NonoM45 a écrit:Salut _Guillaume
_Guillaume a écrit:Pourquoi donc ? Y’a pas la notice dans la boite ?
Non et pour moi c'est normal aujourd'hui, il y a un QR code à la place
Mais ça mène vers une notice en anglais ou chinois et comme je ne suis pas bilingue ou trilingue
De plus rien n'est indiqué quant au branchement du DMP-A6 au AMP-F2
Page 7 du manuel du DMP-A6 Gen. 2 : ⑬ Trigger output: Connects a power amplifi er to enable power-on/off synchronization. The output is 12V when powered on and 0V when powered off.
Page 3 du manuel du AMP-F2 : ⑨ Trigger input (can be linked to the previous stage with trigger function)
Et page 6 : AMP-F2 can be turned on/standby through the front panel power on/off button, it can also be
turned on/standby automatically by the trigger cable.
When the TRIGGER IN jack is connected to a device equipped with a TRIGGER OUT jack, the power
on/standby of the unit can be controlled through the linkage operation of the upstream connected
device.
When the TRIGGER OUT jack is connected to a device equipped with a TRIGGER IN jack, the power
on/standby of the downstream connected device can be controlled through the linked operation of
this unit.
TRIGGER IN/OUT jack Inputs/outputs electrical signals are up to 12V DC/150mA.
In TRIGGER mode, the front panel power on/off button will be disabled and the on/off will be
controlled by Trigger.
