Marque : Onkyo
Modèle et options : PR-SC886
Prix de vente : 800 Euros
Département où la marchandise est visible : Belgique
Montant des frais d'expédition : A déterminer
État de la marchandise : Très Bon
Première main : Non, acheté à nos65 sur ce forum
Prix neuf : 2000 euros
Facture disponible : non
Numéro de série : sera communiqué si nécessaire
Documentations conservées : Oui + link: http://63.148.251.135/redirect_service. ... En_web.pdf
Ce préampli est remplacé dans mon installation par un 5508.
THX® Ultra2 Plus™ Certified 7.1-Channel A/V Controller
Pre-Processing for High-Definition Media and Precise Calibration for Any Home Theatre Installation
The PR-SC886 delivers state-of-the-art features and performance for the most technically sophisticated home theatres. Designed to connect to high-end amplifiers, this A/V controller includes full high-definition processing capability over HDMI™, comprehensive 1080pupscaling of video sources with HQV Reon-VX, and a wide array of connection options. It’s also the first A/V controller to feature built-in ISF (Image Science Foundation) video calibration alongside Onkyo’s RIHD (Remote Interactive over HDMI) system integration and control protocol.The PR-SC886 supports multi-room set-ups, including the option of component and composite video outputs in the second zone and subwoofer pre outs for the second and third zones.
AMPLIFIER:
# Channels 7
THX Certified (Ultra2 Plus)
S/N Ratio (LINE IN) 110dB
All Discrete Circuitry
Absolute Ground Plate
Toroidal Transformer
Independent Power Supply 4
Linear Optimum Gain Volume
Non-Scaling Configuration
Bi-amp Capability For Front
PROCESSING:
DOLBY Decoder DD Plus, TrueHD
DTS Decoder DTS-HD Master Audio
Neural Surround Neural THX
THX Processing Mode
DSD Processing/Direct Mode
192K/24 Bit DACs Burr Brown
VLSC (ALL CH)
DSP Type / QTY 32 BIT / 3
Adjustable Crossover (Hz) 40/45/50/55/60/70/80/90/100/110/120/130/150/200
Adjustable Crossover by Channel Pair
Accurate Speaker Distance Setting 0.2ft step
AV Sync Delay (by source) 250ms
Multi-Band Speaker EQ 15 Band
CONNECTIVITY:
Audio I/O 9 / 2
Balanced Audio Output (7.1ch)
Balanced Audio Input (2ch, assignable)
Phono Input
Digital Audio IN (OPT/COAX) 3 / 3
Digital Audio OUT (OPT/COAX) 1 / 0
Composite I/O 6 / 1
S-Video I/O 6 / 1
Front-Panel A/V
Front-Panel Optical
Component Video / Bandwidth 3 / 100MHz
HDMI I/O 4 / 2
HDMI Version V1.3a Repeater
HDMI Bandwidth 1080p
HDMI Deep Color Capable (36bit)
Component Video Upconversion
Analog To HDMI UpConversion
480i to 480p Processing (HQV Reon)
1080p Upscaling (HQV Reon)
Noise Shaped Video (NSV)
Multi-Channel Input 7.1
Pre-Outs 7.1
Zone 2 Fixed/Variable line Out
Zone 2 Fixed/Variable Subwoofer Out
Zone 2 Tone/Balance Control
Zone 2 Max/Power On Volume
Zone 2 Composite Video Out
Zone 2 HD Component Video Out
Zone 3 Fixed/Variable line Out
Zone 3 Max/Power On Volume
Zone 3 Fixed/Variable Subwoofer Out
HDMI / Component video assignable to Tape/CD/Phono
iPod Ready (DS-A2)
Radio Data System (RDS)
Built-in HD Radio Tuner
Simultaneous Access to Multiple Tuner Bands (Z1, Z2, Z3)
INTEGRATION ACCESS:
RS-232
IR Input/Output 2/1
Ethernet (E-control, AMX Duet)
RI System Control
12V Trigger (w/adjustable delay)
Assignable (x3)
MISC.
Pre-Pro/Learning Remote
Back-Lit Remote
GUI for Setup Menu (advanced)
Input Name Edit
Setup Store/Recall function
Permanent Memory Storage
Solid Aluminum Front
Detachable AC Cord
Rack Mount Kit Available IRK-175-4A
