Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: slyn et 18 invités
Parasound A23
Message » 27 Fév 2012 14:23
Type : Ampli stereo
Marque : Parasound
Modèle et options : Halo A23
Prix de vente : 600 €
Département où la marchandise est visible : 33
Montant des frais d'expédition : a voir
Etat de la marchandise : excellent peu servi
Facture conservée : oui
Date et lieu d'achat : 23/07/2004 en france
Numéro de série : marque derriere il faut que je regarde
Documentation conservée : oui
Description et commentaires :
Excellent etat tres peu servi
Pour le home cinema idealement couple au A52 pour du 7.1
Excellent pour de la hifi sans compromis
un post ou l'on en parle
view ... hlight=a23
A 23 Features:
Circuitry designed by legendary John Curl
Lucasfilm Home THX Ultra 2 certified
High bias Class A/AB operation
Balanced inputs with discrete circuits and XLR connectors
Direct Coupled - no capacitors or inductors in signal path
Complementary MOSFET driver stage and JFET input stage
12 beta-matched 15 amp, 60 MHz bipolar output transistors
1 kVA encapsulated toroid power transformer with independent secondary windings for each channel
48,000 µF power supply filter capacitance
DC Servo and relay protection circuits
AC present, channel status, high temperature displays
Gold-plated RCA input jacks, loop output jacks
Auto turn-on by 12v trigger or audio signal
Heavy-duty 24k gold-plated 5-way speaker binding posts
Rear mounted gain controls, ground lift switch
2u Chassis, carry handles, rack mounting adapter available
Parasound’s 10 years parts, 5 years labor warranty
A 23 Specs:
Continuous power output:
125 watts RMS x 2, 20 Hz - 20 kHz, 8W, both channels driven
200 watts RMS x 2, 20 Hz - 20 kHz, 4W, both channels driven
400 watts RMS x 1, 20 Hz - 20 kHz, 8W
Current capacity: 45 amperes peak per channel
Power bandwidth: 5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total harmonic distortion: < 0.06 % at full power
IM distortion: < 0.04 %
Slew rate: >130 V/µsecond
Dynamic headroom: > 1.5 dB
Interchannel crosstalk: > 80 dB at 1 kHz; > 63 dB at 20 kHz
Input sensitivity: 1 V for 28.28 V, THX Reference Level
Input impedance: 33 kW
S/N ratio: > 112 dB, input shorted, IHF A-weighted
Damping factor: > 800 at 20 Hz
Voltage: Switchable for 110V – 120V or 220V – 240V operation
Dimensions: 17-1/4" w x 4-1/8" h x 13-1/4" d, 3-5/8" h without feet
Net weight: 28 lbs.
franky33480
Inscription Forum: 26 Aoû 2008 15:44
Message » 27 Fév 2012 14:33
j'ai le même et c'est vrai qu'il marche excellemment bien ce petit bloc, je me demandais si je n'allais pas me prendre un emotiva XPA-5 pour faire du 5.1, mais prendre celui-ci pour faire du 4.1, ce ne serait peut-être pas si mal!! :grad:
je vais réfléchir mais faut pas que je traine!! :oops:
aldiallo
Inscription Forum: 25 Fév 2002 2:00
Message » 27 Fév 2012 15:10
nettement au dessus d'un emotiva
bobim
Message » 27 Fév 2012 15:22
bobim a écrit:nettement au dessus d'un emotiva
Bobim, tu m'aides pas là!! :ane:
aldiallo
Message » 27 Fév 2012 15:25
Je confirme l'émotiva ne tient pas la route :ko:
farniente77
Inscription Forum: 15 Déc 2005 12:17
Message » 27 Fév 2012 15:29
farniente77 a écrit:Je confirme l'émotiva ne tient pas la route :ko:
Salut David!
Comment va? t'en est ou avec les Hollandais et le parasound??
bon arrete de polluer le topic, j'ai envoyé un MP à Francky! :zen:
aldiallo
Message » 27 Fév 2012 15:51
pour la quantité (poids, watts...), choisir Emotiva
pour la qualité, acheter cet ampli et laisser les Emotiva aux autres
contactes le Al car ça reste rarement longtemps
bobim
Message » 27 Fév 2012 15:57
mais je lui ai déjà envoyé un mp moi!! :wink:
aldiallo
Message » 28 Fév 2012 10:44
Reservé en attente du paiement pour vendredi par un connaisseur parasound apparement :D
franky33480
Message » 02 Mar 2012 15:09
Vendu!! :grad: 8)
aldiallo
