bonjour,
Cary Audio sort un nouveau lecteur CD / HDCD /SACD avec des entrées numériques pour utlisation de son DAC interne via d'autres sources numériques.
et il semble que ce lecteur ait également une entrée numérique qui accepte en entrée du 24 / 192 ! (sur de l'USB, c'est à ma connaissance un des 1ers)
qu'en pensez vous ?
qques infos :
Features:
The CD 303T SACD is a vacuum tube/solid state selectable SACD player. Plays Redbook CDs and upsamples at 44.1, 96, 192, 384, 512, and 768kHz. Internal clocking of 22.5792 MHz in SACD processing mode. In vacuum tube mode, the analog output section utilizes four 12AU7 vacuum tubes as the audio gain stage as well as the output buffer. Can be used as a standalone DAC with switchable inputs for USB (24 bit 192 kHz), RCA, and Toslink. Eight ( PCM1792u DAC chips running in parallel pairs. The output vacuum tubes have a removable panel above them for tube exchange or ‘tube rolling’ without opening the chassis.
Additional features of this player include adjustable metal cone feet, and vacuum tube and solid state output sections that can be changed through the remote or by a button on the front panel. Other enhancements include a dimmer light control for the display, C-core power transformer, fully regulated power supplies, RS 232 port control for custom installation systems, and HDCD decoding with Cary DSP-300 digital filter. Available with silver or black anodized aluminum front panel.
The CD 303T SACD Professional Version features both tube and solid state output. It has 3 digital inputs including USB accepting 24bit/192kHz signals from your computer.
For even greater resolution when playing back SACD’s, the internal wordclock frequency is set to 22.5792 MHz. Completing the list is an aluminum loader tray that adds elegance and greater disc handling care. This version continues on with 8 Burr Brown 1792u DAC chips running in a true balanced parallel, extremely low jitter digital to analog converter.
SACD Mechanism Triple-beam laser, multi speed SACD transport
Formats SACD, CD AUDIO (CD-DA), CD-R, CD-RW, HDCD
Master Clock Jitter Below measurable levels
Digital Sample Rates (Fs) 44.1, 96, 192, 384, 512 or 768 kHz sample rates for CD playback to the analog audio outputs, 44.1, 96 or 192 kHz Fq for digital inputs
Digital Filter Burr Brown DF-1706 Software with HDCD decoding
Digital/Analog Converters Four (4) PCM1792u DAC chips running in parallel pairs
Analog Filter 3rd Order Bessel
Analog Outputs Balanced XLR, Single-Ended RCA
Digital Outputs AES/EBU, Coaxial, Toslink operating at Sample Frequency (Fs) from 44.1 kHz 16 bit to 192 kHz 24 bit
Digital Inputs AES/EBU, Coaxial, Toslink operating at Sample Frequency (Fs) from 44.1 kHz 16 bit to 192 kHz 24 bit , USB 24/192
Digital Input Sample Rate 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz or 192 kHz, Accepts 16, 20, or 24 bits
Communication RS232 full remote configuration interface
Power Input Configured at the factory for 100-120 or 200-240 Volts AC @ 50-60Hz
Power Consumption 65 Watts
Weight 34 lbs
Dimensions 5" H x 18" W x 15" D
AUDIO (CD)
Frequency Range 2 Hz - 22 kHz (44.1 kHz)
Amplitude Linearity 0.1 dB (20 Hz - 20 kHz)
Phase Linearity 3 degrees (20 Hz - 20 kHz)
Dynamic Range 131 dB (1 kHz)
Signal-to-Noise Ratio 127 (1 kHz)
Channel Separation 109 (1 kHz)
Total Harmonic Distortion 0.0004% (1 kHz) THD
Audio Output Level Single-Ended 3.0 Vrms (220 Ω output impedance)
Balanced XLR 6.0 Vrms (440 Ω output impedance)
AUDIO (SACD)
Frequency Range 2 Hz - 100 kHz (2.822 MHz)
Signal System 1 bit DSD
Sampling Frequency 2.822 MHz
Dynamic Range 132 dB
DSD System Clock Frequency 22.5792 MHz
Signal-to-Noise Ratio 128dB
infos constructeur :
http://www.caryaudio.com/
des photos de l'intérieur ici :
http://www.moon-audio.com/Cary%20Audio.htm
qqu'un sait quelles mécaniques utilise en général Cary Audio ?
qqu'un a déjà eu l'occasion d'écouter les précédents modèles de lecteur Cary Audion qui ont l'air d'etre réputés aux US ? (genre le CD / SACD 306, etc ...)
frisou
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Balin et 118 invités
Les Lecteurs CD & SACD
nouveau lecteur CARY audio CD 303T SACD Professional Version
- Home Audio Selection
- Inscription Forum: 05 Sep 2006 22:01
- Localisation: 2 points d'écoutes sur le Sud-Ouest (périphérie TOULOUSE et BORDEAUX)
Hello, pas encore pu l'écouter, mais j'ai toujours bien aimé les lecteurs cd cary, le 306 sacd pro est fabuleux.
les lecteurs Cary ont des très bonnes critiques au USA, mais sont moins reconnus en France
Cédric
Cédric
For the love of music...
- cédric1
- Inscription Forum: 07 Avr 2007 18:26
Encore un lecteur purement stéréo
Avec quoi les pros écoutent le SACD en multicanal?
- KurtLil
- Inscription Forum: 24 Oct 2000 2:00
cédric1 a écrit:Hello, pas encore pu l'écouter, mais j'ai toujours bien aimé les lecteurs cd cary, le 306 sacd pro est fabuleux.![]()
les lecteurs Cary ont des très bonnes critiques au USA, mais sont moins reconnus en France![]()
Cédric
j'ai surfé sur des sites US ou ils disent que le nouveau 303T serait meilleur que le 306 sacd pro (qui reste au catalogue) pour moins cher ...
si c'est le cas, cela promet effectivement car le 306 a une tres bonne réputation !
le 306 sacd pro, tu l'avais écouté (et aimé) en comparaison de quels autres lecteurs si c'est possible de savoir ?
Le 303 serait meilleur que le 306 qui a deux fois plus de puces de conversion ?
Possible, mais Carry ne se tire-t'il pas une balle dans le pied ???
Quant au multicanal, c'est certainement le prochain défi pour les DAC et les serveurs à venir (environ 5 ans), mais je peux me tromper.
Cdlt
Cdlt
- Djilbe
- Inscription Forum: 09 Sep 2006 15:19
frisounette a écrit:cédric1 a écrit:Hello, pas encore pu l'écouter, mais j'ai toujours bien aimé les lecteurs cd cary, le 306 sacd pro est fabuleux.![]()
Cédric
J'ai eu a plusieurs reprises l'occasion d'écouter les 306 sacd et 306 sacd pro chez mon vendieur et j'ai pu tester un 306 sacd pendant quelques jours chez moi
Ce sont des appareils qui sont très musicaux, très détaillés et avec une dynamique qui décoiffe
- cédric1
Djilbe a écrit:Bonsoir,
Cdlt
ce n'est pas le 303 mais le nouveau 303T (avec écoute possible via les sorties tube ou via les sortie transistor ... par sélection en facade ou sur la télécommande)
303T avec donc T pour version Tube ...
ici le descriptif des puces / conversion du 303T pro : "Eight (8) PCM1792u DAC chips running in parallel pairs"
ici le descriptif des puces / conversion du 306 pro : 8 Burr Brown 1792u DAC chips running in a true balanced parallel,
Digital/Analog Converters 8 channel (4) Burr Brown DSD 1792U
cela semble donc bien proche.
8 Burr Brown 1792u (4 paires en parallèle)
j'ai juste noté que le 303T est en PCM 1792u alors que le 306 est en DSD 1792u ... quelles sont les différences entre la version PCM et DSD ?
les 2 lecteurs ont des entrées numériques, mais le nouveau 303T a l'avantage d'avoir une entrée USB ... le 306 non.
par contre, sur les photos internes des 2, les alims ont l'air différentes ... celle du 306 a l'air plus ambitieuse (?)
Ha ! Ils se contredisent sur leur site pour le 303T.
8 puces de conversion dans le texte et 4 dans le tableau de specs.
Mais bon, et ce niveau c'est déjà très bien.
Cdlt
Cdlt
- Djilbe
8 ... et 4 in parallel pair (4 x 2 donc), c'est le meme chose ... maps de contradiction donc
J'aimerais bien le comparer avec un Mcintosh MCD500
Cédric
Cédric
- cédric1
ben si tu en as l'occasion, tiens nous au courant ...
+1
, des retours m'interesserait egalement ! il a de bon feedback au states
EGGLESTONWORKS FONTAINE MK1 /Blocs mono CAYIN 800 MK ( Tubes 829b RCA ) / Linn KLOUT / PCHC -Dac TOPPING DX3 Pro V2 2x AK4493EQ
bernardi - Membre HCFR
- Inscription Forum: 25 Jan 2006 21:39
frisounette a écrit:8 ... et 4 in parallel pair (4 x 2 donc), c'est le meme chose ... maps de contradiction donc
Pour moi, 8 puces 1792u ce n'est pas pareil que 4 puces 1792u. Et peut importe le mode de fonctionnement ou le fait qu'elle soit stéréo.
Mais attendons donc des tests avec photos de "sous la jupe" pour en avoir le coeur net
Cdlt
- Djilbe
Hello, j'ai eu la chance de l'ecouter ce vendredi après-midi chez Portier à Genève
L'appareil était flambant neuf, il le sortait du carton à mon arrivée
Dans ces conditions, difficiles de ce faire une idée sur les capacités de l'appareil, mais franchement le peut que j'ai écouté c'était très bon avec une dynamique fabuleuse et très transparent.
Sinon le Cary est superbe avec un magnifique plateau cd en alu et chose que j'aime beaucoup, le plateau est SOUS l'afficheur et non DESSUS
Cédric
Cédric
- cédric1
merci de ton retour.
je cherche déspéremment un revdendeur qui aurait le 303Tpro et:ou le 306pro dans le sud de la france ...
vu que tu avais déjà écouté le 306pro, tu as trouvé le 303Tpro comment ? différent ? meilleur ? moins bien ?
vu que le 303Tpro a des tubes (ce qui n'est pas le cas du 306pro), comment cela se traduit t il à l'écoute entre les 2 ?
qu'en dit ton revendeur également ?
frisou
frisou
24 messages
