Sony a écrit:Model: TA-A1ESTA-A1ES Integrated Stereo Amplifier: £1,999.00
The next generation amplifier for High-Resolution Audio
Integrated stereo amplifier with FET input buffer, SEPP hi-current amp and intelligent BIAS control
•FET input buffer for enhanced sound quality
•Simplified SEPP amplifier for large power output
•True sound with intelligent BIAS control
FeaturesTA-A1ES
Sound without compromise – The amplifier’s FET input buffer reduces distortion while enhancing the sound quality of Hi-Res Audio
Powerful output with better quality sound – The amp’s final stage circuit is simplified with less transistors and cutting the emitter resister and Coil & Capacitor needed
A quality, powerful performance – BIAS of the amplifier circuit is intelligently controlled by the volume position, so the sound quality always stays true
Technical SpecificationsTA-A1ES
Power Output
8Ohms 20-20kHz 80W+80W
4Ohms 20-20kHz 80W+80W
Features
Total Harmonic Distortion 0.03%
Speaker Impedance 4ohm-
Frequency Response 20Hz-100KHz
Signal-to-Noise Ratio(A Network) (When all of EQ/Surround off) 100dB
Number of amp. channels 2ch
4 Ohm/8 Ohm Switching YES
OP processing YES
Auto Standby YES
Input / Output
Analog Audio Input 5 (Balanced x 1 UnBalanced x 4)
Headphone Output YES
Speaker Output YES
IR Repeat (In/Out) 1 / -
General Specifications
Power Requirement 230V
Power Consumption Standby (W) 0.3
Dimension(WxHxD mm) 430 x 107.5 x 365
Weight(kg) 18
13 messages • Page 1 sur 1
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: _Guillaume, Dabozz, dgohyeres, domin, douda, jep, jybliste, lotofoof46, PBN94, Samuel2612 et 35 invités
Nouveaux appareils ES chez Sony
Un ampli : le TA-A1ES
- roland_de_lassus
Un lecteur de fichiers numériques (avec disque de 1TB inclus) : le HAP-Z1ES
Particularité : resample tout au format DSD.
Sony a écrit:HAP-Z1ES HDD Audio Player: £1,999.00
1TB HDD Audio Player with built-in Wi-Fi, Ethernet and easy music file transfer
・ Convert any music files to crisp, clear DSD audio
・Store all your tracks on a huge 1TB hard drive
・Browse music using an app on your smartphone
Features
Uncover true sound with High-Resolution (Hi-Res) Audio – The DSD Re-mastering Engine converts all your music files to DSD audio for better than CD quality sound
Copy & transfer with ease – Copy existing music files to the hard drive over Wi-Fi. When you add new music files they get copied automatically
Total control at your fingertips – Easily browse your music at speed using the front-panel LCD, or use the dedicated smartphone app, as a remote control
Access your entire music collection – The 1TB hard drive is huge – more than enough space to store all your Hi-Res Audio as well as your compressed music files
Stay in tune with your music – When files are copied to the hard drive, track names are automatically checked against an online database for accuracy
Compatible with a range of file types – Play Hi-Res Audio from a variety of compressed and non-compressed formats including FLAC, WAV, AIFF, DSD (DFF) and DSD (DSF)
Boost your storage via USB – If you need more storage, easily connect an external hard drive using USB
Technical SpecificationsHAP-Z1ES
Functions
Internal HDD YES (1TB)
External HDD YES (Rear USB)
PC Sync (Music/Video/Photo) YES/-/-
Maximum number of music 20,000 title
Internet Music Service vTuner
Sleep Timer YES
Auto Standby YES
Playback Codec
DSDIFF(DSD) YES
DSDIFF(DST) -
DSF YES
MP3 YES
WAV(LPCM) YES
WMA YES
AAC YES
FLAC YES
ALAC YES
ATRAC(NON DRM) YES
AIFF(LPCM) YES
Features
DSD Remastering YES
DSEE YES
Total Harmonic Distortion < 0.0015%
Frequency Response 2Hz – 80KHz(-3dB)
Dynamic Range >105dB
Network Features
Ethernet YES
Wi-Fi YES(IEEE802.11b/g/n)
Network Update YES
Network Standby YES
Inputs & Outputs
Analog Audio Onput 2 (Balanced x 1 UnBalanced x 1)
USB for external HDD 2 (For external HDD x 1, For PC x 1 )
IR Repeat (In/Out) – / 1
Display LCD(4.3inch)
Power Requirement 230V 50/60Hz
Power Consumption(W) 35
Dimension(WxHxD mm) 430 x 130 x 390
Weight(kg) 14.5
Remote control RM-ANU183/S
- roland_de_lassus
L'amplificateur n'est pas donné.
- Scytales
- Contributeur HCFR
C'est comme chez Yamaha avec leur série 3000.
Ils ont du se dire qu'il n'y avait pas de raison de ne pas en profiter..
Sinon, quelques photos supplémentaires sur le fil de l'IFA.
Mais 80 W l'ampli... Ça me paraît vraiment peu.
- roland_de_lassus
Et ce qui est bizarre c'est la puissance qui est identique sous 8 et 4 Ohms ?
- duf666
- Inscription Forum: 11 Mai 2011 18:07
- duf666
roland_de_lassus a écrit:C'est comme chez Yamaha avec leur série 3000.
Oui marrant qu'ils ne fassent pas plus puissant
- NOIR
Je suis assez curieux de "voir" comment ça sonne un ampli sony. Je n'en ai jamais écouté. J'ai vu des BE des ampli HC ES, ils ont l'air bon musicalement, alliant douceur et justesse des timbres.
Le seul regret sur le lecteur c'est le manque d'entrée numérique. Et comme l'ampli n'en a pas, ça peut manquer.
- Shocka
- Inscription Forum: 09 Mai 2004 15:38
J'ai pu écoute l'ensemble avec les nouvelles colonnes Sony a l'IFA.
Ma première impression est plutôt bonne. Mais je ne connaissais pas les morceaux joués.
Il m'est donc très difficile de donné un avis.
- julien0810
- Inscription Forum: 16 Nov 2009 22:57
L'application android pour le lecteur avec un mode démonstration pour tester
"HDD audio remote"
"HDD audio remote"
- lotofoof46
- Inscription Forum: 14 Nov 2005 12:13
Je suis bien content que Sony se remette à la HIFI avec la gamme ES ( du moins en France ). Au Japon la série ES a toujours été au catalogue, les SCD-XA5400ES, XA9000ES sont toujours en vente là bas.
Espérons qu'ils reviennent en force comme dans les années 90.
- ozata1
- Inscription Forum: 29 Jan 2006 20:04
Un des premiers articles complets sur le streamer (en anglais).
A lire sur le site de The Absolutesound.
A noter qu'il n'est pas compatible DLNA.
Vous ne pourrez donc pas streamer votre musique à partir d'un NAS.
Par contre, il recopie automatiquement chaque nouveau morceau de votre bibliothèque musicale sur son disque dur interne.
- roland_de_lassus
13 messages
