- Gestion des Basses
- Speaker Fill (conversion du 2.0 en 5.1)
- Egalisation du niveau sonore
- Correction de pièce: réglage automatique des délais, niveaux des enceintes, et ré-égalisation par rapport à la réponse de la pièce.
J'ai ouvert ce post pour que ceux qui on essayé ces amélioration nous donnent leur retours.
CORRECTION ACCOUSTIQUE de la PIECE
Voici en quoi consiste cette correction d'après Microsoft (sur AVS):
Our room correction will equalize frequency response, time delay, and gain between all of your main channels, as well as build a first-reflection-cancellation filter if one or more of your speakers are near a reflective surface. If you do have a high-quality microphone, the room correction system will also flatten the overall frequency response and adjust the subwoofer delay accordingly.
Le papier ci-dessous (conférence AES #117) décrit ces algorithmes plus en détail, mais je n'ai pas pu mettre la main dessus... Voici quand même des slides
P16-3 A Low Complexity Perceptually Tuned Room Correction System—James Johnston, Serge Smirnov, Microsoft Corporation - Redmond, WA, USA
In many listening situations using loudspeakers, the actualities of room arrangements and the acoustics of the listening space combine to create a situation where the audio signal is unsatisfactorily rendered from the listener’s position. This is often true not only for computer-monitor situations, but also for home theater or surround-sound situations in which some loudspeakers may be too close to too far from the listener, in which some loudspeakers (center, surrounds) may be different than the main loudspeakers, or in which room peculiarities introduce problems in imaging or timbre coloration. In this paper we explain a room-correction algorithm that restores imaging characteristics, equalizes the first-attack frequency response of the loudspeakers, and substantially improves the listeners’ experience by using relatively simple render-side DSP in combination with a sophisticated room analysis engine that is expressly designed to capture room characteristics that are important for stereo imaging and timbre correction.
Convention Paper 7263
PROCEDURE
Malheureusement, ces améliorations ne sont pas disponibles pour toutes les cartes son. Cela dépend de la volonté du fabriquant à supporter ou non ces effets standards.
Heureusement, pour ceux qui ont des cartes sons ne disposant pas par défaut de ces améliorations (les cartes son pro en particulier), il existe un moyen de les rajouter qui marche pour la plupart des cartes sons. Je l'ai testé positivement pour les cartes Auzen X-Meridian 7.1 et pour l'EMU 1820M. Si vous avez une autre carte, la démarche sera la même.
Voici cette démarche. Elle vient à l'origine de là. Voici ces instructions rapportées ci-dessous:
Here's how to add the Enhancements tab to your sound card.
Requirements: Your sound card must have Vista drivers and use the Vista in-box class driver. To check if your sound card uses the Vista class driver, go to device manager and open up the properties of your sound card. Go to the drivers tab and click on Driver Details. The driver files list should include portcls.sys.
Some vista sound card vendors haven't written APOs (Audio Processing Objects) for Vista yet. You can use the instructions below to hack your sound card to use the APOs for the Microsoft High Definition Audio Device driver. Once you have the APOs defined and your card's driver uses the in-box class driver, you should be able to use the enhancements tab with your soundcard. I did this on my X-Meridian 7.1 sound card, but it should work for other sound cards.
For the X-Meridian 7.1 card, use the C-Media control panel app to set the input and output to 8 (7.1) channels. Disable digital output. Set the output to 48kHz, or whatever rate you want. You will then need to manually sync up the rate that you set here to the Advanced tab on the properties of the speaker output for you card.
1) Start cmd.exe as an administrator and execute these instructions:
cd %windir%\system32
regsvr32 WMALFXGFXDSP.DLL
Regedit
2) With the registry editor, browse to this regkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion \MMDevices\Audio\Render
3) Look at each \{GUID}\Properties regkey for string values that describe the speaker output for your sound card. For the X-Meridian it should have strings like "Auzen X-Meridian 7.1" and "Speaker". Don't use the digital outputs as the beta drivers only work for the analog connections.
4) Right-click on the {GUID} regkey and select rename. This will highlight the entire GUID string. Hit Ctrl-C to copy the string to your clipboard buffer. Hit Escape to cancel the rename operation.
5) Save the attached file as .reg. Right-click on VistaAudioEnhancements.reg and select edit. Paste your card's GUID over the one in the reg file. You will be replacing the part in the quotes. This will add the FxProperties regkey and values to your card.
..MMDevices\Audio\Render\"{c9e0d6e5-1682-41fd-82d3-d071b37d9075}"\FxProperties]
6) With the registry editor, right-click on your card's GUID regkey and select permissions. Click the advanced button and go to the Owner tab. Highlight the Administrators group and click Apply. This will change the owner of this regkey to the administrators group. Click OK. On the permissions dialog box, highlight the administrators group and check Allow for Full Control. Click Apply, then OK. This will allow you to add the VistaAudioEnhancements.reg file to your card's GUID regkey. Double-click the reg file to add the FxProperties regkey to your card's GUID regkey.
7) Restart. You should now have the Enhancements tab on the properties dialog box for the speaker output for your card.
En résumé et en français:
1) Pas utile la plupart du temps
2) et 3) Recherche dans la base de registre la clé correspondant à l'EMU ou l'Auzen selon (voir zone surlignée dans la copie d'écran ci-jointe). Repérer le champs "Haut-parleurs" dans la section "Properties" de la clé.
4) Copier la clé dans le presse-papier
5) Dans le fichier .txt ci-joint, remplacer la clé de la première ligne par celle copiée dans le presse-papier. Sauver le fichier en .reg au lieu de .txt
6) Dans la base de registre, modifier le propriétaire et les droits d'accès à la clé afin de pouvoir lui ajouter la section "FxProperties" définie dans le fichier .reg. En d'autres termes:
---> Bouton droit sur la clé > Autorisations > Avancé > Propriétaire > "Administrateurs" > Appliquer > OK
---> "Administrateurs" > Autoriser le contrôle total > OK
---> Maintenant, cliquer sur le fichier .reg afin d'ajouter la section "FxProperties" à la clé.
7) Redémarer
Voilà, maintenant, dans les périphériques de lecture, sur les propriétés de l'EMU ou de la X-Meridian, vous devriez voir l'onglet Améliorations avec entre autres la "Correction de pièce" (voir copie écran ci-jointe).
Bon tests.
