11 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: nemo136, outlaw et 22 invités
REL STORM 5
Vends 1 subowoofer Rel STORM 5. Neuf, emballage d'origine, facture. Placage bois véritable black ash. A peine rodé. Prix neuf 1700 € vendu à 1100 €.
- Fichiers joints
- storm5.jpg (12.19 Kio) Vu 1453 fois
- prol
- Inscription Forum: 16 Oct 2002 20:41
Et pour ceux qui veulent en savoir + :
High quality, gas-tight Neutrik Speakon input (high level)
High quality, panel-mounted twin phono inputs (L/R) (low level)
LFE phono input/output, a separate input to twin low level phono inputs
Totally discrete input circuitry for high and low level inputs
Large, blue front-firing LED display with adjustable brightness
True 200W (continuous) discrete, direct-coupled MOSFET amplifier
Downward-firing long-throw 250mm (10”) cast chassis driver
Improved ABC® filtering circuit calibrated in single Hz steps from 16 to 99
Separate volume controls for high and low-level adjustment
Variable Slam/Depth control –9dB to +9dB at 80Hz
5-12V DC trigger
Simultaneous connection of high and low level sources
Set-Safe® audibly transparent driver protection
Double-sided glass-fibre boards with plated-through holes
IEC power input socket and switch - no captive leads for installation flexibility
Finished in 30mm MDF in balanced Black Ash, Maple, Cherry, Walnut, Light Oak and Rosenut real wood veneers
Designed and hand-built in Great Britain, three-year worldwide warranty
Specifications
System Type
Closed box 'Zero-Q' loading
Frequency Roll Off
16Hz-99Hz
Lower In-Room Response (-3dB) 15Hz
Gain Control Range
80dB
Dimensions WxHxD mm (incl feet & controls)
345 x 520 x 370
Net Weight kg
30
Lien => http://www.rel.net/index2.htm
Bonne vente.
OO7livier.
5-12V DC trigger
Specifications
System Type
Frequency Roll Off
16Hz-99Hz
Gain Control Range
80dB
345 x 520 x 370
Net Weight kg
30
Bonne vente.
OO7livier.
OO7livier - Modération Home-Cinema & Rencontres
- Inscription Forum: 21 Nov 2002 14:32
Personne pour ce superbe caisson ?
Faites moi une proposition correcte.
- prol
tu es ds quel dpt?
- escaf1
- Inscription Forum: 12 Mar 2002 2:00
un petit up pour ce superbe caisson !!!!!
- prol
11 messages
