Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: 2612hz, aeric, alcine, Bedouille69-CX-Denon, boston, Bravvv, Brest29, Calimero2, CDE37, Charly Brown, Cool-Spot, dday34, dedelynks, djinn77, fsannier, FZ26, Google [Bot], GuiGou_013, guti95, ilopan, infobm, jp_78, Julrxl, Kael2966, laduche, lcdmen, lorenzo974, magicone, Marvel Wars, michael63, mister key, Nicko84, patychard, Philofil92, pkoka, pourpre, Psymon57, Remind, Rhteamc, stasio, stef44, ted59100 et 541 invités
CES 2015: LES ANNONCES SUR L'ULTRA HD POUR 2015
» 05 Jan 2015 19:45
Le CES ( Consumer Electronics Show ) est devenu le plus important salon consacré à l'innovation technologique en électronique grand public. Il se tient annuellement à Las Vegas au Nevada et il est organisé par la Consumer Electronics Association. Le salon se représentera du Mardi 6 au 10 janvier 2015.
CES 2015 : que nous réserve cette édition ? ( avec 01netTV )
4K / 60p High speed display in 60 frames per second of 4K video (3,840 x 2,160 pixels - Ultra HD), which has four times the resolution of Full Hi-vision, for highly detailed videos with extremely smooth movement.
10-bit gradation Previous Blu-ray Discs displayed the color signals (Y, Cb, Cr) in 8-bit gradation each (256 gradations). By expanding this to 10-bit gradation each (1,024 gradations), even minute signals can be faithfully reproduced to realize richly textured video.
High Dynamic Range A technology that drastically expands the brightness peak from the previous 100 nit to 1,000-10,000 nit, marking a significant leap in the dynamic range of the picture. Bright light sources (e.g. lights or rays of the sun) and reflected light (from metal or water) that up to now were difficult to display can now be shown in rich textures.
BT.2020 wide color gamut Compliant with the ITU-R BT.2020 wide color gamut signal formulated for 4K/8K broadcasting. Enables vividly rich coloration not previously possible on Blu-ray discs (BT.709 standard).
HEVC (H.265) / 100Mbps Support for the highest 100Mbps video signal using the latest high-efficiency video compression technology. Compression efficiency and high bit rate far beyond previous Blu-ray discs (MPEG-4/AVC (H.264), maximum 40Mbps) enabling outstanding playback of high quality video with 4K/60p/10bit, High Dynamic Range, BT.2020, etc.
D' une seule jusqu'à l'IFA 2014 inclus, Sharp passera à trois séries de téléviseurs Ultra HD en 2015. La gamme se déclinera ainsi :
Série UB30 : dalle Ultra HD, puce de traitement à quatre cœurs, Revelation Upscaler, prise en charge du streaming 4K avec les codecs HEVC et VP9 (de Google), plateforme connectée SmartCentral 3.0 héritée de la génération précédente, entrées HDMI 2.0 et HDCP 2.2. Disponible au moins aux Etats-Unis à la fin du printemps 2015 en 43, 50, 55 et 65 pouces, pour respectivement 750, 1000, 1200 et 2300 dollars HT. Série UE30 : idem plus fonctions AquoMotion 480 et AquoDimming, nouvelle plateforme connectée SmartCentral 4.0 reposant sur Android TV. Lancée au même moment en 60, 70 et 80 pouces, pour respectivement 2000, 2800 et 5400 dollars. Série UH30 : idem UE30 plus fonction AquoMotion 960, colorimétrie élargie Spectros et certification THX 4K. Même date en 70 et 80 pouces pour respectivement 3200 et 6000 dollars.
Je retiens surtout l'arrivée d'une entrée Display Port 1.2a (qui tordra le coup définitivement je pense aux entrée vga sur les TV) et l'arrivée de l'USB 3.0
Chaque constructeur de TV a choisi son camps au niveau de l'OS embarqué (Android TV, Firefox OS, WebOs)
En tout cas , chaque constructeur essaye d'améliorer son moteur d'upscalling et tente de parler de HDR. Dans les faits beaucoup d'annonces, reste à voir dans les prochains tests qui s'est réellement améliorer.... et qui vent du vent pour maintenir du soit-disant HDG.
hf206 a écrit:En tout cas , chaque constructeur essaye d'améliorer son moteur d'upscalling et tente de parler de HDR. Dans les faits beaucoup d'annonces, reste à voir dans les prochains tests qui s'est réellement améliorer.... et qui vent du vent pour maintenir du soit-disant HDG.
Pour nous vendre du vent, t'inquiète, il y a match nul
fab92
Inscription Forum: 27 Aoû 2007 21:22
Localisation: WGS84 : 48° 53' 14'' de latitude Nord et 02° 16' 03'' de longitude Est
