Les LCR sont Des klipsh KL650
FREQUENCY RESPONSE: 48Hz-20kHz (+-)3dB
SENSITIVITY: 97dB @ 2.83 volts / 1 meter
POWER HANDLING: 150 w max continuous (600 w peak)
NOMINAL IMPEDANCE: 8 ohms compatible
TWEETER: 1" (2.5cm) magnetically shielded, titanium dome compression driver with 9.6oz ceramic magnet structure
HIGH FREQUENCY HORN: 10" x 6" rectangular 90(o) x 60(o) Tractrix(r) Horn
WOOFER: Two 6.5" (16.5cm) magnetically shielded, Cerametallic(tm) cone, cast aluminum frame drivers
CROSSOVER FREQUENCY: 1400Hz
ENCLOSURE MATERIAL: MDF
ENCLOSURE TYPE: Bass reflex via front-firing port
INPUT CONNECTIONS: 2 sets of binding post speaker terminals (connected via brass strap jumpers)
DIMENSIONS: 15" (38.1cm) H x 17" (43.2cm) W x 12.5" (31.8cm) D (w/ grille)
WEIGHT: 39 lbs. (17.7kg)
MOUNTING: 4-bolt pattern, 1/4"-20 thread
FINISHES: Galaxy Black cabinet with Black anodized aluminum fascia
BUILT FROM: 2004
