Type : Ampli casque/DAC
Marque : SOEKRIS
Modèle et options : 1541
Prix de vente : 500 €
Département où la marchandise est visible : 93
Montant des frais d'expédition : 20 €
État de la marchandise : BON
Première main : NON
Prix neuf :
Facture disponible : NON
Date, pays et lieu d'achat : INCONNU
Garantie et date d'expiration : INCONNU
Numéro de série :
Documentations conservées : NON
Celle du constructeur - "The Soekris dac1541 is a fully balanced Audiophile discrete R-2R DAC, with USB and SPDIF inputs and outputs to either the built in headphones amplifier on a front mounted XLR or 6.3mm Jack, or to line level outputs on rear mounted XLR and RCA Phono connectors. The dac1541 is not just any regular DAC, the sound quality is the absolute best available, thanks to the ultra high end design with a discrete R-2R sign magnitude DAC using a total of over 400 small and very precise resistors, discrete headphones amplifiers with zero negative feedback, delivering high power to almost any headphones, all powered by high reliability switch mode power supplies with 6 discrete linear low noise and low impedance power regulators and 3 low noise regulators for the digital parts.
The dac1541 R-2R DAC circuit is fully isolated from the noisy computer USB interface and the SPDIF inputs are also all transformer isolated. It supports input signals on the USB interface up to 24 bit / 384 Khz PCM audio, and up to DoP-128 (x2) and DSD-256 (x4) audio, or up to 24 bit / 192 Khz PCM audio on the various SPDIF interfaces. It has a fully digital volume control and four sets of digital anti-aliasing filters to fit any taste, and have a flexible crossfeed circuit for the headphones. The dac1541 is designed and built in Denmark, using advanced surface mount technology and parts from only the highest quality suppliers, with a full aluminum casing."
Site web du constructeur : http://www.soekris.dk/dac1541.html
Ce matériel appartenait à un membre de HCFR qui nous a quitté et j'effectue cette vente au bénéfice de ses enfants.
Il n'y a pas de câbles fournis.
Philippe possédait deux modèles identiques, ce qui fait que c'est ma deuxième annonce pour le même produit.
5 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 11 invités
Petites annonces pour Casques (filaire, sans fils) et Oreillettes.
DAC AMPLI CASQUE SOEKRIS 1541
La musique avant tout.
renecito - Contributeur HCFR & Modérateur HiFi et Univers Casques
- Inscription Forum: 28 Juin 2011 14:42
Up
Nono - Membre HCFR
up
Nono - Membre HCFR
5 messages
