Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: citizen33, killi13011 et 34 invités
SUNFIRE LA TOTALE
Message » 02 Juin 2003 10:04
hello,
à vendre pour un ami (moi je suis pas assez riche :D )
PRE AMPLI sunfire TGIII : 3800 euros, encore sous garantie
Auto signal sensing input switching – Automatically turns the unit on, selects your source and surround mode
7.1 Channel Dolby Digital, Dolby Digital EX, DTS, DTS-ES, DTS Neo:6, and Dolby Pro-Logic II decoding, plus Sunfire's exclusive Side-Axis outputs for 9.1 channels total playback!
Bob Carver's awesome Holographic Imaging now in noise-free DSP for the ultimate soundstage enhancement of two-channel sources
Second zone can play sources independent of the main zone
Full-time digital downmix provides accurate two-channel output for tape recording, digital outputs, and second zone from multichannel digital sources
Nine channel (user settable) 'PARTY' mode engages all speakers from any two channel source
Direct two-channel analog bypass mode
Incredible new preprogrammed and learning remote control with LCD (click HERE to see it)
Bob Carver's awesome Dynamic Tuner Noise Reduction circuit dramatically improves clarity of weak FM stations
Additional simulated surround mode converts stereo inputs into five or seven channels of output
FM/AM tuner with Bob Carver's Dynamic Noise Reduction circuit and 40 presets
Three 100MHz+ HDTV compatible wide-bandwidth component video inputs and two outputs
Six audio/video inputs, each with audio, S-video and composite video
Three audio-only inputs, including Moving Magnet Phono input for LPs
Eight channel analog audio input using RCA connectors for DVD-A, SACD, or other external multichannel source
Digital audio (S/PDIF) inputs for six sources: four coax or optical, plus two coax only
Coaxial and optical digital (S/PDIF) outputs provide two-channel digital downmix from 5.1 sources
Balanced outputs for primary 7.1 channels
Four subwoofer outputs
Side-axis side speaker outputs for completely enveloping soundstage (total of 9.1 channels!)
Comprehensive all-digital bass manager with crossover frequencies of 40 to 160Hz
DSP tone controls
24-bit A-to-D converter and 24-bit/192kHz Multibit D-to-A converters for the ultimate in sound quality
Separate trigger outputs and infrared inputs for both zones
High-current (500mA total) trigger outputs easily handle the most power hungry accessories
Sunfire exclusive: FLASH memory upgradable by playing a CD!
IEEE-1394 (Firewire™) port for future expansion
Dimensions: 19" wide, 6.5" high, 15.75" deep
AMPLI Cinema Grand 5x225 watts : 3000 Euros
info dispo sur www.sunfire.com
julianr
Inscription Forum: 08 Sep 2000 2:00
Localisation: dpt 91 village de gauche apres celui des apaches
Message » 05 Juin 2003 14:11
alors ça tente personne???
julianr
Message » 05 Juin 2003 18:22
Ben si, mais pas assez riche non plus :cry:
Up quand même ;)
guest
Inscription Forum: 15 Fév 2001 2:00
Message » 16 Juin 2003 11:01
alors toujours personne pour un ensemble d'exception???
julianr
Message » 22 Juin 2003 23:18
ha si seulement j avais pas la meme chose,je plongerai sans hésiter :wink:
Fantomas29
Inscription Forum: 16 Oct 2002 15:17
Message » 09 Juil 2003 11:04
suite à desistement, c'est à nouveau dispo!!! :o
julianr
Message » 16 Juil 2003 14:26
ben toujours le meme statut!!! :(
julianr
Message » 16 Juil 2003 15:17
Archivé pour cause de "vente de matériel d'un ami" :roll:
Christophe Elecson KLS
Pro-Commercant
Pro-Commercant
Inscription Forum: 23 Sep 2000 2:00
Retourner vers Enceintes HIFI
