Type : Amplificateur de puissance 2 canaux
Marque : Emotiva
Modèle et options : UPA-2
Prix de vente : 375 --> 350 --> 325€ frais de port compris
Possibilité d'expédition : A voir, 14Kg Une remise en main propre est préférable
Montant des frais d'expédition : Compris (Colissimo R4)
État de la marchandise : Excellent état
Première main : Oui
Prix neuf : En se basant sur le XPA-200 à 500$ donc à la fin 650€ avec les frais de port + douane
Facture disponible : Oui
Date, pays et lieu d'achat : 12/12/2011, USA
Garantie et date d'expiration : Garantie jusqu'au 12/12/2016
Voici les caractéristiques du produit :
Model: UPA-2
Class: A/B
Channels: 2
Power 8 Ohm All Channels Driven: 125W
Power 4 Ohm All Channels Driven: 185W
Power Bandwidth: +/-0.05dB
Frequency Response: 5Hz-150kHz(-3dB)
THD: NA
SN Ratio 1W: >93dB
SN Ratio Full: >107dB
Damping: NA
Crosstalk: >80
TransformerVA: 300
Capacitance: 40,000
Input Sensitivity: NA
Input Impedance Unbal/Bal: 25
Gain: 32dB
Adjustable Gain: Yes
Power Requirements: 15A
Connections: RCA
Trigger: Yes
LED Meters: No
2 Ohm Capable: NA
Output Devices: 4/ch
Fans: No
Weight: 30
Width: 17
Height: 3.87
Depth: 18
Rack Size: 2U
Topology: Fully discrete, dual differential
DESCRIPTION:
A dynamic, high current Class A/B amplifier with a surprisingly modest price. Its advanced feature set makes it versatile enough for multiple applications.
The UPA-2 is no toy. Inside the compact 2RU chassis are two of the same amp modules used in our UPA-7. They are horizontally mounted and driven by a high-current toroid transformer power supply. Built with the same high-quality/low noise standards as all Emotiva amplifiers, the UPA-2 is a reference level two channel power amplifier.
FEATURES:
Fully protected from all fault conditions.
Advanced microprocessor operating system.
Soft start circuitry.
External trigger turn on.
Soft touch power switch.
2RU chassis w/ solid milled aluminum faceplate.
IEC power inlet, 120/230 VAC auto configurable.
Output design: Triple Darlington with On output stages.
Type of outputs: Audiophile quality 5 way binding post.
Display type: Digital status indicators.
1% resistors, precision film capacitors in all critical signal paths.
Modular channel design for greater channel separation, auto rail detection relays for automatic voltage selection.
On/Off LED Status Switch.
Site web du constructeur : http://www.emotiva.com
6 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 17 invités
Baisse de prix à 350€
- deuch
- Inscription Forum: 08 Mai 2000 2:00
Baisse à 325€
- deuch
J'offre les frais de port, 325€ frais de port compris, après je le garde
- deuch
Réservé !
- deuch
Vendu ! A fermer !
- deuch
6 messages
