dr rotule a écrit:Porciprince v1 (cible Harman-Wisdom)
Enfin ... Quand je dis v1, c'est v1 avec RCH ...Roulette pour voir tout
- Code: Tout sélectionner
ROOM CORRECTION HELPER - 18/06/2025 15:10:06
BASIC SETTINGS
Loaded File: - Denon_AVC-X3700H_16-06-2025_19-21-55.ady
Target Curve: -PorciprinceHarman-Wisdom(1695Hz)finale-
Target Level: 71.93 dB
Average Method: Magn plus phase average
AVR INFORMATION
Model: Denon AVC-X3700H
MultEQ Type: XT32
Has Cirrus Logic DSP: No
Speed of Sound: 300 m/s
SPEAKER SETTINGS
Smoothing Method: 1/3
Windowing: Optimized MTW
Individual Max Boost: 3 dB
Overall Max Boost: 3 dB
SUBWOOFER SETTINGS
Number of Subs: 2
Revert LFE Filter Freq: None
Additional Bass Gain: 3 dB
Max Boost Individual: 6 dB
Max Boost Overall: 3 dB
Align Frequency: 80 Hz
Selected Speaker: 6: SLAavg
LPF for LFE: 120 Hz
Subwoofer Output: LFE
DYNAMIC SETTINGS
Dynamic EQ: Disabled
Dynamic Volume: Disabled
LF Containment: Disabled
VERSION INFORMATION
REW Version: 5.40 Beta 89 API 0.8.4
RCH Version: 1.1.9
| Measurement | Channel | Distance | SPL Offset | Crossover Frequency | Inverted |
| 1: Cavg | C | 4.34 | 0.5 | 0 | |
| 2: FLavg | FL | 4.38 | 2.5 | 0 | |
| 3: FRavg | FR | 4.39 | 1.0 | 0 | |
| 4: SBLavg | SBL | 2.85 | 1.0 | 0 | |
| 5: SBRavg | SBR | 2.64 | 1.0 | 0 | |
| 6: SLAavg | SLA | 2.17 | -1.5 | 80 | |
| 7: SRAavg | SRA | 2.21 | -1.5 | 80 | |
| 8: SW1avg | SW1 | 6.82 | -1.5 | 0 | |
| 9: SW2avg | SW2 | 7.35 | -1.0 | 0 | |
| 10: TFLavg | TFL | 2.54 | 3.5 | 150 | Yes |
| 11: TFRavg | TFR | 2.52 | 1.0 | 150 | Yes |
| 12: TRLavg | TRL | 2.25 | 1.5 | 150 | Yes |
| 13: TRRavg | TRR | 2.24 | -2.5 | 150 | |
Fichier OCA : https://drive.google.com/file/d/1DJcu13 ... sp=sharing
Fichier nfo : https://drive.google.com/file/d/1EPHnrw ... sp=sharing
Courbe cible Harman-Wisdom : https://drive.google.com/file/d/1_SZh3B ... sp=sharing
Teste ça et dis-nous ...
Attention : interdit d'aller dans le menu SPEAKERS du Denon !
(Ca risque de péter les réglages)
Ensuite, tu sors l'Umik, et tu fais une série de mesures :
- Toutes enceintes avec subs éteints
- 4 subs LFE (ensemble, une seule courbe)
- 4 subs BM (ensemble, une seule courbe) via enceinte SLA (éteinte) 80Hz
- 4 subs BM (ensemble, une seule courbe) via enceinte TFL (éteinte) en mode ficher 150 Hz.
Et voici :
https://drive.google.com/file/d/1iognmq ... sp=sharing
