Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Emmanuel Piat, J3FF, kyron, michelB2, phil30, sbk2010 et 95 invités
Reclock 1.8.6.1 by Slysoft
Message » 09 Jan 2010 12:08
Edit: sortie de la 1.8.6.1:
pbmtp a écrit:Je relance d'une version avec le resampler multithreadé :)
http://sandbox.slysoft.com/beta/SetupReClock1861.exe
1.8.6.1 - 20/01/2010
* New: New quality settings for resampler
* New: Improved quality of resampler
* New: Resampler is now multi threaded
* New: All non-pcm formats are now accepted as bitstream formats
* New: VBS scripts are started from a separate thread, playback will not stop while your script is executed.
* New: Added debug registry value AC3_48k_only. Set it to 1 to instruct ReClock only to use the AC3 encoder on 48k PCM sources.
* New: Added debug registry values ChannelMaskOverride_x for PCM formats, where x stands for the number of channels.
Example: Set ChannelMaskOverride_6 to 0x60f to override the channel mask for 6 channel PCM to use the side speakers, or set it to 0x3F to use the back speakers for the rear channels.
A value of 0 disables channel mask override (default). These are the definitions of the speaker positions:
SPEAKER_FRONT_LEFT 0x1
SPEAKER_FRONT_RIGHT 0x2
SPEAKER_FRONT_CENTER 0x4
SPEAKER_LOW_FREQUENCY 0x8
SPEAKER_BACK_LEFT 0x10
SPEAKER_BACK_RIGHT 0x20
SPEAKER_FRONT_LEFT_OF_CENTER 0x40
SPEAKER_FRONT_RIGHT_OF_CENTER 0x80
SPEAKER_BACK_CENTER 0x100
SPEAKER_SIDE_LEFT 0x200
SPEAKER_SIDE_RIGHT 0x400
SPEAKER_TOP_CENTER 0x800
SPEAKER_TOP_FRONT_LEFT 0x1000
SPEAKER_TOP_FRONT_CENTER 0x2000
SPEAKER_TOP_FRONT_RIGHT 0x4000
SPEAKER_TOP_BACK_LEFT 0x8000
SPEAKER_TOP_BACK_CENTER 0x10000
SPEAKER_TOP_BACK_RIGHT 0x20000
* New: Added debug registry value NotifyOnGreen. Set it to 0 if you don't want your script to be called with GREEN notifications
* New: Added debug registry value NotifyOnStop. Set it to 0 if you don't want your script to be called with STOP notifications
* New: Added debug registry value NotifyOnQuit. Set it to 0 if you don't want your script to be called with QUIT notifications
* Change: Audio only playback uses the specified buffer duration, but it can be set independently with the registry value AudioOnlyPrebuffTime.
* Fix: ReClock could hang, if the Wasapi buffer ran empty or overflowed.
* Fix: Bitstream passthrough was really broken
* Some fixes and improvements
Reclock 1.8.5.5 by Slysoft
Lien internet: http://forum.slysoft.com/showthread.php?t=19931
Lien de téléchargement: http://www.free-codecs.com/ReClock_Dire ... wnload.htm (Pas dispo pour le moment :-? )
Par contre il n'y a rien sur le site de Slysoft, Reclock n'est pas présenté.
Changes in ReClock DirectShow Filter 1.8.5.5 beta :
- New: Added "audio only" mode, no part of the prebuffer will be skipped
- New: Added option to prohibit loading of ReClock without showing the application dialog, if an application isn't configured in the list
- Fix: Manually setting a sample rate different to the input rate could cause the audio hardware fail to initialise
Changes in ReClock DirectShow Filter 1.7 beta 9 :
- Change: Some tweaks to hardware detection
- Change: Expiry date changed to December 2008
- Change: Method triggering DisplayChange() if RunEvent.vbs returns 0
- Fix: AC3 encoder didn't work correctly, if hardware resampling was previously enabled
- Some fixes and improvements
En bon Francais, quels changements depuis la reprise de reclock par Slysoft ?
Merci :wink:
kbil69
Message » 09 Jan 2010 12:59
Voir même encore mieux la 1.8.5.6
http://forum.slysoft.com/showthread.php?t=37426
1.8.5.6 - 07/01/2010
* Change: Removed "original speed x0.66"
* New: Improved IEEE float / PCM conversion, most conversions will be bit exact
* New: Added "original speed x0.96" which can be used to demonstrate the PAL speedup difference
* New: Added "24 bit PCM padded to 32 bit" to PCM output formats
* Fix: Possible memory access violation
pbmtp
Inscription Forum: 04 Mai 2008 19:50
Message » 09 Jan 2010 13:01
Qui dit mieux :mdr: :wink:
kbil69
Message » 10 Jan 2010 1:24
Moi.
Reclock 1.8.5.7
1.8.5.7 - 09/01/2010
* New: Pure audio mode uses fixed pre-buffer size of 100ms
* Change: Relaxed "bit exactness" display
* Change: Removed "24 bit PCM padded to 32 bit" from PCM output formats
* Change: IEEE float / PCM conversions
* Change: Resampler normalizes to avoid clipping
http://sandbox.slysoft.com/beta/SetupReClock1857.exe
Xavier.
tobal
Inscription Forum: 13 Sep 2001 2:00
Message » 10 Jan 2010 1:38
Ce qui me fait rire avec tout ces softs, c'est la mise à jours toutes les 48hrs, je ne comprends pas trop leur principe :mdr:
kbil69
Message » 10 Jan 2010 20:07
En gros ca vaut le coup de passer à une de ces versions récentes ?
Lajet
Inscription Forum: 28 Fév 2008 0:07
Message » 11 Jan 2010 11:09
Bonjour à tous et pour ceux qui sont pas pro comme moi ça apport quoi de vraiment NOUVEAU ces versions ?
ocean_78
Inscription Forum: 09 Mar 2006 13:29
Message » 11 Jan 2010 13:30
J'en sait rien j'ai pas testé , mais bon a part deux trois petites options le fonctionnement du logiciels est toujours le même .
AlexScan
Inscription Forum: 27 Déc 2005 20:57
Message » 11 Jan 2010 15:20
je pense que c'est le resampler qio doit changer le plus souvent dans les nouvelles versions.
lulu78fr
Inscription Forum: 20 Oct 2001 2:00
Message » 11 Jan 2010 16:33
Guy59
Inscription Forum: 04 Mar 2007 17:13
Message » 11 Jan 2010 20:15
Où se trouve Le pure audio mode et l'option set machin speaker configuration for pcm sound il y a un avantage ?
Kaotech
Inscription Forum: 02 Aoû 2006 11:46
Message » 12 Jan 2010 0:25
reclock passe automatiquement en pur audio mode lorsqu'il ne détecte pas de piste vidéo
pbmtp
Message » 12 Jan 2010 0:58
bien
manureva45
Inscription Forum: 07 Oct 2004 21:07
Message » 12 Jan 2010 11:46
Quand j'ai coché la case "set machin speaker configuration for pcm sound", j'ai l'impression que le son est plus aéré que d'habitude.
Je n'ai fait que 2 aller retour avec et sans. Je retesterais à l'occasion sur un live.
Kaotech
Message » 12 Jan 2010 15:49
La tu m'intéresse si il y a une amélioration du son ...
AlexScan
