Modérateurs: Modération Forum Home-Cinéma, Le CA de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 124 invités
Discussions générales qui ne rentrent dans aucune autre catégorie
Denon AVR-3803 : Informations Officielles (direct USA)
Message » 02 Oct 2002 23:01
Voici des informations officielles sur l’AVR-3803
Information données par Jeff Talmadge Product Manager DENON Electronics (USA), Inc.
Image Source de l’information
Yes we officially announced the 3803 at CEDIA. It will carry a MSRP of $1199 and be available very late October/early November.
Bass Management crossover points are now 40/60/80/100/120 like the 4802/5803. There is no BM on the EXT Inputs, however. We have added 24/192 A/D and D/A conversion. With the D/A conversion receiving dual DACs per audio channel(Burr-Browns PCM-1791)! Also Pure Direct is there, so with a digital source, in stereo, you get 4 DACs per channel. AL24 is on board for the best 2 channel digital filtering.
More juicy stuff - DDEX and dts 96/24 processing has been added, decoded by one of the Analog Devices HammerHeads from the 5803! Assignable 100MHz bandwidth component video switching with Video Conversion(composite to S and/or component)with on screen display! Audio Delay for lip sync correction.
The Multi-zone/source function is much more friendly with Remote I/O ports, Serial port for 232 protocol control, Assignable 12v trigger, discrete power on/off commands for Main and Second Zone with volume/source and now video!
New remote with LCD display and full backlighting
En français :
-- Bass Management 40/60/80/100/120
-- Pas de bass management sur l’entrée 5.1 (EXT)
-- Conversion A/N <-> N/A des signaux en 24/192
-- 2 DAC par canal (Burr Brown PCM-1791)
-- PURE DIRECT en Dual Differential (4 DAC / canal)
-- Dolby Digital EX
-- DTS 96/24
-- Décodage realise par un SHARC HammerHeads (le même que celui de l’AVC-A1SR)
-- Bande passante de 100 MHz sur les E/S Composantes
-- Conversion vidéo Composite <-> S-VIDEO <-> Composante
-- Audio delay (synchro image/son)
-- Gestion Multi-zone
-- RS-232 (pour AMX / panja probablement)
-- Trigger 12 V
-- Télécommande entièrement éclairée avec ecran LCD
Dispo USA : fin Octobre / début novembre
Prix USA : $1199
Update 10.11.2002 :
Communiqué de presse Denon France :
Denon est fier de vous présenter un nouveau venu dans la gamme des Ampli Tuner Audio Video
Fort de son expérience mondialement reconnue dans le domaine des technologies numériques, DENON est fier de vous annoncer un nouvel arrivant dans sa gamme AVR (ampli tuner audio/vidéo). L’AVR-3803 AL24 / Dolby Digital EX / DTS ES / DTS 24/96 / DPLII.
Section Audio :
L'AVR-3803 intègre pour la section d'alimentation un nouveau transformateur de puissance, combiné à une diode de redressement et un nouveau bloc de condensateurs de forte capacité ; ces éléments ont été spécifiquement développés pour l’AVR-3803. Toutes ces innovations garantissent une alimentation stable, capable de fournir des courants importants permettant de bénéficier d’une puissance de 7 x 110 Watts sous 8 ohms.
L’AVR-3803 utilise les dernières évolutions techniques en matière de décodage :
-Analogue Device Hammer Head Sharc 100 (virgules flottantes 32bits)
-DIR Sanyo 89057 + 4 D/A DAC PCM 1791 24/192kHz + 4 A/D DAC PCM 1804 (Burr Brown).
L’AVR 3803 offre la légendaire musicalité et la transparence sonore Denon en mode stéréo, grâce au fameux processeur AL 24.
Fonctionnalité Multi Room
La fonction Power Amplifier Assign de l’AVR-3803 permet, lorsque l’appareil n’est pas configuré en format 7.1, d’utiliser les amplificateurs des deux canaux Surround gauche et droit pour alimenter les enceintes de la zone Multi room 2, à raison de 110 Watts par canal, tout en alimentant avec les cinq canaux restants les 5 enceintes de la configuration 5.1 dans la salle de Home Theater.
Section vidéo
L’AVR-3803 intègre la fonction Video Up Conversion Y/Pb/Pr, qui permet de convertir les signaux vidéo en signaux composantes, pour une meilleure qualité d’image avec tous les types d’appareils vidéo.
Cette fonction offre un grand confort aux utilisateurs de video projecteurs, en leur permettant d’utiliser un seul cable YUV pour véhiculer toutes leurs sources image.
L’AVR-3803 intègre également :
-7 entrées audio/vidéo
-8 pre out
-5 entrées, 2 sorties optiques
-2 entrées coaxiales
-7 SVHS
-7 composites
-2 YUV.en entrées 1 en sortie
-un trigger 12 Volts
-un port série compatible AMX et Crestron.
-un réglage du niveau d’écoute par demi-dB
-un Cross over réglable 40/60/80/100/120 Hz
Image Source de l'information
Laurent Image
Update 10.11.2002 : Ajout du communiqué de presse de Denon France.
Laurent B.
Inscription Forum: 13 Mai 2001 2:00
Message » 03 Oct 2002 17:36
Salut Laurent
Les conversions vidéo sont fort sympathiques, et laissent supposer que dans le futur, la plupart des intégrés et préamplis HC en seront dotés. Ce qui sera fort pratique pour les amateurs de VP (à condition que la conversion vers les sorties composantes soit de bonne facture, évidemment).
A bientot
Georges
Georges G
Inscription Forum: 06 Fév 2002 2:00
Encore plus d'infos...
Message » 03 Oct 2002 20:02
La photo :
Les spécifications :
Dolby Digital Surround EX, Dolby Pro Logic II & DTS ES Discrete 7.1 A/V Receiver • Dolby Digital Surround EX, Pro Logic II decoding with Cinema and Music Modes • DTS Extended Surround Discrete 6.1 decoding • DTS Extended Surround Matrix 6.1 decoding • DTS Neo:6 Cinema & Music Surround decoding • DTS ES 96/24 5.1 decoding for DVD Video • New DDSC-Digital featuring Analog Devices Melody 100 (HammerHead SHARC) 32 bit floating point DSP processor • 7 Channels equal power amplifier section • 110 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD) • 150 watts per channel (6 ohms, 1 kHz, <.7%THD) • 16 Burr-Brown PCM-1791 24 bit, 192 kHz high resolution DACs on all eight channels, in differential configuration • Real 24 bit, 96 kHz Digital Interface Receiver • 24 bit, 192 kHz A/D conversion (Burr-Brown PCM-1804) on all analog inputs • Pure Audio mode, features 4 DACs per audio channel in dual-differential configuration • ALPHA 24 Processing (AL24) in Stereo/Direct/Pure Direct modes (left/right channels) • Adjustable High and Low Pass Crossover (40/60/80/100/120Hz) • 2 Assignable component video inputs (100MHz), with On-Screen Display • Video Conversion of Composite to S-Video and/or to Component, with on-screen display • 7 sets composite and "S" video inputs • 7.1 external wide bandwidth (100 kHz) input for future multi-channel formats (such as DVD-Audio) • 5/7 Channel Stereo • Digitally regulated volume control with .5dB increment adjustments and step range of -80 to +15 • Audio Delay adjustment to match audio signals with video signals(0-200ms) • Personal Memory Plus • 7 assignable digital inputs (5 Optical, 2 Coaxial) • 2 Optical digital outputs • 9 analog inputs including built-in AM/FM tuner • Multi-Zone 1 stereo pre-amp level audio outputs, fixed or variable level • Multi-Zone 1 Composite Video output • Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive second zone speakers directly • LCD dot-matrix programmable/learning remote features TV, VCR, DVD codes from other manufacturers with full backlighting • Serial Port for Third Party Control Systems • Remote I/O ports • Assignable +12v trigger • Dimensions: 17.1"w x 6.7"h x 16.4"d • SRP $1199 • Available at Dealers in LATE OCTOBER/EARLY NOVEMBER '02
Divers :
Image Telécharger la fiche détaillée de l'AVR-3803
Image Telécharger le manuel utilisateur de l'AVR-3803
Laurent Image
Laurent B.
Message » 03 Oct 2002 20:23
Pas mal du tout la bestiole.
Il ne lui manque qu'une seule chose : des entrées numériques iee1394 pour le DVD-A/SACD histoire que ces DAC 192Khz soient réellement utiles !
ajds
Inscription Forum: 02 Fév 2000 2:00
Message » 03 Oct 2002 20:31
On peut alors espérer une prochaine sortie d'un 4803, non ?
manu_XP
Inscription Forum: 01 Juin 2002 17:23
incompatible 100%
Message » 03 Oct 2002 20:36
ajds a écrit:Il ne lui manque qu'une seule chose : des entrées numériques iee1394 pour le DVD-A/SACD histoire que ces DAC 192Khz soient réellement utiles !
Oui, mais je ne suis pas certain que Denon veuille sortir une IEE-1394. Ils ont l’air très accrtoché à leur système propriétaire Denon Link dont ils vienne de sortir une nouvelle version (comme tu le sais) incompatible à 100% avec l’ancienne version. Des fois, il font vraiment n’importe quoi chez Denon :evil:
A mon avis, les DAC 192/24, c’est parce que leur fournisseur ne fabrique plus moins que ça.
Laurent Image
Laurent B.
Message » 03 Oct 2002 20:45
Soir à tous,
7 amperes c'estpas un peu mou çà. (pas taper tout de suite :wink: )
A+,
Scuderia.
SCUDERIA
Inscription Forum: 20 Déc 2001 2:00
Message » 03 Oct 2002 22:00
Y a t'il un 2803 de prévu??
rajak
Inscription Forum: 05 Juil 2002 22:56
Message » 03 Oct 2002 23:33
Salut !!
Ca a l'air pas mal tout ca !!!! :wink:
Volte/face
Inscription Forum: 28 Fév 2002 2:00
Message » 04 Oct 2002 0:36
SCUDERIA a écrit:Soir à tous,
A+,
Scuderia.
tu as vu ca ou, toi?
et s'il consommait effectivement 7 amperes, cela ferait une consommation instantanee de 1540W (7x220)... ce qui n'est pas mal, non?
quand ils disent amp, cela veut dire amplifier.... canal d'amplification en fait!
sans la telco, il ressemble un tout petit peu au 3802 :wink: :wink:
et mou, un Denon? viens chez moi, tu verras ou entendras que ce n'est pas si mou que ca! :wink: :wink:
l'invitation est sincere!
Pierre
newbie mais
Inscription Forum: 02 Fév 2002 2:00
xc
Message » 04 Oct 2002 9:38
Pas mal le look!! il se sont laché les designers chez Denon :lol: :lol:
tertez
Inscription Forum: 08 Mai 2002 17:47
Message » 04 Oct 2002 10:44
[quote="newbie mais]
[/quote]
c est un peu exagérer 1540W
averell
Inscription Forum: 05 Jan 2002 2:00
Pas encore, à mon avis
Message » 04 Oct 2002 13:30
manu_XP a écrit:On peut alors espérer une prochaine sortie d'un 4803, non ?
Pas encore, je pense. Pour le moment, Denon suit exactement le même calendrier qu’il avait suivi lors de l’ancienne gamme
1. AVC-A1SE
2. Quelques mois après AVR-1602 et AVR-1802
3. Quelques mois après AVR-3802
4. Et puis l’AVR-2802
5. Et longtemps apres : l’AVC-A11SR
Là, ils sont bien parti pour faire pareil :
1. AVC-A1SR
2. Quelques mois après AVR-1603 et AVR-1803
3. Quelques mois après AVR-3803
En général, chez Denon, les HDG ont une durée de vie de 1 an et demi.
Laurent Image
Laurent B.
Message » 04 Oct 2002 17:44
A+,
Scuderia.
Pierre
J'ai lu çà dans la fiche détaillé de l'ampli, que Laurent à mis en lien.
Et puis M**** j'avais dis pas taper :evil: .
A+,
Scuderia.
SCUDERIA
Message » 04 Oct 2002 17:53
SCUDERIA, tout faché, a écrit:J'ai lu çà dans la fiche détaillé de l'ampli, que Laurent à mis en lien.
A+,
Scuderia.
je n'ai pas tape voyons! n'as tu pas vu les :wink: :wink: ?
tu as vu "7 amp", et ce sont "7 canaux d'amplification"!
sont faineants ces Ricains :wink: :wink:
Pierre
newbie mais
