Modérateurs: Modération Forum Installations, Le CA de l’Association HCFR, Modération Forum DIY • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 38 invités
Le Bistrot des DIYers
Message » 27 Nov 2018 15:01
Bonjour Exact Agnostic1er ;) .
D'ailleurs j'extrais la phrase qui va bien :
At first glance, the port output seems to be 3 to 5 dB higher than the woofer output, which is a counter intuitive result. This is due to the diameter difference between the woofer and port. The port output can be scaled to the correct relative level by writing the summing equation in a different form:
pTOT = pWOOFER + DPORT/DWOOFER * PPORT [5]
For this example, the woofer effective diameter is 14 cm and the port diameter is 5.5 cm, which gives:
DPORT / DWOOFER = 5.5/14 = 0.39 = −8.1 dB [6]
The scaled version of the port response is also plotted in Figure 4a. Now you can see that it is more in line with the woofer level. Before leaving Figure 4a, there are two interesting points not directly related to near-field testing. First, the sharp dip in woofer response at 37.6 Hz indicates the tuning frequency of the vented enclosure. In general, this value is more accurate than one obtained from the impedance curve, since it is not corrupted by voice coil inductance.
Esscobar
Message » 27 Nov 2018 18:39
oui Cob Esscobar, je pensais surtout à " the sharp dip in woofer response at 37.6 Hz indicates the tuning frequency of the vented enclosure. In general, this value is more accurate than one obtained from the impedance curve, since it is not corrupted by voice coil inductance." :wink:
Agnostic1er
Superviseur Forum DIY
Message » 27 Nov 2018 18:46
Agnostic1er a écrit:oui Cob Esscobar, je pensais surtout à " the sharp dip in woofer response at 37.6 Hz indicates the tuning frequency of the vented enclosure. In general, this value is more accurate than one obtained from the impedance curve, since it is not corrupted by voice coil inductance." :wink:
:lol: :lol: :lol: :lol:
Je me marre doublement...
androuski
Message » 27 Nov 2018 18:57
c'est l'induction l'inductance qui te fait marrer hein!
:P
Agnostic1er
Message » 27 Nov 2018 20:58
oui oui c'est ça :lol:
androuski
Message » 27 Nov 2018 22:58
Et Esscobar… y se...marre? :mdr:
Agnostic1er
Message » 27 Nov 2018 23:52
Oui,
il s'éclate comme un ouf à bord du Bounty, là on commence à prendre les alizés, salut le pot au noir :lol:
androuski
Message » 28 Nov 2018 0:09
bande de nazes moussaillons! :mdr:
Agnostic1er
Message » 28 Nov 2018 21:58
Hello , comment on obtient -8.1 dB ?
"DPORT / DWOOFER = 5.5/14 = 0.39 = −8.1 dB [6]"
jot
Inscription Forum: 07 Mar 2011 13:14
Message » 28 Nov 2018 22:01
20*log(0,39)
sdf
Inscription Forum: 09 Jan 2003 16:22
Message » 28 Nov 2018 22:30
:thks:
jot
Message » 01 Déc 2018 22:10
Je viens de tester le Dayton NHP25Ti-4, meilleur que le 22taf sur tous les plans (THD et même directivité) :love:
ça donne envie de tester le ND25TA-4
speedbad
Pro-Fabricant
Pro-Fabricant
Inscription Forum: 13 Fév 2005 5:12
Message » 01 Déc 2018 22:34
speedbad a écrit:Je viens de tester le Dayton NHP25Ti-4, meilleur que le 22taf sur tous les plans (THD et même directivité) :love:
Des photos !
Kro
Message » 02 Déc 2018 16:55
25cm 98db eq identique
H2
H3
même en deux vois ça passe
speedbad
Pro-Fabricant
Pro-Fabricant
Message » 02 Déc 2018 19:45
superbes résultats !
Powerdoc
