Le topic du marantz SR9300
Je crée ce topic pour recenser les quel heureux processeur de cet magnifique ampli !
Ainsi si il y a eu des mises à jour hardware ou soft merci de les poster.
Il a été commercialisé en black gold et sliver.
Mais uniquement en gold en France et sans péritel mais du YUV à la place.
Voici la version de dos peritel
CERTIFICATION
THX Ultra2, 7 channel Amplifier
MULTICHANNEL/SURROUND MODES
THX: Surround EX, Ultra2, 5.1 Music decoding
DTS: ES (Matrix 6.1, Discrete 6.1, Neo-6), DTS 5.1ch decoding
Dolby Digital: DD / DD-EX
Dolby Pro Logic DPL / DPL II Movie, Music, Customize
Circle Surround CS II Movie, Music, Mono
Virtual Surround Yes
Multi Channel Stereo Yes
Other Surround Modes Movie, Hall & Matrix
Auto Surround Mode Detection Yes
HDCD Decoder Yes
SOUND ENHANCEMENTS
Current Feedback Technology Yes
Discrete Amplification (All) Yes
Power transformer Toroidal, Low leakage flux
Linear Drive Power Supply Yes
Chassis Copper Plated
192/24-bit D/A Conversion All Channels, Crystal DAC
A/D Converter 192kHz/24-bit
Digital Signal Processing 24-bit, High Definition Twin
Digital Signal Processor CS49329 + CS49330
Adaptive Double Diff. Control Yes
Video Off Yes
High Grade Video Components Yes
Source Direct Yes
System Block Shielding Yes
High Grade Audio Components Yes
Customized Components Yes
Intel. silent cooling system Yes
Chassis Stabilisation system Yes
OTHER
GYRO Touch Tuning Yes
Random Tuner Presets 50
RDS PS, PTY, RT Yes
Speaker Distance Correction Yes
On Screen Display Main, Multi Room Yes
Auto TV Switching (On/Off) Yes
Software Upgradable (RS232) Yes
IN/OUTPUTS
VIDEO
Scart In/out 1/1
Composite In/Out 7/4 (Incl.Monitor out)
S-Video In/Out 7/4 (Incl.Monitor out)
Component In/Out No
Gold plated In/Out Yes
AUDIO
Analog In/Out 10/4
Digital Optical In/Out 4/1
Digital Coaxial In/Out 5/1
Gold Plated In/Out Yes
OTHER
Pre-Amplifier Out 7.1 Channels
Main Amplifier In 7
Multi-Channel In 7.1 Channels
Multi-Room Audio Out Yes
Multi-Room Video Out CVBS / S-Video
RS232 Control Yes
DC Triggers 2, Assignable
Speaker Terminal High grade, Heavy Duty, Screw, 7 Channels
Front Speaker A+B
Multi-Room Speaker Terminal High grade, Heavy Duty, Screw, 2 Channels
D.Bus In/Out Yes
Multi-Room D.bus In/out Yes
External IR In/Out Yes
AC Outlets 1, Un-Switched (Not for UK)
Front Inputs 4, Audio/Composite/S-Video/Digital (Optical)
Headphone Out Yes
SPECIFICATIONS
AUDIO SECTION
Power Output 160 W / ch (6Ohm) X7
Signal to Noise Ratio 106 dB
Freq.Response Analog In 8 Hz - 80 kHz (+/- 3 dB)
Freq.Response Digital In 8 Hz - 45 kHz (+/- 3 dB)
Input Sensitivity/Impedance 195 mV / 47 kOhm
TUNER SECTION FM
Frequency Range 87.5 - 108 MHz
Signal to Noise Ratio 75 / 70 dB (Mono/Stereo)
Distortion (Mono/Stereo) 0.2 / 0.3 %
Channel Selectivity 60 dB (+/- 300 kHz)
Usable Sensitivity IHF 1.8uV / 16.4 dBf
Channel Separation 45 dB (1 kHz)
TUNER SECTION AM
Frequency Range 152-282 kHz (LW), 531-1602 kHz (MW)
Signal to Noise Ratio 50 dB
Distortion 0.5% (400 Hz 30% mod)
Channel Selectivity 70 dB (+/- 18 kHz)
GENERAL
Colour Black / Gold / Silver
Front Panel Heavy duty Aluminum
Remote Control RC3200
System Remote, Function Learning / Touch Screen / 2-Way
Power Consumption 530W (Stereo mode rated)
Detachable Power Cable Yes
Maximum Dimension (WxHxD) mm 440 x 184 x 480 mm
Weight 19.5 kg
Il ne lui manque que la liaison ilink ..... c'est la raison de sont flop commercial.
Comme souvent marantz avait un train de retard sur les évolution HC.
Alors pourquoi l'avoir acheté ?
Car j'adore le son marantz et il etait destoké voila !
a+
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: d2r2.off, Google Adsense [Bot], kamuel, manolo57420, misteurz, moglo, MUS1156, Salvador Hard-on, zalem, zarkka et 281 invités
A j'ai oublié une question quelqu'un connait'il l'existence d'une mise a jour hardware derrière la fameuse plaque (opt) qui ce trouve a l'arrière ???
- le.fabiolo
- Inscription Forum: 14 Aoû 2002 11:20
LOL je suis le seul possesseur d'un SR9300 sur le forum ....
Je me sens bien seul
- le.fabiolo
combien l'as tu acheté??
Salon: Sony 77A95L, Marantz DV12S1, Denon AVC-A110, Usher Audio CP777 Diamond + BE-616 Diamond, COAX SEAS DIY Surround, SW Athom V60 DIY. Full Analysis + Oval 2 et pro, Big Silver Oval HP
Salle Jeu: Sony 65A90J, Denon AVC-A11XV, Usher Audio CP6311
koumeebrown - Membre HCFR
- Inscription Forum: 06 Mar 2004 16:01
mise à jour
la mise à jour ne vaut pas trop le coup en plus marantz le fait payer 300 eur
j ai appelé reditech, et les mises à jour me concernant ( sr8200) sont " légeres ", passer de CS.1 à CS.2 par exemple donc j ai laissé tomber, car il au niveau son je suis satisfait
- sjmm
- Inscription Forum: 10 Fév 2004 10:50
sjmm a écrit:la mise à jour ne vaut pas trop le coup en plus marantz le fait payer 300 eur
Tu as un lien pour moi ? reditech ?
c'est des privée c'est pas garantie marantz ?
a+
- le.fabiolo
il y a pas de lien, il faut les contacter par téléphone c est le centre technique agréé marantz, à paris ils sont situé bd ney dans le 19 ieme, voila le numéro de tél 01 46 07 76 44
- sjmm
MERCI
Je vais leur téléphoner pour voir s’ils peuvent faire des modif.
Quelle différence entre le CS.1 et le CS.2 ?
Car la gestion des canaux arrière EX c'est un peu la merde il ne fonctionne pas en auto.
Si la source est pas ex il faut que j'aille dans le menu pour les forcer a chaque disque sa soule.
a+
a+
- le.fabiolo
le technicien m a dit qu il n y avait pas énormément de différences, et qu' a l écoute je ne le verrais pas , c est vraiment une mise à jour logicielle pure et simple,
ce n est pas comme si on te changeait un processeur ou une puce de decodage...
la difference entre cs.1 et cs.2 je ne sais pas
- sjmm
J'ai telephoné pour le moment il n'y a pas de mise a jour pour le SR9300.
a+fab
a+fab
- le.fabiolo
Le Sr9300 cloner
Le SR9300 est cloné par le SR12 !
Look mon post
http://www.homecinema-fr.com/forum/viewtopic.php?p=169193522#169193522
Look mon post
- le.fabiolo
aucune mise a jour de l'ampli...... et il en aura jamais
Marantz france me la confirmé aujourd'hui ... quel idée de mettre du RS232 et une plaque avec option si jamais rien ne bouge.
enfin je l'aime quand même mon ampli
- le.fabiolo
C'est bien le foutage de gueule marketing des matos dit évolutifs !!! (et cela ne concerne pas que le matériel HC of course ...)
On te vante l'aspect évolutif du système et puis quand tu veux y passer, la techno a tellement évoluée (sans parler des prix !) que les évolutions tu les regarde chez les autres ... et puis de guerre lasse tu finis un jour par changer le bazar en entier
Cela dit le SR9300 doit être une bien belle bête, quelqu'un a il pu comparer au 8500 ?
- le_gus
- Inscription Forum: 25 Fév 2004 14:24
pas pareil déja le sr8200 >au 8500 niveau hifi sans pb
- sjmm
sjmm a écrit:pas pareil déja le sr8200 >au 8500 niveau hifi sans pb
qu est qui te fait dire ca...?
a+
- zebulons69
- Inscription Forum: 18 Juil 2002 21:51
25 messages
