Type : Amplificateur home cinéma
[b]Marque : Jungson
[b]Modèle et options : AV 1000 C
[b]Prix de vente : 250 euros
[b]Département où la marchandise est visible : Belgique, Musson (Frontière belge/Luxembourg/France)
[b]Possibilité d'expédition : Heuuu 50 kgs...
[b]Montant des frais d'expédition :
État de la marchandise : Voir ci-dessosu
[b]Première main : non
[b]Prix neuf : +/- 2000 euros
[b]Facture disponible : non
[b]Date et lieu d'achat : Ebay il y a un an
[b]Garantie et date d'expiration : non
[b]Numéro de série :
Emballage d'origine conservé : oui, palette et boîte en bois
[b]Documentations conservées :
Description générale :Specification
6.1 Channel Movie Mode
Left and Right Channel Output: 2*80w(1khz 8ohms)
Frequency Response: 20Hz-20KHz(1.5dB)
THD: 0.066%(1kHz)
Center Channel Output: 2*80w(1KHz 8ohms)
THD: 0.3%(1kHz)
Surround Channel Output: 2*80W(1Khz 8ohms)
THD: 0.3%(1kHz)
2 Channel Hi Fi Mode
Left and Right Channel Output: 2*80w(1Khz 8ohms)
THD: 0.066%(1kHz)
S/N: 85dB(A)
Input Impedance: 4-16kohms
Output Impedance: 4-16kohms
Bass/Treble Adjustment: 10dB
General Specifications
Voltage: AC220v-240V
Net Weight: 44kg
Dimensions: 400*525*270mm
Jungson AV-1000C Class-A, 6.1 Channel Digital Theatre Power Amplifier
Power Output: 6*80W(1kHz, 8ohms) of Class-A power output for each of the six channels.
Weight: 46 kg
Built-in powerful decoding functions on DOLBY PROLOGICA, DOLBY DIGITAL, EX6.1, DTS and PCM formats
Built-in microcomputer control system enables easy function selections by a "Single-Button-Control" switch on the front panel, or a remote control distance from the system.
Audio/Video inputs:3 RCA, 1 optical, 2 coaxial, and a set of 5.1 channels inputs, DVD-audio capability.
Fully Auto protection function: As soon as a short-circuits occurs from any speaker connections, the system protect function will be immediately activated to shut down the system, and "PROTECTION" will appear on the display. After removing the short-circuit and turn on the power again, the system will automatically return to normal operation.
Auto volume level memory function: After turning off the system, the operating volume level can be automatically stored if the level is within 1-45 range. If the previous operating level is over 45, the system will automatically adjust to the level of 45, when the system is turn on again.
Stunning ocean blue power dynamic display, elegant aluminum alloy front panel in shining silver colour, and stylish steel case with heat-sink function.
[b]Site web du constructeur : http://www.jungson.com/
[b]Commentaires : Heureux proprio d'un Jungson AV 895, je voulais m'offrir le haut de gamme de la marque, le Jungson AV 100.
Je l'ai acheté sur Ebay en Angleterre pour 1200 euros, hélas il y a quelques problèmes.
Chez moi, en écoute HC, après quelque temps d'écoute, l'ampli se coupe et je dois rebrancher l'ancien ampli. Je l'ai prêté à des amis qui l'on eu chez eu sans ce problème... Est-ce que mes enceinte DIY Bullets (sur les 5 voies) posent un problème? J'en sais rien.
L'autre soucis, c'est que lorsqu'il est allumé mais qu'aucune source n'est active, à la fin d'un cd par exemple, il émet des petit clacs dans les HP, rien de dangereux pour ceux-ci mais désagréable à l'oreille.
Autrement, il fonctionne parfaitement en stéréo.
Voilà, si quelqu'un veut un ampli pure classe A en 6x80W pour la stéréo à un bon prix.
Essais possibles bien sûr
[b]Liens divers : http://www.homecinema-fr.com/forum/viewtopic.php?t=29744491
[b]Photos :
5 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Bucci et 8 invités
Jungson AV1000C (vendu)
- Fichiers joints
- AV1000.jpg (38.46 Kio) Vu 1886 fois
Peut-on dresser un mur pour ensuite lui apprendre un tour de cirque? Sttellla
- Pascal H
- Inscription Forum: 04 Nov 2003 12:56
Suite aux nombreuses demandes, j'ajoute quelque photos faites ce matin.
Elles sont faites au flash, c'est pas toujours top...
Il y a la télécommande en alu massif et bois, une housse et une paire de gants que j'ai jamais mise
- Pascal H
Argh, j'ai le même sans les décodeurs (AV1000D).
c'est curieux cet arrêt de fonctionnement, mes enceintes BC acoustiques Niger qui mettaient en sécurité mon ampli Atoll, n'ont jamais mises à genoux le jungson.
Et pourtant il a marché longtemps à des volumes déraisonnables sur 2 et 5 canaux.
Pour le clac dans les HP, le mien en fait uniquement quand on l'éteind et que le volume n'est pas au minimun.
mais ce que tu décris n'a pas l'air d'être ça...
C'est bête que tu es si loin aurait pu faire un comparatif.
Modifié : c'est booooo.
bc-manu - Membre HCFR
- Inscription Forum: 14 Nov 2003 14:26
Réservé à Ptisik qui était le premier à m'envoyer un MP.
- Pascal H
Vendu, on peut fermer
- Pascal H
5 messages
