Type : Paire de câbles d'enceintes haut de gamme
Marque : TRANSPARENT CABLES
Model et options : AUDIO PLUS BICABLE
Prix de vente : VENDUS.
Département où la marchandise est visible : 13100 Aix en Provence
Montant des frais d'expédition : Offerts
État de la marchandise : Très bon état, seul un manchon à l'extrémité ampli a du être regainé (voir photo), sans aucune incidence sur les qualités techniques du câble.
Prix neuf : 1300 euros
Facture disponible : Non
Documentations conservées : Oui (1 page...)
Description générale : Une paire de câbles d'enceintes HDG Transparent Audio Plus Bicâble (uniquement utilisable pour le bicâblage passif) de 2,4 mètres, terminaisons fourches côté ampli et enceintes. Génération XL. Idéal pour tirer le maximum de vos enceintes acceptant le bicâblage.
Site web du constructeur : http://www.transparentcable.com/index2.html
Commentaires : "If you want the performance of Transparent Plus cable, but your speakers have been designed to benefit from biwiring, this cable will help to bring out their best. Plus Bicable incorporates double tails on the speaker end so that both the treble and the bass binding posts receive the signal directly from the cable. It provides a far better-sounding connection than the brass jumper-plates that come with most biwire speakers. As you go up the scale of performance within Transparent's range, each increase in level means higher quality parts, more exacting placement of the components in the network, and more testing during assembly. As a result, Transparent Plus Bicable has heftier cable construction and networks that transfer bass frequencies more accurately and reject more noise than others.
Transparent's exclusive BiCable design is the ultimate application of our Plus speaker cable. This high performance version will deliver more current and exert more control over full range biwirable speakers than standard cables. Each channel consists of 2 separate cables, each with its own network, but covered by a single outer jacket. Each half of the speaker system "sees" its own signal, direct from the amplifier ... yet the visual result in your music room is clean and simple."
8 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 43 invités
et bien, ca c'est du cable HP, a trés bon prix, dommage qu'en ce moment ce ne soit pas ma priorité pour un tel budget, peut être dans un an , aprés avoir changer mon projo, acheter une toile fixe, un lecteur cd...... Aprés je suis a toi..............
Aller trés bonne vente pour ce super cable, je ne connais pas sa sonnorité, mais ca doit vraiement être bon, sinon quel type de sonorité en ressorte de ces cables, ca poura surement aider les futurs acquéreur..............
- steevedul
- Inscription Forum: 14 Nov 2003 22:32
transparent
Un prêt pour une écoute est il envisageable ?
Arn
Arn
- arn
- Inscription Forum: 11 Fév 2004 23:32
arn a écrit:Un prêt pour une écoute est il envisageable ?
Si la personne se trouvait dans le 13, pourquoi pas, mais s'il faut les expédier, attendre qu'ils aient été écoutés, puis renvoyés, ça fait minimum une semaine et 20 euros de perdus à chaque fois, largement suffisant pour rater une vente ferme...
Je ne sais guère parler de ces choses là, mais je dirais que c'est le câble d'enceintes qui a le plus apporté à mon ex-système, et dieu sait que j'en ai testé ! Elargissement de la scène sonore, adoucissement des aigus et bluffante "humanisation" des mediums, des voix. Ce serait mentir de dire qu'il est neutre et que c'est un câble qui ne s'entend pas : si, il s'entend autant que n'importe quel autre maillon d'une chaine hifi !
- Gilor
- Inscription Forum: 20 Aoû 2000 2:00
Allez up !
- Gilor
Et re-up...
- Gilor
Transparent
Gilor a écrit:Et re-up...
Tjs pas de prêt envisageable
Arn
- arn
VENDUS, on ferme !
- Gilor
8 messages
