46 messages • Accèder à une page • 1, 2, 3, 4
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 7 invités
Zeskit hdmi 2.1 certifié 48gbps
Bonjour a tous,
J'ouvre ce topic suite a la vidéo de Vincent Teoh:
A 2m18 il parle donc de ce câble comme étant le premier et seul cable hdmi 2.1 certifié 48gbps par le consortium hdmi.
Je l'ai donc commandé sur Amazon us, réception prévu entre le 26 et 28 novembre.
http://www.zeskit.com/hdmi-cable-8k
-48Gbps bandwidth for latest features HDR, HDCP 2.2 & 2.3, DTS:X, Dolby Atmos, Dolby Vision
-8K60, 4K120 & up to 10K resolution, Dynamic HDR, eARC, ALLM, QFT, QMS, VRR
-Certified connectors, thiner and softer cord for easier installation. Exceeds the requirements of latest international EMI standards to significantly reduce interference with wireless services such as Wi-Fi.
-Backward compatible with earlier versions of HDMI and can be used with existing HDMI devices. 2-Year Warranty
The Zeskit 8K series Ultra HD High Speed HDMI cables comply with stringent specifications designed to ensure support for high resolution video modes such as 4Kp50/60/100/120 and 8Kp50/60 as well as new features such as eARC and VRR. The cables exceed the requirements of the latest international EMI standards to significantly reduce the probability of interference with wireless services such as Wi-Fi. They are the best way to ensure that high-bandwidth dependent features are delivered including the enhanced video and audio performance, and accounting for the new EMI characteristics.
Cable Length: 1m / 3'4"
(6.5ft, 10ft, 16ft are also available separately)
Bandwidth: 48Gbps
For All HDMI Versions
Supported Features:
Dynamic HDR, Enhanced Audio Return Channel (eARC), Auto Low Latency Mode (ALLM), Variable Refresh Rate (VRR), Quick Media Switching (QMS), Quick Frame Transport (QFT), HDR10, Dolby Vision, DTS-HD Master Audio, DTS:X, Dolby TrueHD, Dolby Atmos, HDCP 2.2 & 2.3, Ethernet, ARC, CEC
8K Ready
The most recent update of the HDMI specification supports a range of higher video resolutions and refresh rates including 8K60 and 4K120, and resolutions up to 10K. Dynamic HDR formats are also supported, and bandwidth capability is increased up to 48Gbps.
Zeskit Ultra HD High Speed HDMI Cable support the 48Gbps bandwidth and is backwards compatible and can be used with the existing installed base of HDMI devices.
48Gbps Bandwidth
The cable ensures high-bandwidth dependent features are delivered including uncompressed 8K video with HDR, supporting the 48Gbps bandwidth. Other popular supported features are Dolby Vision, Dolby Atmos, HDCP 2.2 & 2.3, DTS:X, eARC.
For future proof, this cable also supports Dynamic HDR, VRR, ALLM, QFT, QMS, features of next generation of HDMI.
Approved Category 3 Connector (Standard HDMI)
Zeskit Ultra HD High Speed HDMI cable uses Approved Category 3 Connector, which was tested at an Authorized Testing Center (“ATC”). This is a must for any device compliant with the latest HDMI standard.
Ultra HD High Speed Cable
It features exceptionally low EMI (electro-magnetic interference) which reduces interference with nearby wireless devices.
https://hdmi.org/spec21sub/ultrahighspeedcable
Évidemment, ça ne veut pas dire que d'autres câbles ne passent pas le 48gbps mais celui ci est visiblement sûr a 100% puisque authentifié.
Donc pour les ps5 et xbox serie X avec un diffuseur compatible, il est peut être a privilégier pour éviter mauvaise surprise notamment @120hz.
Aussi, il est certifié jusqu'à 5 mètres.
Les tarifs sont très corrects:
- 1m: 16.99usd
- 2m: 24.99usd
- 3m: 29.99usd
- 5m: 39.99usd
Bandwidth: 48Gbps
Supported Features:
8K Ready
48Gbps Bandwidth
- 1m: 16.99usd
- 2m: 24.99usd
- 3m: 29.99usd
- 5m: 39.99usd
Jvc RS2100, Xtrem 1.1gen2, Lg 77g3, chambre 65s95b, sources: pana ub9000 +pchc+chinoppo+z1000pro,atv4k, XSX, PS5/ 3 Arendal monitor 1723S, 4 Divatech diva18, 6 Svs prime elevation atmos/ Denon Avc-a1h/ sub arendal 1723 1S
- david555
- Superviseur Forum Univers TV & Contributeur HCFR
- Inscription Forum: 02 Oct 2005 18:13
hyperspace - Membre HCFR
- Inscription Forum: 05 Mai 2018 22:40
M'en fous, j'ai pris des Wireworld.
chkops - Contributeur HCFR 2020
- Inscription Forum: 01 Mar 2011 11:55
midthecid a écrit:déja plus de stock
Amazon US est ton ami
- david555
Bonjour. ATTENTION, ça vaut ce que ça vaut …. Retour d'un utilisateur :
"Mon X6700H a un testeur de bande passante par câble. J’ai acheté 2x 6ft et 2x 16ft de ces câbles. Ils passent 40Gbps seulement la moitié du temps et je recevais des artefacts à 4K120hz au hasard. Ils travaillaient 95% du temps, mais ce n’est pas assez bon.
J’ai troqué pour des câbles certifiés Blue Jeans Cables Series-FE certifiés de haute qualité que j’avais
déjà. Ceux-ci sont beaucoup plus minces, mais même les 15ft passent 40Gbps à chaque fois. J’ai environ une douzaine d’entre eux allant de 6ft à 15ft. Tous ont passé des tests de 40Gbps sans faille.
Dépensez le
supplément. Accompagnez les câbles Blue Jeans BJC Series-FE si vous voulez 4K120 ou 8K60 de façon fiable. Ils peuvent être achetés avec prime sur Amazon. Ce n’est vraiment pas beaucoup plus et ils ne vous donneront pas de maux de tête. "
Personnellement je prendrais pas le risque, surtout si le câble a été testé avec le Denon ...
Dépensez le
- metoujpense
- Inscription Forum: 29 Mar 2001 2:00
On sait si les denon monte a 48gbps?
Parceque personnellement je fais plus confiance à Teoh qui dispose d'autre moyen bien plus qualitatif qu'un denon 4700 pour tester la bande passante...
Il va revenir dans une vidéo sur ce câble.
Wait and see.
Wait and see.
- david555
- david555
david555 a écrit:midthecid a écrit:déja plus de stock
Bah, c'est un peu sur le market US que le site de Zeskit t'envois.
Mais pas grave vu que les 2.1 des consoles ont l'air correct
- midthecid
- Inscription Forum: 11 Sep 2020 23:57
metoujpense a écrit:J’ai troqué pour des câbles certifiés Blue Jeans Cables Series-FE certifiés de haute qualité que j’avais
Dépensez le supplément. Accompagnez les câbles Blue Jeans BJC Series-FE si vous voulez 4K120 ou 8K60 de façon fiable. Ils peuvent être achetés avec prime sur Amazon.
Ah ben merde, j'avais pas pensé à Amazon, au moment d'acheter des 2.1 je suis allé direct sur le site us de BlueJeans pour l'avoir fait il y a longtemps (au moins 10 ans) et pour connaître la qualité irréprochable et "sans marketing" de cette marque, qui de fait, ne parle pas vraiment de 48Gbps sur leur site. Pis finalement j'ai commandé des Pearl48 Audioquest un peu par dépit, à 60€ les 3m, pas encore testés.
Merci pour le tuyau.
- Zappy Bibicy
- Inscription Forum: 30 Sep 2001 2:00
Reçu a l'instant suite a mon achat, le câble doit arriver samedi
- david555
C’est la Xbox Series X pour le 4K/120fps, pas la One X, lol les mecs
hyperspace a écrit:C’est la Xbox Series X pour le 4K/120fps, pas la One X, lol les mecs
Espérons que les câbles soient plus rigoureux que leur communiqué lol
- david555
Arrivé
- david555
Belle qualité de fabrication je trouve !
- david555
46 messages
• Page 1 sur 4 • 1, 2, 3, 4
