Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: drgori, imago01, papounay, spydex et 48 invités
Dune HD TV-303D
Message » 07 Déc 2012 13:50
Dune HD TV-303D is the most universal solution for Full HD video and audio playback as well as IPTV and VOD streams via the new Dune HD Portal. Supporting most all digital audio and video formats, codecs and file containers, including all modern 3D video standards such as MVC, SBS and Top/Bottom, audiophile uncompressed HD audio with high resolutions up to 24 bit /192 kHz, the Dune HD TV-303D sets an entirely new standard. Like previous model, TV-303D is equipped with an internal 2.5” SATA HDD bay with hot swap function.
Key Features
3D Video Format Support: Decodes wide variety of 3D Video formats, including MVC, SBS, Top/Bottom.
HDD Player: Plays content from any HDD (internal, NAS or USB)
Network Player: Connect Dune HD player to a local network and play content directly from PC or NAS via UPnP, SMB, or NFS.
MKV Player: Playback HD and SD video in MKV containers and other modern video file formats, including top quality HD video with very high bit-rates > 50Mbp/s.
USB Ports: Conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices without a USB hub.
HDD Rack Option with Hot Swap Function: Easily and quickly insert and exchange internal 2.5’’ SATA HDDs for nearly unlimited storage capacity expansion.
HDMI 1.4: Ensures broad compatibility to the very latest 3D TV’s, displays and projectors.
Full Range of A/V Connectors: S/PDIF Optical Audio output, Analog Stereo Audio output, HDMI output, Composite Video output.
High-Quality Music Playback: Plays very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey’s Audio APE, WAV/PCM, DTS, etc).
Playlist Support: Build playlists from folders, use your own play lists with repeat and shuffle functions.
Video Output Flexibility: Output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC).
Video Up-Scaling: High quality up-scaling of DVD and any other SD video content to Full HD (1080p) or other HD resolutions.
File Browser: Convenient file browser with powerful file management (copy, move, delete, rename, organize, sort).
Extra Functions
External NAS Support: Access files on any external storage devices (HDD, optical drive, etc) attached to the player from the local network (using SMB or FTP).
Customizable User Interface: Work with media collections using cover art and icon browsing (supports Full HD graphics).
Flash Applications: Extend player functionality with FlashLite applications.
Internet Radio: Playback and record various Internet radio stations.
IPTV: Playback and record IPTV streams.
Internet Browsing: View Internet web sites on your TV using the built-in web browser.
Specification
Processor: Sigma Designs 8672/8673
RAM: 512 MB
Flash memory: 256 MB + 4 GB
Connectors: HDMI 1.4, 2x USB 2.0 (1x rear, 1x side), composite, component, analog stereo outputs, optical S/PDIF, coaxial SPDIF, USB 3.0 slave, Ethernet 10/100/1000 Mb/s, Wi-Fi 802.11n, SD card slot (side), power input, power switch (back), LED indicator (front)
Internal storage: Internal HDD rack with hot swap function for SATA HDD 2.5". USB 3.0 slave interface and provided USB 3.0 (slave-host) cable allow fastest possible way of transferring data between PC and player
Media sources: external HDD (USB), external optical drive (USB), USB devices (USB flash drive, USB card reader, etc), built-in SD card reader (SD/SDHC), PC and NAS in local network (SMB, NFS, UPnP, HTTP), other Internet and local network media sources (HTTP, multicast UDP RTP)
Web Browser: Opera, WebKit
DLNA: DLNA (1.5 or 2.0) client support
Adobe Flash: 3.1 (Lite, standalone) supported
DRM options: PlayReady, Verimatrix, Secure Media. Other DRM can be added by request
Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264; support for very high bitrate video (up to 50 MBit/s and higher)
Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, BDMV, DVD-ISO, VIDEO_TS
3D Video Support: MVC, Side-by-side, Top/Bottom
Video output modes: wide range of supported output resolutions (up to 1080p) and framerates (including 23.976p, 24p, PAL, NTSC)
Video output framerate: automatic (according to the played content) and manual
Audio codecs: AC3 (Dolby Digital), DTS, MPEG, AAC, LPCM, WMA, WMAPro, FLAC, multichannel FLAC, Ogg/Vorbis; support for very high quality audio (up to 192 kHz / 24-bit)
Audio file formats: MP3, MPA, M4A, WMA, FLAC, APE (Monkey’s Audio), WV Pack, Ogg/Vorbis, WAV, AC3, AAC
Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, external SUB/IDX), PGS (Blu-ray, TS, MKV)
Hardware 3D Graphics Acceleration: OpenGL support
Picture file formats: JPEG, PNG, BMP, GIF
Playlist file formats: M3U, PLS
Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle Audio playback functions: browse playlist, repeat, shuffle, ID3 tags, plasma TV burn-in prevention
Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3/EXT4 (read-write), NTFS (read-write)
Ethernet: 10/100/1000 Mb/s
Wi-Fi: Internal Wi-Fi (b/g/n) module
Dune Network Playback Accelerator: special optimizations ensuring best-in-class network playback performance for the Sigma Designs 864x-865x-867x platform and enabling smooth playback of any supported kind of media content via any network protocol (including NFS and SMB) even in 100 Mbit/s Ethernet networks.
http://dune-hd.com/eng/products/full_hd ... players/36
Christophe CHEREL
Pro-Fabricant
Pro-Fabricant
Inscription Forum: 06 Juil 2001 2:00
Message » 08 Déc 2012 4:25
J avoue que je m y perd un peu avec la nouvelle gamme de DUNE.
103 = modele basique
203 = tuner tnt
303 = pas de tuner tnt
403 = double tuner tnt
Etonnant qu un modele "superieur" au 203 , comme le 303 n offre pas la possibilité de regarder la TNT , alors que le modéle inférieur le peut.
J ai cherché un tableau pour ces 4 modéles, listant leur différerences, mais impossible a trouver.
J'ai actuellement une C-200 mais j aimerais un systeme plus complet, avec tuner tnt intégré, et systeme de jaquette zapitti.
Donc, si j ai bien regardé les caractérisques, une 203 ou une 403.
kisscool
Inscription Forum: 15 Déc 2001 2:00
Message » 10 Déc 2012 11:31
Pour l'instant il y a la 101-102-301 et 303D, rien d'autre.
C'est la 102 qui a l'option tuner pour l'instant.
costaud
Contributeur HCFR 2019
Inscription Forum: 05 Oct 2004 20:51
Message » 10 Déc 2012 15:07
costaud a écrit:Pour l'instant il y a la 101-102-301 et 303D, rien d'autre.
Et la 103 qui ne l aura pas :o . Vraiment étrange leur évolution de gamme.. Mais si j ai bien tout lu, celle qui me faut sera la 403.
kisscool
Message » 10 Déc 2012 15:58
Il n'y a pas de 103 pour l'instant mais une 102 :o :ane:
costaud
Message » 10 Déc 2012 16:15
costaud a écrit:Il n'y a pas de 103 pour l'instant mais une 102 :o :ane:
Oui, je parle de la nouvelle gamme qui sort d ici peu , suite a l IFA.
kisscool
Message » 10 Déc 2012 16:28
La 102 est de la nouvelle gamme aussi :wink:
costaud
Message » 10 Déc 2012 16:34
il me semblait que les x02 étaient réservées aux providers ?
Mr Eric
Message » 10 Déc 2012 16:39
Oui il me semble aussi.
costaud
Message » 10 Déc 2012 16:56
costaud a écrit:La 102 est de la nouvelle gamme aussi :wink:
Ca risque en effet de compliquer les références, car la 102 existe avec ou sans le tuner TNT.
Sinon, pour en revenir à la 303, niveau 3D elle supporte le TB et SbS comme la précédente gamme, mais au niveau des résolutions, on a le Full TB/SbS à présent ?
Le MVC 3D, c'est quoi finalement ? C'est un MKV 3D ou de l'iso Bluray ??
En tout cas la platine ne supportera pas le Java comme la gamme de l'année d'avant (et comme la Dune HD Base 3D à priori, pas de lecteur Bluray interne, pas de Java/Cinevia).
dem1980
Inscription Forum: 24 Jan 2005 15:57
Message » 10 Déc 2012 17:11
Le MVC 3D c'est le format dans les BD 3D il me semble, mais comme je m'en tape de la 3D, je me trompe peut être :mdr:
costaud
Message » 12 Déc 2012 14:35
Bien le bonjour.
Gandalflux
Inscription Forum: 07 Avr 2008 23:03
Message » 12 Déc 2012 14:45
gné ? :wtf:
Mr Eric
Message » 14 Déc 2012 9:38
je suis impatient de voir quand et à quel prix ce ptit joujou va sortir !
j'ai eu une popcorn C200 dans les bras pendant 2 ans et j'ai toujours eu des soucis avec, pb de lecture 24p, reset HDMI, pb de sub, freeze réseau, etc..
de mon coté, je ne suis pas encore passé 3D, mais c'est surtout la stabilité et le support des nombreux formats ( et l'autoframe rate ) qui va compter.. et un prix raisonnable !!
j'ai cherché dans de nombreuses boutiques en ligne ( via le site officiel, en europe), rien d'annoncé !!
goodz31
Inscription Forum: 12 Avr 2011 11:08
Message » 14 Déc 2012 18:07
goodz31 a écrit:je suis impatient de voir quand et à quel prix ce ptit joujou va sortir !
J ai une dune TV 101. Elle n'a jamais été capable de décoder des flux HD audio.
A l'époque, elle avait pourtant été vendu comme une des rare box multimedia décodant le DTS HD et le DolbyHD ... retiré depuis de ses spécifications chez dune-hd.
Au moins les spécifications de cette 303 chez dune-hd sont claires, elle ne decode que le DTS et le Dolby simple.
On est donc encore loin de la box parfaite...
benhur_C6
Inscription Forum: 04 Juil 2010 8:32
