : comment accéder à ce réglage
- Paramètre inaccessible via MyHarmony.com (appeler le SAV)
- Paramètre accessessible via Harmony Remote Control Software
pour y accéder .........
• Symptômes : Une commande au sein d'une activité (séquence) n'est pas prise en compte par un dispositif
• Tests préliminaires : tests pour déterminer que ce réglage est bien en cause
Exemple avec le cas de l'Activité "Watch TV" où l'un des dispositifs ne s'allume pas ou ne s'éteint pas :wtf:
Test 1 : Lancement de la commande directe de Power On/Off du dispositif en question = Ok
Test 2 : Lancement de l'Activité (séquence) utilisant le Power On/Off du Dispositif = pas Ok
"là l'étau se resserre" :hehe:
• Durée par Défaut = 500 ms
- Durée mise par le SAV lors de l'appel pour ce type de Pb = 1 000 ms
- durée recommandé par moi 600, 700 et 800 ms doivent suffirent (plus il y de commande dans la séquence et plus les délais s'additionnent)
au final ça peut faire long avec des durée de 1s et plus...... !
Explication imagée :
pas simple de faire un comparaison à la fois simple et juste !
dès que j'ai trouvé je l'ajoute
Explication détaillée :
Exemple de durée 1 000 ms de délai séparant l'envoi successif de 2 commandes destinés à 2 dispositifs différents
ce paramètre (durée) sert à permettre au 2nd dispositif,
de retourner à l'état "près à recevoir une commande IR"
parce que quand la télécommande envoi une commande au 1er dispositif, le 2nd dispositif la reçoit aussi
et pendant qu'il est occuper à essayer de comprendre cette commande (qui ne lui pas destiné) si il reçoit trop l'autre commande alors qu'il est encore occupé avec la précédente commande, alors il ignore cette seconde commande qui pourtant lui est bien destiné
blues93
réservé
blues93
PRESS_ACTION
PRESS ACTION
6 réglages possibles : 0, 1, 2, 3, 4 ou 5
• "Press Action" = Nb de Répétition du message IR tel que mémorisé dans la Telco
> message IR tel que mémorisé = xNb de Code IR de la Commande
> tel que mémorisé dans la Telco car le nb de code IR dans une Commande peut être > 1 (déjà "répété" d'origine)
> Format RAW = format Brut sans traitement ou analyse (tel que appris par la télécommande par Ex.)
parfois appelé aussi "format d'origine", en particulier dans l'univers Harmony
blues93
HOLD_PRESS
Message » 30 Juin 2012 1:26
NB : Le "Hold Press" des Harmony est inaccessible de l'Utilisateur
le seul moyen de le modifier est de passer par le SAV Logitech Harmony et d'un opérateur
HOLD PRESS = durée d'émission du signal IR
• "Hold Press" = Durée d'activité d'une touche = durée d'émission des signaux IR
La durée ainsi régler détermine la durée d'émission IR lors de l'appui sur une touche
L'envoi du signal IR (l'appui sur la touche) restera en action
suivant le délai correspondant à la valeurs choisie parmi les 6 possibles (de 0 à 5)
quand bien même on appuis même une fraction de seconde sur une touche
ou
que l'on reste le doigts sur la touche, l'envoi s’arrêtera suivant ce même paramètre
blues93
PRESS_ACTION & HOLD_PRESS INTIMEMENT LIÉS
Message » 30 Juin 2012 9:19
Ex. construit autour du fonctionnement la commande POWER TOGGLE
En effet, il peut arriver qu'il faille augmenter la valeur du "Press Action" pour que Power Toggle fonctionne avec certain Dispositif (cas d'école avec certaines séries de FreeBox)
Mais régler ce paramètre "Press Action" à une valeur Haute
peut entrainer le problème du changement double des chaînes après appui sur "Channel Next" et "Channel Prev."
ou du double numéro de chaînes après appui sur une des touches de Numéro de Chaine directe (0 à 9)
Pour compenser ce "Press Action" réglé Haut et qui doit le resté pour que POWER TOGGLE fonctionne
on doit revoir à la baisse le réglage du Hold Press C.Q.F.D
blues93
Message » 07 Juil 2012 8:32
NB : 3 derniers Posts MaJ
si besoin me faire un MP
Ne pas Poster ici SVP
blues93
Retourner vers Pilotage et Télécommandes
