Type : Caisson de grave
Marque : Revel
Modèle et options : B15 de couleur noir
Prix de vente : 1700
Département où la marchandise est visible : 69
Etat de la marchandise : Excellent
Première main : non
Prix neuf : 4000
Facture conservée : oui
Date et lieu d'achat : 2006 pour ma part, probablement 2002 (dixit Revel après controle n° de Série)
Numéro de série : oui
Documentation conservée : oui
Description et commentaires :
Je me sépare de ce super caisson, l'un des meilleurs assurément.
Il est de couleur noir.
Entrées XLR, triple égaliseur.
50 kg le bestiau
Low Frequency Extension: -3 dB @ 18 Hz (up to full-rated power)
In-room Frequency Response: 20 Hz to f c ±0.5 dB, - 3 dB @ 18 Hz
True Linear Volume Displacement: 275 inches cubed
Dimensions: width: 17.75" (45cm)
height: 20.062" (51cm)
depth: 18.312" (46.5cm) including grille
Spikes add 1.5" (3.8cm) to height
Shipping Weight: 110 lbs. (49.9 kg) net (without packing, includes amplifier)
Output Power: At least 1,000 W rms , 1,400 W peak
Equalization: Type: Three independent parametric equalizers
Frequency: Continuously variable from 18 to 80 Hz
Bandwidth: Continuously variable from 0.1 to 1 Octave
Level: Continuously variable from -14.5 to +6 dB
Low-Pass Filter: Type: Low pass with ON/OFF switch
Slope: Selectable 24 or 48 dB per octave
Frequency: Selectable at 30, 40, 50, 60, 70, or 80 Hz
Phase: Continuously variable from 0 to 180°
High-Pass Filter: Type: High pass, always on
Slope: Selectable 12 or 24 dB per octave
Frequencies: Selectable at 30, 40, 50, 60, 70, or 80 Hz
Inputs: Left and right balanced (XLR) and unbalanced (RCA) line level
Outputs: Left and right balanced (XLR) and unbalanced
(RCA) high-pass line level to main amplifier
(RCA) line level to auxiliary components
Power: 120 V ac @ 60 Hz, 720 W rms with 10 A fuse
240 V ac @ 50 Hz, 720 W rms with 5 A fuse
Switch: OFF or AUTO-ON
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: ludovic62, Manu GS et 7 invités
Tu le remplaces par quoi?
- aurel
J'aimerais le remplacer par plusieurs petits caissons.Pas encore choisi.
- Muadib
- Inscription Forum: 03 Juin 2005 18:06
j'espère pour toi que tu as fait des essais avant!
- aurel
L appareil est il encore sous garantie?Est ce une premiere main?
- pascal20
- Inscription Forum: 20 Jan 2007 20:05
Pas de garantie, ce n'est pas une première main. En revanche, il est nickel de chez nickel. J'ai le carton, les docs.
- Muadib
pourrais tu nous donner le diametre du HP ?
- Gregouille
- Inscription Forum: 13 Mai 2001 2:00
B15 = 15" = 38 cm
Magnetar UDP800 / Lumagen Pro 4242 / JVC N7 / MicroPerf'Oray HD 4K / Anthem AVM90 / 9 x Focal, SM6 Be & 1000 Be + 4 x 300 / 2 x Subs DIY Beyma 18LX60 V1 / Amplis HPA / Etudes, traitements & calibrations pros
SYLEX - Administrateur Suppléant de l'Association & Délégué Editorial
- Inscription Forum: 11 Oct 2002 13:47
Un beau "petit " monstre ce B15! j'avoue qu'il m'avait bien tenté à une époque!
buss - Modérateur Home-Cinéma
- Inscription Forum: 31 Aoû 2002 23:12
Si notre spécialiste en basses nous dit que c'est un bon caisson, alors s'est un bon caisson
Buss ....
Buss ....
- kbil69
mp
tu as un mp
- teteatoto
- Inscription Forum: 12 Jan 2006 14:20
Baisse du prix 1800 euros
- Muadib
Le banc d'essai de PAV :
http://www.studiopressdigital.fr/prestige/bepav/index.php?page=be_txt.php&id=309
Extrait du test :
"Grâce à son exceptionnel haut-parleur de 38 cm à membrane papier et aluminium, son système d'optimisation et de réglages en fonction de l'environnement acoustique, son amplificateur de 1000 watts RMS, son ébénisterie inébranlable, le Revel Performa B15 offre des performances unique qui le placent comme une référence absolue en "matière" de caisson grave."
Extrait du test :
- Franck21
- Inscription Forum: 12 Mai 2002 17:12
26 messages
