Type : Amplificateur Bloc Stéréo
Marque : McIntosh
Modèle et options : [/b ] MC 2105
[b]Prix de vente :
Département où la marchandise est visible : 75015
Montant des frais d'expédition : A définir
État de la marchandise : Excellent, appareil restauré par MusicHall Paris X
Première main : Non
Prix neuf :
Facture disponible : Oui et lettre de session
Date, pays et lieu d'achat : Mai 2010 Paris MusicHall
Numéro de série : par Mp
Description générale : Appareil en 220V
PERFORMANCE
POWER OUTPUT: 105 watts minimum sine wave continuous
average power output, per channel, both
channels operating into 4 ohms, 8 ohms,
or 1.6 ohms load impedance, which is:
20.5 volts RMS across 4 ohms
29.0 volts RMS across 8 ohms
41.0 volts RMS across 16 ohms
OUTPUT LOAD IMPEDANCE
4 ohms, 8 ohms, or 16 ohms; separate terminals
are provided for each output
RATED POWER BAND
20 Hz to 20,000 Hz
TOTAL HARMONIC DISTORTION
0.25% maximum harmonic distortion at
any power level from 250 milliwatts to 105
watts per channel from 20 Hz to 20,000
Hz, both channels operating
INTERMODULATION DISTORTION
0.25% if instantaneous peak power output is 210 watts
or less per channel with both channels operating for
any combination of frequencies 20 Hz to 20,000 Hz
FREQUENCY RESPONSE
20 Hz to 20,000 Hz +0 -0.25 dB
10 Hz to 100,000 Hz +0 -3.0 dB at one watt output
NOISE AND HUM
90 dB below rated output
OUTPUT POWER MONITOR METER
Meter is calibrated to read +3 dB when amplifier produces
105 watts. Meter range switch is provided to
increase meter sensitivity by 10 dB or 20 dB
Calibration accuracy at 0 dB reading is ±2% at all
frequencies; meter range accuracy is ±5%
9
OUTPUT VOLTAGES
25 volts for distribution lines
DAMPING FACTOR
13 at 8 ohms output
18 at 4 ohms output
10 at 16 ohms output
INPUT IMPEDANCE
200.00 ohms
INPUT SENSITIVITY
0.5 volt. Level control provided for higher input voltage
MECHANICAL INFORMATION
SIZE
Front panel measures 16 3/16 inches wide (41,12 cm)
by 7 1/8 inches high (18,1 cm). Chassis measures 15
inches wide (38,1 cm) by 6 9/16 inches high (16.67 cm)
by 14½ inches deep (36.83 cm), including connectors.
Knob clearance required is 1½ inches (3.81 cm) in
front of mounting panel
WEIGHT
65 pounds (29.48 kg) net, 77 pounds (34,93 kg) in shipping
carton
Site web du constructeur :
35 messages • Accèder à une page • 1, 2, 3
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: MAGISSON et 18 invités
[VENDU]McIntosh MC2105 220V:
- Bouquet de nerfs
- Inscription Forum: 29 Oct 2005 16:06
.. et tu n'auras donc plus besoin de ton meuble..
Oui, ton meuble, tu sais, nous en avons déjà parlés il y a longtemps.. tu ne le vends toujours pas ?
- Lohengrin
- Inscription Forum: 11 Juil 2002 14:30
UP et Baisse de prix
- Bouquet de nerfs
35 messages
• Page 1 sur 3 • 1, 2, 3
