Modérateurs: Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: dr rotule et 70 invités
Laboratoire HC du Prince en sous sol 22m² : Config. 7.4.4
Message » 18 Juin 2025 21:01
dr rotule a écrit:Porciprince v1 (cible Harman-Wisdom)
Enfin ... Quand je dis v1, c'est v1 avec RCH ...
Code: Tout sélectionner
  ROOM CORRECTION HELPER - 18/06/2025 15:10:06
BASIC SETTINGS
Loaded File:       - Denon_AVC-X3700H_16-06-2025_19-21-55.ady
Target Curve:      -PorciprinceHarman-Wisdom(1695Hz)finale-
Target Level:      71.93 dB
Average Method:    Magn plus phase average
AVR INFORMATION
Model:                    Denon AVC-X3700H
MultEQ Type:              XT32
Has Cirrus Logic DSP:     No
Speed of Sound:           300 m/s
SPEAKER SETTINGS
Smoothing Method:         1/3
Windowing:                Optimized MTW
Individual Max Boost:     3 dB
Overall Max Boost:        3 dB
SUBWOOFER SETTINGS
Number of Subs:           2
Revert LFE Filter Freq:   None
Additional Bass Gain:     3 dB
Max Boost Individual:     6 dB
Max Boost Overall:        3 dB
Align Frequency:          80 Hz
Selected Speaker:         6: SLAavg
LPF for LFE:              120 Hz
Subwoofer Output:         LFE
DYNAMIC SETTINGS
Dynamic EQ:        Disabled
Dynamic Volume:    Disabled
LF Containment:    Disabled
VERSION INFORMATION
REW Version:       5.40 Beta 89 API 0.8.4
RCH Version:       1.1.9
| Measurement            | Channel       | Distance | SPL Offset  | Crossover Frequency | Inverted |
| 1: Cavg                | C             |     4.34 |         0.5 |                   0 |          |
| 2: FLavg               | FL            |     4.38 |         2.5 |                   0 |          |
| 3: FRavg               | FR            |     4.39 |         1.0 |                   0 |          |
| 4: SBLavg              | SBL           |     2.85 |         1.0 |                   0 |          |
| 5: SBRavg              | SBR           |     2.64 |         1.0 |                   0 |          |
| 6: SLAavg              | SLA           |     2.17 |        -1.5 |                  80 |          |
| 7: SRAavg              | SRA           |     2.21 |        -1.5 |                  80 |          |
| 8: SW1avg              | SW1           |     6.82 |        -1.5 |                   0 |          |
| 9: SW2avg              | SW2           |     7.35 |        -1.0 |                   0 |          |
| 10: TFLavg             | TFL           |     2.54 |         3.5 |                 150 | Yes      |
| 11: TFRavg             | TFR           |     2.52 |         1.0 |                 150 | Yes      |
| 12: TRLavg             | TRL           |     2.25 |         1.5 |                 150 | Yes      |
| 13: TRRavg             | TRR           |     2.24 |        -2.5 |                 150 |          |
Roulette pour voir tout
Fichier OCA : https://drive.google.com/file/d/1DJcu13 ... sp=sharing
Fichier nfo : https://drive.google.com/file/d/1EPHnrw ... sp=sharing
Courbe cible Harman-Wisdom : https://drive.google.com/file/d/1_SZh3B ... sp=sharing
Teste ça et dis-nous ...
Attention : interdit d'aller dans le menu SPEAKERS du Denon !
(Ca risque de péter les réglages)
Ensuite, tu sors l'Umik, et tu fais une série de mesures :
- Toutes enceintes avec subs éteints
- 4 subs LFE (ensemble, une seule courbe)
- 4 subs BM (ensemble, une seule courbe) via enceinte SLA (éteinte) 80Hz
- 4 subs BM (ensemble, une seule courbe) via enceinte TFL (éteinte) en mode ficher 150 Hz.
Et voici :
https://drive.google.com/file/d/1iognmq ... sp=sharing
porciprince
Inscription Forum: 09 Juin 2021 15:44
Message » 18 Juin 2025 21:31
Intéressant. Je dois discuter avec Jaoued ...
J'ai deux enceintes que j'avais montées pour égaliser, et qui ne sont pas redescendues.
Et la mise en phase des subs ne me satisfait pas. Ils sont en avance de 7 ms.
Et la réponse dans le grave des SBL SBR a comme un bug.
Et j'ai un doute sur le niveau des subs ...
Je dirais : N'écoute pas.
dr rotule
Contributeur HCFR 2024
Message » 18 Juin 2025 21:44
Cest bien noté. La courbe des 4 subs est sympa :bravo:
porciprince
Message » 20 Juin 2025 12:59
Porciprince v2 (hybride RCH - MultEQ-X)
C'est une version rapidement adaptée avec les filtres RCH (+ HPF pour les subs). Je ne suis pas trop sûr des distances (à cause du son à 300m/s), ni des gains ...
Dans MultEQ-X, on va utiliser le profil REFERENCE, dans la banque de ton choix (1 ou 2).
1/ Tu démarres MultEQ-X, et tu charges le fichier vide que nous avons déjà utilisé.
2/ Onglet 4. Design Target Curve :
- Cocher en haut la case Individual Channels
- Disable Auto-Levelling sur toutes enceintes et subs
- SubEQ HT: Cutoff Mode Disabled
- Enceintes: Cutoff Mode Auto
3/ Fichiers filtres : https://drive.google.com/drive/folders/ ... sp=sharing
4/ Charger les filtres de chaque enceinte avec l'outil Import Target (ne pas oublier de cocher Reference et le nom de l'enceinte dans la colonne de gauche)
5/ Onglet 5. Filter Settings : Sub EQ HT Low Freq EQ Limit Manual 10Hz
6/ Onglet 6. Calibration Settings :
| 1: FLavg               | FL            |     4.38 |         9.3 |                   0 |          |
| 2: FRavg               | FR            |     4.39 |         7.9 |                   0 |          |
| 3: Cavg                | C             |     4.34 |         7.8 |                   0 |          |
| 4: SLAavg              | SLA           |     2.17 |         3.8 |                  80 |          |
| 5: SRAavg              | SRA           |     2.21 |         6.5 |                  80 |          |
| 6: SBLavg              | SBL           |     2.85 |         7.2 |                   0 |          |
| 7: SBRavg              | SBR           |     2.64 |         5.1 |                   0 |          |
| 8: TFLavg              | TFL           |     2.54 |         9.4 |                 150 |          |
| 9: TFRavg              | TFR           |     2.52 |         8.1 |                 150 |          |
| 10: TRLavg             | TRL           |     2.25 |         8.6 |                 150 |          |
| 11: TRRavg             | TRR           |     2.24 |         5.2 |                 150 | Yes      |
| 12: SW1avg             | SW1           |     4.87 |         3.9 |                   0 |          |
| 13: SW2avg             | SW2           |     5.40 |         4.4 |                   0 |          |
Roulette pour voir le bas
7/ Générer le MQX et le charger dans le Denon.
8/ Régler le LPF du LFE à 150 Hz avec la télécommande ou l'interface web.
Ensuite, tu me fais une série de mesures (les mêmes qu'hier).
On peaufinera les gains et délais.
Le but étant que tu regardes un film aujourd'hui :lol:
dr rotule
Message » 20 Juin 2025 13:10
OOOOOhhh ooouuiii!! :bravo: :bravo: :bravo:
Je te fais cela, merci Doc!
porciprince
Message » 20 Juin 2025 13:39
Sur Audyssey, les SLA et SRA sont en lien avec les SBL et SBR.
Pour le dire autrement, soit en LARGE les 4, soit en SMALL les 4.
Si je mets les 4 en SMALL, SLA et SRA à 80Hz et SBL et SBR je coupe au plus pas qu'Audyssey le permet c'est jouable ? Soit 40Hz.
porciprince
Message » 20 Juin 2025 13:47
Et nous sommes d'accord que dans l'onglet 3 "MESURE", je mets tout sur "exclude position" ?
Le fichier est prêt, j'attends juste ton feu vert pour le balancer dans le Denon :bravo:
porciprince
Message » 20 Juin 2025 13:59
Charge le fichier.
N'oublie pas de régler le LPF du LFE à 150 Hz
Partage le MQX stp.
dr rotule
Message » 20 Juin 2025 14:04
porciprince a écrit:Et nous sommes d'accord que dans l'onglet 3 "MESURE", je mets tout sur "exclude position" ?
OUI
dr rotule
Message » 20 Juin 2025 14:06
porciprince a écrit:Sur Audyssey, les SLA et SRA sont en lien avec les SBL et SBR.
Oui, je viens de découvrir ça :o
On ne peut pas mettre les SB en LARGE et le S en small. Mais on peut faire le contraire :lol:
Règle les SBL SBR à 150 Hz.
Elle sont bien sous 70 Hz, mais entre 70 et 140 Hz, elles ont un énorme trou.
dr rotule
Message » 20 Juin 2025 14:20
voici le MQX : https://drive.google.com/file/d/1gk24vQ ... sp=sharing
Si c'est ok pour toi j'attaque les mesures :bravo:
porciprince
Message » 20 Juin 2025 14:50
Vas-y.
dr rotule
Message » 20 Juin 2025 15:20
porciprince
Message » 20 Juin 2025 15:32
c'est toujours chaud ici ..... :o :o
pereti
Inscription Forum: 03 Oct 2017 14:45
Message » 20 Juin 2025 16:06
Ca ne chôme pas on va dire! Dernière ligne droite logiquement :mdr: :mdr: :mdr:
porciprince
