Type : Unité de refroidissement
Marque : Sherbourn
Modèle et options : C-12
Prix de vente : 150€
Département où la marchandise est visible : Chamonix (chez un ami)
Etat de la marchandise : Comme neuf
Facture conservée : oui
Date d'achat : 2013
Garantie et date d'expiration : oui 2021
Numéro de série : Sur demande
Documentation conservée : oui
Description et commentaires :Je vends ce produit car j'en ai acheté trois pour bien refroidir mon système, mais deux suffisent. Ce modèle est parfait pour maintenir une bonne température des appareils grâce à sa sonde.
Featuring a 2u high, full rack width foot print, the Sherbourn C12 cooling unit employs three 4.75»
fans and can be easily accommodated in any application utilizing the supplied rack mount panel or
as a stand alone application.
The C-12 employs a unique mechanical design (patent pending) that allows users to configure the
unit to either exhaust hot air or to blow hot air away from the equipment.
The C12 has a built in temperature and pig-tailed thermostat switch to automatically control the
thermally governed fans. In addition, the C12 has a sync switch to allow two units within the same
installation to operate in tandem. The C12 also features a 12-volt trigger.
The optional H10 exhaust kit allows easy adaptation to any installation and flawlessly exhausts hot
air from the environment using the flexible, heat resistant hose.
• Configuration: Three 3.75” thermal sensing fans that can be configured to intake or exhaust
• 12v Trigger
• Selectable Thermal Switch: The three fans can activate at two different ambient room temperatures
• Sync Switch: Allows two units to operate at similar speeds
• Pig-Tail Remote Temp. Sensor: Governs fan speed from the “hot spot” of the installation
• Optional exhaust hose kit: Allows hot air to be drawn from the installation to an alternative location
• Dimensions Fan Unit Chassis (W x D x H): 400mm x 222mm x 57mm
• Dimensions Rack mount panel (W x D x H): 483mm W x 95mm H (attaches to front panel of fan chassis)
• Weight: 4.1 kg (in carton)
6 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: tex61 et 50 invités
6 messages
