Voici quelques liens qui peuvent vous aider à mieux cerner tout le potentiel de la Fire TV d'Amazon !
Certains acheteurs non Americains on acheter la Fire TV et dans pays respectifs, tout est fonctionnel, sauf les services Americain biensur, Hulu, Netflix, etc.
I got a fireTV off eBay as I am not an American, It worked out to about 2x the price that Americans are paying with the $85 sales lately. Anyway, heres what I did from taking it out of the box to booting XBMC. I downloaded adb from google & extracted the SDK platform-tools, and on the FireTV had to go into settings to enable ADB so I could push things to the device over the network. I done everything from CLI but I think you could get away with adbfire for most.
Exit bluestacks if installed as it screws with adb/adbfire, reboot adb server ('adb kill-server' followed by 'adb devices' reboots it), download the update file you want to install here:
http://www.aftvnews.com/software/Router block amazon update addresses.
http://amzdigitaldownloads.edgesuite.net http://softwareupdates.amazon.comRoot with towel root, install SuperSU and Busybox
http://www.aftvnews.com/how-to-root-the-amazon-fire-tv/Manually update to latest update you downloaded earlier.
http://www.aftvnews.com/how-to-manually ... /#more-906Repeat root and reinstall SuperSU and Busybox on latest rootable build. disable update service on the fireTV, so it stays that way.
adb shell
su
pm disable com.amazon.dcp
You should get an echo stating it was disabled.
Install Google Acct Manager, Play Services, Services Framework, Play Store (in this order), and Market helper. This sets up Google Play. Login to google play with your google account.
http://www.aftvnews.com/how-to-install- ... n-fire-tv/Run Market Helper and setup as Tablet - nexus 7 3G - United states - AT&T. hit down to highlight the hidden activate button, then select it. This has to be done on each reboot where you want N7 app support in the play store.
http://www.aftvnews.com/how-to-trick-go ... -all-apps/Clear Play store cache from KFTV Launcher app section for settings to take. Least I had to.
In Play install Timezone Changer, run, set your timezone if outside USA zones. Install whatever else you want like ES File explorer, youtube, maps, chrome, VLC.
Install Xposed framework installer, HDXPosed 1.3, RboxFireTVMods1.2, SQlite Editor 9.
Launch Xposed framework, install it. Reboot
Launch SQlite Editor, Select "Settings Storage", Select "settings.db", Select the "global" table, Highlight the record "install_non_market_apps",
Hit the Menu button and select "Edit Record", Change the Value to "1" and save the record by selecting the left button at bottom. Reboot.
http://forum.xda-developers.com/showthr ... ?t=2784173Run Xposed, enable the two modules installed with mouse. Downloads section works, enable what you wish like youtube adaway. install Settings.apk. This lets you sync bluetooth mice, headphones, speakers, etc.
http://forum.xda-developers.com/showthr ... ?t=2714494Install FireTV build of XBMC; signed-xbmc-13.2-FireTV(v8).apk. This takes advantage of rboxFireTVMods and allows XBMC to boot as well as fixing keymapping and launches installed apps and returns to XBMC when home is hit.
http://forum.xda-developers.com/showthr ... ?t=2790392Streaming OTA TV from TVHeadend works, somewhat. Hardware Acceleration had to be enabled but neither mediacodec or libstagefright could be enabled without triggering an XBMC crash when attempting to open the stream. I was able to deinterlace but video playback is noticeably stuttery. Play around with the settings and see what works best for you. Skins like Aeon Nox 5 works great. Heres how to add Menus and Sub-
Menus to deal with things like Games, Streaming apps, etc.
Click on the APPS/PROGRAMS link on the home screen
Click the backwards arrow
Select Android Apps from the menu
Highlight the app that you want to add the shortcut for
Click the MENU button on the remote to bring up the context menu
Select Add To Favorites
Back out to your home screen
Select the Skin Settings submenu under SYSTEM
Select the first link at the top of the page (think its something like Aeon Nox Home Screen Settings or something like that)
Select the menu item on the left that you want to add the submenu item too (or select one of the Custom slots)
Select Manage Submenu (unless using one of the Custom slots that you want to be a direct link to the program)
Add the submenu item using the center box
Repeatedly click the Type button in the center box until the right hand box shows all of the items you have set as Favorites
In the right hand box, select the item you want and hit the center button on the remote
Back out to your home screen and the menu system should refresh
Thats it! you should have a fire TV blocked router and unit side from root killing updates, google play store functioning with Nexus 7 app support, booting to XBMC instead of KFTV Launcher, a working settings to configure bluetooth & possibly other things, the correct time in your menus, and no ads on youtube
