Type : Préampli
Marque : EAD
Modèle et options : Ovation couleur noir
Prix de vente : 800
Département où la marchandise est visible : 68
Montant des frais d'expédition : 25
Première main : non
Prix neuf : très très cher
Facture disponible : Lettre de cession
Date, pays et lieu d'achat : US 2008
Numéro de série :
Description générale : Dolby Digital® 5.1-channel surround sound: Provides 5 channels of full-range information, plus a dedicated subwoofer channel, to achieve truly holographic surround-sound effects.
· DTS Digital Surround(TM) 5.1-channel surround-sound technology provides ultra-high resolution playback suitable for both movie and audiophile-quality multi-channel music playback.
· Pro Logic®: Dolby Pro Logic decoding is performed with mathematical precision in the digital domain.
· MPEG2 Digital Audio: Automatic decoding of MPEG1 and MPEG2 bitstreams into two-channel PCM for stereo or Pro Logic processing.
· HDCD®: The HDCD process was designed to match the ultimate resolving power of the human ear, while maintaining compatibility with the existing 16-bit CD format.
· Flexibility and simplicity: TheaterMaster provides the combined functions of a consummate-quality stereo D-to-A converter, state-of-the-art surround-sound processor, transparent pre-amplifier, all integrated into one, simple-to-use system.
· Large front-panel display: Vacuum fluorescent display provides ergonomic user interface.
· State-of-the-art precision 20-bit CS5390 5th-order delta-sigma A-to-D converter provides exceptional transparency when using analog inputs.
· Six precision Burr Brown PCM1702 "Series K" 20-bit DACs provide exceptional low-level linearity and dynamic range, with a guaranteed THD and noise level below -96 dB. Teflon DAC's with Vishay resistors.
· AccuLinear® analog circuitry provides superior reconstruction of the musical waveform, resulting in reduced transient distortion--a principal cause of harshness, glare and stridency.
· Teflon analog circuit board ensures maximum transparency with low "dielectric signature".
· Ultra-premium passive components, including 0.1precision Vishay metal foil resistors.
· Balanced stereo outputs utilize separate DACs for and - polarity to achieve the lowest possible THD and greatest signal-to-noise ratio.
· Auto Setup(TM): This remarkable software greatly simplifies TheaterMaster setup by providing automatic speaker level balancing, calibration of speaker delays, and a readout of absolute and relative speaker phase.
· Built-in, audiophile-grade, high-order digital crossover network utilizing dual Zoran® 38600 decoding computers provides highest possible performance with maximum system flexibility.
· Full-function, programmable back-lit touch-screen IR remote with tactile keys for commonly used functions offers total system control.
· Dialogue Normalization readout for the professional user.
· Remote volume control utilizes switched resistive array for ultimate transparency.
· Six digital and six analog audio inputs, including 1 ST glass, 4 Coaxial S/PDIF, and 1 TOSLINK.
· Tape monitor outputs (both analog and digital) provide maximum system flexibility.
· RS-232 controllable, for integration into sophisiticated home theaters and/or home automation systems.
Site web du constructeur :
9 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: cocogex, couscous, Fafa, kroliv et 43 invités
Petites annonces pour Préamplificateurs HC multi-canaux.
- BA
- Inscription Forum: 10 Mar 2000 2:00
- BA
bonjour de quelle année est le EAD ?
est il en 230 Volts ?
- jazz891
- Inscription Forum: 13 Fév 2010 20:01
oui 230v, l'année, j en sais rien mais c est une bonne question, pourquoi cette question ?
- BA
pour savoir s'il à beaucoup servi ou pas
- jazz891
Si tu veux, ce genre de préampli ce n est pas comme un lecteur CD ou autre appareils avec des éléments en mouvements et des éléments d usure et vu comme il est construit, tu peux être serein
EN résumé il peut avoir servi 24 millions d heures (ce qui n est pas son cas ) il fonctionnera parfaitement.
- BA
quant pense tu avec un bloc EDGE GAV que je possede et une source Esoteric
- jazz891
9 messages
Retourner vers Préamplificateur HC
