Le nouveau pré_proç HC 11.2 canaux Marantz AV7705 est arrivé.
A l'image de son prédécesseur 7704, il met en oeuvre l'applet Audyssey et est certifié "IMAX Enhanced Technology"...
... qu'est-ce l' "IMAX Enhanced Technology"? et un premier élément de réponse :
vers-l-ultra-hd/imax-enhanced-t30089986.html
http://us.marantz.com/us/Products/Pages ... tId=AV7705
Key Features
- 11.2 channel XLR pre-out; 11.2 channel RCA pre-out
- 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support; 3 HDMI outputs (incl. Zone 2)
- 4K/60 Hz full-rate pass-through, Dolby Vision compatibility, HDR, HLG and BT.2020
- Advanced video processing with analog to HDMI conversion; SD to HD/4K upscaling
- Dolby Atmos, DTS:X (up to 7.1.4 with an external 2ch amplifier), Auro-3D and DTS Virtual:X for height virtualization effects
- eARC (Enhanced Audio Return Channel) support via firmware update supports the most advanced surround and object-based audio formats via single HDMI connection between AVRs and compatible TVs
- Stream music from Internet Radio, Spotify Connect, Pandora, SiriusXM, Amazon Music, TIDAL, Deezer and more with Bluetooth, Airplay2 or HEOS built-in
- Built-in Wi-Fi with 2.4GHz/5GHz dual band support
- Enjoy multi-room whole-home audio streaming with HEOS technology
- Amazon Alexa voice control via the HEOS Home Entertainment skill
- Marantz 2016 AVR remote app for control over the latest generation of Marantz network AV Receivers. Available on iOS and Android.
- High resolution DSD (2.8/5.6MHz), FLAC, ALAC and WAV support
- AKM AK4458 32-bit D/A converters, HDAM circuit boards and Current Feedback circuitry for optimum fidelity and maximum dynamic range
- Suite of Audyssey room correction software: Audyssey MultEQ XT32, Dynamic Volume and Dynamic EQ, LFC and Sub EQ HT
- Third-party integration and IR remote control, RS-232C serial port and Creston Connected for external control
- Seamless out-of-the-box experience with Quick Start Guide, guided Setup Assistant and Marantz AVR Remote App
- lien vers le mode d'emploi (en Anglais) : http://us.marantz.com/DocumentMaster/US ... 082018.pdf
Prix public : 2199€, dispo début Octobre.
Hugo
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: blooddiurne et 33 invités
Marantz AV7705 - pré_proç HC 11.2 canaux, applet Audyssey
- Hugo S
- Membre d'Honneur - Président de l'Association & Relations PROs
- Inscription Forum: 04 Mai 2000 2:00
Tu as vu que d' après Marantz US, le 8805 serait également " Imax enhanced"
Mise à jour à venir ? bien que cette fonction me semble nébuleuse pour le moment
http://us.marantz.com/us/Products/Pages ... tId=AV8805
- Chewee Levelu
- Inscription Forum: 25 Aoû 2010 9:38
C'est plus un label de qualité qu'une fonction de ce que j'ai compris. Cela indiquerait que l'appareil est compatible dolby vision etc...
Envoyé de mon Redmi 5 Plus en utilisant Tapatalk
- DTSman
- Contributeur HCFR 2022
Tu as raison, j' ai lu un peu vite
Le site : https://www.imaxenhanced.com/ et j' ai ouvert un post dans les "normes" vers-l-ultra-hd/imax-enhanced-t30089986.html
- Chewee Levelu
Le post 1 a été màj avec :
1- Prix public : 2199€
2- la dispo, début Octobre.
D'autre part, on devrait avoir des précisions quant à la notion de "IMAX Enhanced Technology" au début de la semaine prochaine @ 17 Sep.
Hugo
Hugo
- Hugo S
cc il me titille celui la , mais j hésite avec le 8802A , ils sont tout les deux au même tarif . le 8805 il y a quand meme une grosse différence de prix , je sais pas si elle est justifié
- fafa0512
- Inscription Forum: 12 Juil 2014 19:02
voila il est commandé , un peut plus de 1800 euro sur iacono
- fafa0512
fafa0512 a écrit:cc il me titille celui la , mais j hésite avec le 8802A , ils sont tout les deux au même tarif . le 8805 il y a quand meme une grosse différence de prix , je sais pas si elle est justifié
Personnellement je partirai plutot sur le 7705 plutot que le 8802A pour deux choses:
- compatiblité avec les dernières normes comme l'Auro3D
- et surtout compatiblité avec l'application MultEQ editor qui apporte un plus à l'égalisation Audyssey
- DTSman
fafa0512 a écrit:voila il est commandé , un peut plus de 1800 euro sur iacono
Ne manques pas de nous faire un retour. Tu seras surement le premier proprio du forum
- DTSman
j’ai bien aimé la phase interrogation qui se conclu par un achat 1h après
je suis pas le seul à être fou
- nolem
- Inscription Forum: 23 Oct 2007 19:08
hihi oui ,rare que je me décide aussi vite . la promo fini demain matin a 8h
j ai surtout fais comme ca pour de pas craquer et rester raisonnable et prendre le 8805
même pas sorti que déjà une promo , le 8802 est deja plus ancien et le 8805 même a 3400 reste bien plus cher , et j aurais pas forcement besoin des deux voies de plus
- fafa0512
DTSman a écrit:fafa0512 a écrit:voila il est commandé , un peut plus de 1800 euro sur iacono
oui ,il va remplacer un onkyo 3008 qui me sert uniquement de preampli pour mes chevin
oui c'est pour cette raison que je suis pas parti sur le 8802A tu as dis tout juste ce que je pensais
- fafa0512
bonjour,
quelqu'un sait qu'elles sont les principales différences avec le 8805 qui justifient le double de prix ?
Par avance, merci
Par avance, merci
- THX72
- Inscription Forum: 05 Juil 2002 13:42
THX72 a écrit:bonjour,
Par avance, merci
Sur le post du 7705 du forum AVS il ya les différences avec le 7704 et 8805 :
AVS Forum a écrit:What's new or to be added via firmware update?
- Able to overlay the Volume, Info, and Option menus on 4k video (including Dolby Vision) while Setup takes up whole page on black background
- RESET - Menu setting that restores all settings to factory default (in addition to usual 2 button + power on reset)
- Airplay 2 (via future firmware update on all current and former HEOS capable models)
- Web Control (reintroduced for the first time on HEOS models)
- <Dialog Level> setting more appropriately relabeled as <Center Level> as it simply adjusts the volume level of the center speaker
- <Center Level> (formerly Dialog Level Adjust) and <Subwoofer Level> (formerly Subwoofer Level Adjust) no longer have ON/OFF setting, but rather simply mirror the Center/Subwoofer Manual Setup - Levels - Test Tones settings such that they can be adjusted on the fly now correctly as opposed to being in addition to the Manual Setup settings on previous year's models
- “ihiji Invision” and Domotz Pro remote system management technology
- eARC (via future firmware update - also AV7704)
IMAX enhanced DTS:X processing - firmware update early 2019)
What was dropped from the AV7704?
- Circle indicator on front panel display when "HEOS Music" source is playing
- Smart Select initial volume no longer defaults to an initial value (ie. previously 40 but now must be set by the user)
What does the AV8805 offer beyond the extra 2CH processing capability vs. the AV7705?
- Mfr'd in Japan
- Overall better quality construction and design resulting in lower noise and distortion.
- AKM AK4490EQ DAC vs. AKM AK4458VN for the AV7705, resulting in a 5dB increase in SNR for the DAC in the AV8805.
- Toroidal transformer
- Future HDMI 2.1 hardware upgrade (summer 2019?) to increase lifespan by supporting 8K resolution and more (similar to the "A" upgrade to the AV8802 for HDMI 2.0 in the last generation).
- Vertical Stretch for use with anamorphic lenses (note: does not appear to work with full bandwidth 4K signals like 4K/60 4:4:4)
- Rear USB input in addition to the front USB, the rear port is rated to power devices so more practical for a streaming stick or cooling fan etc.
- Balanced L/R XLR inputs
- LCD display on remote
- Dialog Enhancer (Low/Med/High; focuses on the 1kHz-3Hz voice frequencies unlike the Center Level Adjust (formerly Dialog Level Adjust) on the AV7705 which simply adjusts the Center speaker volume)
- Front Wide speaker support
- As a result of 13CH processing capability, better Auro3D support (and also less compromise with a dual use Atmos/Auro layout). The AV7705, like other current/previous 11ch D+M models is limited to 10.1ch Auro3D (5.1 + 4 heights + VOG). And the only way to practically mix Auro + Atmos is to use a Front Height + Rear Height layout. The AV8805 can run a full 13.1ch Auro3D speaker layout and has FOUR pairs height speakers outputs, allowing you much more flexibility to configure your layout while maintaining optimal Atmos/DTS:X playback. Since Auro3D was first introduced, many owners have commented how they prefer using the Auro 3D simulator (AuroMatic) to simulate 2CH stereo audio to a full Auro 3D configuration.
- Tazz24
- Inscription Forum: 13 Juin 2003 14:41
