Lyngdorf annonce ce jour le MP-40 !
Processeur 16 Canaux avec 1 sortie HDMI et 3 entrées.
12 canaux gérés en natif comme le MP-50 (contre 16 pour le MP-60).
Prix estimé : 10.000€
Disponibilité : Juin 2020
Specifications
Decoding: Dolby Atmos®, Dolby Digital, EX & Plus, Dolby TrueHD, DTS:X, DTS ES Discrete 6.1, DTS ES Matrix 6.1, DTS 96/24, DTS-HD High Res. Audio, DTS-HD Master Audio, AURO-3D®
Post processing options: Dolby Surround, AURO-MATIC®, DTS Neural:X
Audio inputs: 3 x HDMI (≤192kHz/24bit), 1 x HDMI eARC, 1 x AES/EBU S/P-DIF input (≤192kHz/24bit), 3 x S/P-DIF coaxial inputs (≤192kHz/24bit), 4 x S/P-DIF optical inputs (≤96Hz/24bit), 1 x USB audio input (≤192kHz/32bit), 1 x microphone input (XLR) for RoomPerfect
Audio outputs: 16 x XLR analog outputs (5.0 Vrms), 1 x SPDIF coax digital ZONE output (Fix 96kHz/24bit)
Audio specifications: Frequency response: ±0,5dB from 20 to 20,000 Hz, Total harmonic distortion: 0.005% max from 20 to 20,000 Hz
EQ: RoomPerfect™, Subwoofer level assistant, 32 x adjustable voicings holding ≤8 shelving, high/low pass or parametric filters with adjustable gain and Q
Media player: Internet radio (vTuner), Airplay, Spotify Connect, Roon Endpoint, DLNA Support of FAT32 based media storage
Video inputs: 3 x HDMI (2.0b – HDCP 2.2), accepts 3D 30Hz, 4K 60Hz (18 Gbps), accepts HDR, Dolby Vision and HLG
Video outputs: 1 x HDMI ((2.0b – HDCP 2.2 – eARC )
Control interfaces: 1 x DB9 RS232 connector, 2 x IR sensor inputs, 1 x IR output (loop from one of the sensor inputs), 1 x trigger input, 4 x trigger outputs, 1 x RJ45 ethernet LAN connector, 2 x USB A connectors, 1 x SD card slot , (Backup – storage for system software and settings)
Accessories included: RoomPerfect™ microphone, Microphone stand, Microphone cable, RF remote control
Placement options: Rack mount and freestanding
Dimensions (H x W x D): 14.0 x 45.0 x 35.9 cm 5.51 x 17.7 x 14.1 inches
Weight: 6.7 kg / 14.8 lbs
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: athoriac, daaadou, Eames, Gort'h, jean38, Mickaelmanon, titi040179 et 78 invités
Il s'agirait d'un 16 sorties avec processeur 12 canaux...comme le MP50
Autres infos ici : https://www.on-mag.fr/index.php/video-h ... -Mag.fr%29
- DTSman
- Contributeur HCFR 2022
Bien vu merci Nicolas
PP estimé : 10K€ ... pas mal mais assez limité côté entrées/sortie HDMI ...
- Danam
- Inscription Forum: 12 Fév 2002 2:00
Possibilité d'évolution HDMI2.1 comme annoncée sur le Marantz AV8805...
En terme de canaux processés cela en fait le remplaçant du MP50.
- DTSman
Oui mais attention à la limitation des ports HDMI ...
- Danam
Cela pousse, une fois de plus chez Lyngdorf, à l'utilisation d'un scaler externe surtout avec l'absence d'osd en surimpression.
- DTSman
Salut Olivier,j’ai vu cela juste avant et j’allais t’envoyer un message
10000€ plus un radiance pro,on a qqch de vraiment pas mal
Coco68 - Modérateur Home-Cinéma
- Inscription Forum: 30 Nov 2010 22:14
Dispo Juin 2020, trop tard pour moi
- Danam
Tu as opté pour quel pre-ampli ?
- DTSman
A priori il sera à 9450$ aux US ... le MP-50 étant à 9990$ ... ça va le mettre à 11-12K€ ici ... soit le même prix que le MP-50 ?
Bizarre comme positionnement, je le voyais bien à 10K€ moi attendons d'avoir le prix officiel en France.
- Danam
Je pense qu’il sera vers 10000€, sinon pas hyper compétitif vu le peu d’entrées /sorties hdmi.
Danam a écrit:Dispo Juin 2020, trop tard pour moi
Tu as des nouvelles de son arrivée ?
Nico je laisse le soin à Olivier de te répondre,moi je sais
Il m'a mis au parfum
- DTSman
Je trouve tout de même dommage qu’ils n’aient pas laissé la double vitre pleine hauteur.
Les 50/60 sont du fait plis jolis
Nico :
25 messages
