Type: Subwoofer
Marque :Emotiva
Modèle et options : X-Ref 12
Prix de vente :EUR 450.-
Département où la marchandise est visible : Suisse (Fribourg)
Possibilité d'expédition: non
État de la marchandise :parfait
Prix neuf : EUR 699.-
Facture disponible : oui
Date, pays et lieu d'achat : 31 juillet 2012 USA
Garantie et date d'expiration :GARANTIE EMOTIVA 31 juillet 2017
Emballage d'origine conservé :OUI
Description générale : Le produit est en parfait état, je le change car je me suis trouvé un petit velodyne dd10
The all-new X-Ref 12 takes low frequency extension and total system output to truly subterranean levels. For the serious home theater enthusiast who demands the ultimate low frequency experience, the X-Ref 12 was made for you.
This amazing subwoofer produces incredibly deep, powerful, and clean bass; providing the bedrock of a truly impressive home theater experience, all the while maintaining the musical accuracy, detail, bandwidth, and transient response necessary to integrate seamlessly into a true audiophile music system.
The high-efficiency 600-watt RMS amplifier and high-current-density switch-mode power supply give the X-Ref 12 awesome power reserves, while an advanced DSP control system optimizes its performance in virtually any room.
There's no longer any reason to settle for a hard-hitting home theater sub that frankly just doesn't sound very good, or for a musical sub that can't deliver on sound effects; with the X-Ref 12 you can have the best of both worlds.
The X-Ref 12. The Bedrock.
FEATURES
Extremely powerful, smooth, and extended bass with excellent transient response in a compact package.
Advanced DSP management system with easy to read backlit LCD display and rotary encoder input.
Fully configurable two-band parametric equalizer for optimal flexibility and precise room matching (variables: Q, frequency, gain).
Accurate and repeatable selection of crossover points in 1 Hz increments, phase correction in 45-degree increments, and EQ settings in 1 dB increments.
Remote EQ feature automatically selects Music or Movie EQ modes with external trigger from processor/preamp or receiver.
Powerful, 600-watt RMS high-efficiency amplifier with high current density switch-mode power supply.
Professional balanced (XLR) and unbalanced (RCA) input connections.
Front firing cabinet to simplify placement options and minimize room interactions.
Sealed cabinet design with extensive cross bracing and internal damping produce excellent transient behavior with no port noise.
Rigid die-cast woofer frame with massive 3" vented motor assembly.
12" long-throw woofer design with woven tinsel leads for low distortion and high reliability.
Proprietary para-aramid blended fiber cone for high rigidity, accurate low frequency response, and minimal breakup.
Heavy-duty, large diameter synthetic Butyl rubber half roll surround.
Sophisticated, digitally-based dynamics processing for optimal system performance.
Elegant, digital soft limiting leaves musical peaks untouched while protecting the system from dangerous overloads.
Includes both aluminum spikes and non-marring rubber feet.
Removable grill.
Hand rubbed studio black satin lacquer finish.
REFERENCE
Reviews
Secrets of Home Theater and High Fidelity (March, 2012)
Audioholics video review (February, 2012)
Sound + Vision (December, 2011)
Audioholics (December, 2011)
Manuals
X-Ref 12 Owner's Manual (PDF)
Accoustic Response Charts:
With all filters set to flat
With Movie EQ engaged
Example EQ Responses
Using parametric EQ 1
Using parametric EQ 2 - settings shown in red
Using parametric filters 1 & 2 - settings shown in red
6 messages • Page 1 sur 1
[SUSPENDU] Subwoofer Emotiva X-Ref 12
- EdelweissCH
- Inscription Forum: 22 Avr 2012 19:11
Supervisé…
- opbilbo
6 messages
