Type : Ampli intégré
Marque : Onkyo
Model et options : TX SR 875
Prix de vente : 1200 €
Département où la marchandise est visible : 93
Montant des frais d'expédition : compter environ 50€ via Transporteur
Date et lieu d'achat : Juillet 2007
Site web du constructeur : http://www.eu.onkyo.com/products/product_en_2008_5875659.html
ADVANCED FEATURES
* THX Ultra2 Certified (with THX Processing)
* DTS-HD Master Audio, DTS-HD High Resolution Audio, Dolby TrueHD, Dolby Digital Plus Decoding
* VLSC (Vector Linear Shaping Circuitry) for All Channels
* HQV Reon-VX Video Processing
* HDMI (v. 1.3a) Audio and Video Processing (4 Inputs and 1 Output)
* HDTV-Capable HDMI Switching
* HDTV-Capable (100 MHz) Component Video Switching (3 Inputs and 1 Output)
* HDMI Upscaling and Upconversion
* Component Video Upconversion
* Burr-Brown 192 kHz/24-Bit Audio DACs (PCM1796) for All Channels
* Three TI Aureus™ 32-Bit DSP Chips for Advanced Processing
* Bi-Amping and BTL (Bridged Transless) Capability for Music and Movie Sound Effects
* Audyssey MultEQ XT to Correct Room Acoustic Problems and to Calibrate Speakers
* Powered Zone 2 (Audio and Video); Zone 2 and Zone 3 Pre Outs; Independent Control for Volume, Balance (Zone 2 and Zone 3) and Bass/Treble (Zone 2 Only)
* Neural-THX® Surround Technology for Gaming, Movies and Broadcasting
* Onkyo RIHD (Remote Interactive Over HDMI) for System Control (Works with Certain Key Functions of Panasonic's VIERA Link)
* Compatible with RI (Remote Interactive) Dock for the iPod
AUDIO FEATURES
* 200 W/Ch Minimum into 6Ù, 1 kHz, IEC (1 Channel Driven)
* DTS®-ES™ Discrete/Matrix, DTS® Neo:6, DTS® 96/24, Dolby® Digital EX™, Dolby® Pro Logic IIx
* H.C.P.S. (High Current Power Supply) Massive High Power Transformer
* WRAT (Wide Range Amplifier Technology)
* 6 Digital Inputs (3 Optical/3 Coaxial) and 1 Optical Output
* A-Form Listening Mode Memory
* Linear Optimum Gain Volume Circuitry
* Non-Scaling Configuration
* Tone Control (Bass/Treble) for All Channels
* Color-Coded 7.1-Multichannel Inputs and Pre Outs
* Independent Crossover Adjustment for F/C/S/SB40/50/60/70/80/90/100
/120/150/200 Hz)
* Double Bass Function
VIDEO FEATURES
* 6 S-Video Inputs and 2 Outputs
* 6 Composite Video Inputs and 2 Outputs
* Front Panel Auxiliary Input (for Camcorders, Game
Consoles, etc.)
OTHER FEATURES#
* Color-Coded Dual Banana Plug-Compatible Speaker Posts
* Pure Audio Mode
* A/V Synchronization Function (Up to 250 ms in 5 ms Steps)
* 40 FM/AM Radio Presets
* RDS (PS/RT/PTY/TP)
* Onscreen Display
* RS232 Port
* IR Input and Output
* 12 V Trigger
* 6 A/V Inputs and 1 Output
* 2 Audio Inputs and 1 Output
* Phono Input
* Direct Mode
* IntelliVolume
* Late Night Mode (High/Low/Off)
* Headphone Jack
* Aluminum Front Panel
* Preprogrammed RI (Remote Interactive) Learning Remote Control with Macros and Mode-Key LEDs
10 messages • Page 1 sur 1
[Vds] Ampli Onkyo TX SR 875
- ephisio
- Inscription Forum: 03 Nov 2006 11:46
Garantie ?
Adhérez à l'association pour que le site progresse : http://www.homecinema-fr.com/asso.php/
- frahlt
- Membre d'Honneur
- Inscription Forum: 05 Mai 2006 4:29
déjà....
tu viens a peine de remplacer ton yam. 3800.... , toujours pas satisfait sur tes klipsch....?
- zebulons69
- Inscription Forum: 18 Juil 2002 21:51
Coucou, j'ai tjr mon yam 3800, c'est le 875 de mon meilleur ami, qui désire aussi monté en gamme! donc je lui laisse le soin de répondre a chacun d'entre vous.
Je reviens a peine de vacance avec 6h de décallage! je me remet tranquillement
- ephisio
ephisio a écrit:Coucou, j'ai tjr mon yam 3800, c'est le 875 de mon meilleur ami, qui désire aussi monté en gamme! donc je lui laisse le soin de répondre a chacun d'entre vous.
ok...
- zebulons69
frahlt a écrit:Garantie ?
- frahlt
- Membre d'Honneur
bonjour,
je regarderai dans mes papiers car je ne sais plus s'il est garanti 2 ans ou 3 ans constructeur, disons 2 dans le pire des cas et 3 dans le meilleur, enfin quoi qu'il en soit il est dans un état impeccable et encore sous garantie
- ephisio
Merci. C'est une précision importante !
- frahlt
- Membre d'Honneur
Toujours d'actualité ?
- frahlt
- Membre d'Honneur
10 messages
