Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: morgan07, shoowie et 54 invités
Petites annonces pour Préamplificateurs HC multi-canaux.
LEXICON MV5 echangé
pour 120€ de plus je peu rajouter un switch hdmi ---> analogique 7.1 pour qu'il accepte le true hd et autre codec hd en direct sans passer par le lpcm
- stef12eme
- Inscription Forum: 24 Aoû 2007 21:33
Hello
c quoi ce switch au juste? ..ca pourrait m'interesser
- speedy_92
- Inscription Forum: 19 Jan 2006 0:39
# HDMI 1.3 Compliant
# HDCP Compliant
# Bulit-in 2x1 HDMI switch
# HDMI video supports up to 1080p@36 bit RGB/YCbCr
# Scalable HDMI 1.2/1.3 Output with HDMI 1.3 Input
# Maximum Output Pixel Clock 165MHz
# Maximum TMDS Input Clock 225MHz
# Maximum Output Bus Width 36 bit
# Loop Though HDMI output
# 7.1 Analog Audio Output
# 5.1 SACD Digital Output
# Stereo S/PDIF RCA/Fiber Output
# DTS-HD, Dolby TruehHD High Bitrate Audio Support
# Front panel LED indicators and push button
# EDID learning
The CV-505 2x1 HDMI v1.3 Switch & 7.1ch Audio Extractor offers the highest compatibility to HDMI 1.3 in the market. This unique device supports the separation of high quality audio such as DTS-HD and Dolby TrueHD from the incoming HDMI signal and make HDMI audio more friendly to your expensive audio systems. Plus, the high bit rate HDMI 1.3 data can be scaled down the color depth, which is compliant to HDMI 1.2/DVI 1.1, to ease the limitation of the transmission distance and gain higher compatibility to the display without noticeable video degradation. To broaden the spectrum of HDMI audio output, high quality 7.1 analog audio and 5.1 digital Super Audio CD (SACD) outputs come with this mini converter. Furthermore, stereo S/PDIF with TOSlink and RCA connector are also seamlessly integrated into this adapter.
CV-505 is designed to enrich your full digital video and audio experiences at the least expense in a smoothest way. With built-in HDMI switch, this adapter is able to easily switch between HDMI home theater devices and PC DVI devices.
- stef12eme
maj de la description en page 1
- stef12eme
echangé, on peut fermer
- stef12eme
20 messages
• Page 2 sur 2 • 1, 2
Retourner vers Préamplificateur HC
