Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: albator91, AlexDarkness, alfachris, chris25, cohelfer, coucouse, Cyberdom, Dany54200, dat, djmx, Hubu, jmiforum, john-33, kalifept, Kris Tof, Madmax, Messenger of Death, Miky10, NoBiluS, Patbon21500, roosvelt, scramix, Stade81, Tommyknockerz99, tony51, vauclair83, WarC0zes et 161 invités
Nouveau Firmware
Recu par mail ce matin:
Model Support :
TViX HD M-4000P(PA,SA) / TViX PVR M-4010SA
TViX HD M-5000A / TViX PVR M-5010P
Bellow are the changes from firmware version 2.2.0. if your firmware is more recent version, some features may have been implemented already.
Default TV out : NTSC Composite
Default Language : English
Support Language : English, French, German, Italian, Spanish, Swedish, Russian, Czech
1. The location of the recording scheduler file(schedule.data) was changed from internal hard disk to Flash Rom.
- Improved the problem that the TViX does not boot after the recording time set passes.
2. Added Day Light Saving option.
- You can change this option on the SETUP-HDTV.
3. Improved the problem that Spanish L2 channel freezes when changing the channel.
4. Improved the problem that UK EPG skips some lists.
5. Fixed the problem that some German channels were not recorded in case that the channel names have some specific characters.
6. Fixed several minor bugs.
Firmware Download Link
Model Support :
- ayzan
- Inscription Forum: 28 Déc 2006 10:55
bonjour,
voila j ai une petite question surement deja posée mais je ne me sent pas de lire les 183 pages
j ai mon tvix 5000 branché en reseau avec mon pc via netshare.Je peux lire sans probleme tout ce qui est dans le repertoire c:tvixhd1.
ce que j aimerai,c est de pouvoir partager d autres dossiers mais je n y arrive pas.Si je vais dans netshare et que je veux ajouter un dossier à partager,ca enleve le premier!Ne peut on partager qu un seul dossier avec netshare ou y a t il une astuce que je n ai pas vu !
Merci de vos reponses
henry
henry
- henry55
- Professionnel
il te faut la dernière version du NetShare : ftp://ftp.dvico.com/Products/TViX/FirmW ... re2.01.zip
Cette version permet de gérer pls dossiers de partage
- dangee
- Inscription Forum: 02 Juil 2007 11:57
BUG Fmw 2.2.7 TviX 5000
J'ai noté un petit bug du 2.2.7, et j'aimerai savoir si c'est pareil chez vous.
Lorsque le message "Play" s'efface, il reste un petit bout de ce message en haut à droite de mon écran...
- dangee
[quote="dangee"]il te faut la dernière version du NetShare : ftp://ftp.dvico.com/Products/TViX/FirmW ... re2.01.zip
Cette version permet de gérer pls dossiers de partage [/
Ben merci DANGEE,comme quoi c est simple la vie....lol
- henry55
- Professionnel
dangee a écrit:J'ai noté un petit bug du 2.2.7, et j'aimerai savoir si c'est pareil chez vous.
yep ! j'ai détecté le même problème. Toutefois durant le visionnage d'un film cet artéfact à disparu au bout d'un long moment ! mais c'est quand même un bug gênant ( ça attire l'œil )
- benji425
- Inscription Forum: 08 Oct 2004 14:01
Pas la peine d'attendre...il faut appuyer sur la touche "Title", ce qui a pour effet d'ouvrir la fenêtre de chargement de sous-titres, puis appuyer pour la fermer...
C'est sur, c'est pas compliqué me direz-vous, mais à la longue c'est chiant...J'adore les MAJ qui amène plus de bugs qu'avant !!!
il faudrait prévenir Dvico du bug...mais pour expliquer ça en anglais c'est pas gagné...
- dangee
Participation
Hello,
Bon bin pas de réponses à mes questions en page 182...
Voici tout de même une participation pour les icônes, cela permet d'organiser les albums de musique ou les vidéos par ordre alphabétique.
Bon up.
Bon up.
- Fichiers joints
- iconTvix4.zip
- (124.39 Kio) Téléchargé 67 fois
- sebinet76
- Inscription Forum: 24 Juin 2007 12:40
c'est fait, en attente de nouvelles
"Hi there, in the last firmware you posted for TVIX 5000A (2.2.7), there is a minor bug which is when you're pushing on the button player, there is still a residual image of the icon on the right upper cadran of the Tv...could you fix it please?"
- abonnard
- Inscription Forum: 29 Aoû 2007 22:38
Pour info, meme problème sur le 4000....
- cedric22
- Inscription Forum: 02 Jan 2007 23:59
Savez vous si la dernière version de netshare fonctionne avec windows home server.
- cricribi86
- Inscription Forum: 10 Déc 2006 15:31
Depuis MAJ 2.2.7...J'ai un fichier .ts qui ne fonctionne plus et une diminution de réactivité sur les films HD....
- dangee
Bonjour, j'ai une question
Mon tvix est branché acuellement en s-vidéo sur ma TV avec le son en sortie optique sur un ampli.
dans ma chambre, j'ai une autre TV. Est ce que je peux brancher celle-ci avec la sortie composante pour la video et les sortie RCA pour le son (tout en gardant la s-video et optique sur la TV principale).
En gros, en journée je regarde le tvix dans le salon (s-video + optique) et le soir je regarde le tvix dans la chambre (composante + rca audio), le tout sans rien debrancher.
Est-ce que cela fonctionnera bien pour le son ? et pour l'image ?
- witchblade
- Inscription Forum: 18 Jan 2007 14:47
Je pense que c'est possible...Mais cela implique que tu changes la sortie vidéo dans le set-up du tvix à chaque fois...
- dangee
Retourner vers Lecteurs et Box Multimedia |
