Pour info nouveau software v3.09 dispo ici
http://www.anthemav.com/download-support-file-download/cat_view/7-anthem-statement/15-av-processor/19-d2v/160-softwareCHANGE LIST
v3.09:
This version is applicable to any AVM 50v and D2v, but latest hardware is required for 3D handling and video passthrough mode. The unit displays "3D" on the front panel during power-on if 3D-capable.
1. Added support for 3D hardware upgrade kit. Video "Through" mode is required for 3D but can also be used with 2D sources. It must be enabled manually by setting Video Out Configuration in the Source Setup (menu 6) to Through. Scaler In must be set to HDMI 1-4 to allow this selection. Through mode cannot be applied to HDMI output 2 or HDMI inputs 5-8.
2. DTS Master Audio surround position mapping disabled. The reason for this choice is that newer 7.1-speaker installations are more likely to have the side surround speakers directly beside the central listening position instead of slightly behind it. Previously, the side-surround channels were partly mixed to the fronts to move the surround image forward.
3. General fixes and improvements for HDMI.
4. Certain CD tracks were muting mid-song - fixed.
5. Interoperability improvements with certain video cards and cable/sat receivers.
6. Added support for Custom Resolution Manager v1.1.0 utility (replaces Live Video Settings Editor).
