Type : Bloc HC
Marque : Parasound
Modèle et options : Halo A52
Prix de vente : 1.300€ > 1.200€
Département où la marchandise est visible : Barcelone, Catalogne
Montant des frais d'expédition : 40€
État de la marchandise : Très bonne
Première main : Non
Prix neuf : 3.250€
Facture disponible : Non
Date, pays et lieu d'achat : Espagne
Garantie et date d'expiration : Non, pas transférable
Numéro de série : Oui
Emballage d'origine conservé : Oui (double!)
- Circuitry designed by legendary John Curl
- THX Ultra2 certified
- High bias Class A/AB operation
- Balanced inputs with discrete circuits and XLR connectors
- Direct Coupled - no capacitors or inductors in signal path
- Complementary MOSFET driver stage and JFET input stage
- 20 beta-matched 15 amp, 60 MHz bipolar output transistors
- 1.4 kVA encapsulated toroid power transformer with independent secondary windings for each channel
- 100,000 µF power supply filter capacitance
- DC Servo and relay protection circuits
- AC present, channel status, high temperature indicators
- Heavy-duty 24k gold-plated 5-way speaker terminals
- Gold-plated RCA input jacks; ground lift switch
- Auto turn-on by 12v trigger or audio signal, 12v trigger out
Continuous power output:
125 watts RMS x 5, 20 Hz - 20 kHz, 8 Ω, all channels driven
225 watts RMS x 5, 20 Hz - 20 kHz, 4 Ω, all channels driven
Current capacity: 30 amperes peak per channel
Power bandwidth: 5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total harmonic distortion: < 0.2 % at full power
IM distortion: balanced 16 V rms < 0.04 %
Slew rate: > 130 V/µsecond
Dynamic headroom: > 1.5 dB
Interchannel crosstalk:
> 78 dB at 1 kHz;
> 63 dB at 20 kHz
Input sensitivity: 1 V for 28.28 V, THX Reference Level
Input impedance: 47 k Ω unbalanced; 94 k Ω balanced
S/N ratio: 113 dB, input shorted, IHF A-weighted
Damping factor: > 1000 at 20 Hz
Dimensions: 17-1/4" w x 5-7/8" h x 19-3/4 " d, 5-1/4 " h without feet
Net weight: 50 lb.
Site web du constructeur : http://www.parasound.com/halo/a52.php
Le "petit" monstre bloc HC de la ligne Halo de Parasound.
Un des meilleurs blocs HC hdg a un prix réellement raisonnable.
Aucun intégré HC dispose d'une section d’amplification comme ce-là.
C'est le 75% de son frère A51 qui coûte presque 6.000€.
Joyeux noël!
15 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: FrankD et 50 invités
http://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CC8QFjAA&url=http%3A%2F%2Fwww.parasound.com%2Fpdfs%2FJCinterview.pdf&ei=hWLxUPyJHI-N0wXTmIGwDg&usg=AFQjCNHD3s8kstzPOAGEcvuR2hsvV52wfQ&bvm=bv.1357700187,d.d2k&cad=rja
Un petit lien pour qui veut savoir comment John Curl a conçu ses superbes amplis Halo... Le A52 à ce prix est une affaire à ne pas rater je crois (j'en ai à la maison et c'est )
- Invite17
Sergioredshoes a écrit:http://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CC8QFjAA&url=http%3A%2F%2Fwww.parasound.com%2Fpdfs%2FJCinterview.pdf&ei=hWLxUPyJHI-N0wXTmIGwDg&usg=AFQjCNHD3s8kstzPOAGEcvuR2hsvV52wfQ&bvm=bv.1357700187,d.d2k&cad=rja
Meilleur que la série hca 1200 et 2200 mk2?
En tous cas,j'ai acheté 2 fois à ce vendeur ça s'est très bien passé.
Bonne vente,Pierre.(Je suis en pleine réflexion pour savoir si je te le prendrais ou pas mais j'aimerais avoir un comparatif avec la série très réputée hca)
- clarkent73
- Inscription Forum: 10 Déc 2009 18:55
Merci Sergio pour ce interview avec JC. Très intéressant. Ce-là est ma deuxième aventure dans la ligne Halo de Parasound. J'avais aussi le préamp P3 qui à une relation prix performance ridicule.
Je doute de si finalement vendre le A52 après ce commentaire!
Merci aussi Laurent! entre nous deux nous avons une petite entreprise en marche d'achat et vente!
cordialement
cordialement
- PierreBCN
- Inscription Forum: 06 Déc 2008 21:19
toujours dispo
vous avez un mp
vous avez un mp
- subbreton
- Inscription Forum: 30 Déc 2006 13:01
Oui après la tentation de le garder, il et nouvellement en vente.
Cordialement,
Cordialement,
- PierreBCN
Ah bah quand même, un Parasound Halo qui traine comme ça dans les PA ce n'est pas normal
Sergio
Sergio
- Invite17
15 messages
