Type : Preampli Processeur Haute Définition HDMI
Marque : Emotiva
Modèle et options : UMC-1 V6
Prix de vente : 730
Département où la marchandise est visible : 35
Montant des frais d'expédition : 20
État de la marchandise : Neuf
Première main : Oui
Facture disponible : Oui
Garantie et date d'expiration : 1 ans
Numéro de série : Au dos de l'appareil
Site Emotiva:
* Twin Cirrus® 32 bit dual core DSP’s
* Decoding support for Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Digital True HD, Dolby PLIIx, DTS, DTSES, DTS HD, DTS Master Audio, DTS Neo 6, SPDIF, PCM 8 channel (note: some audio formats are only supported via HDMI)
* Multi-channel Dolby Volume
* Genesis/ST® Torino high performance scaling engine - featuring a full implementation of the Faroudja DCDi™ image processing suite
* Intuitive, full color graphical OSD with adjustable transparency presented over live video, including HDMI
* Emo-Q™ automatic multi-channel room correction and loudspeaker setup. Calibrated measurement microphone included.
* Quadruple bass manager with independently selectable high and low pass frequencies from 40hz – 250hz, in 5 or 10Hz increments (depending on frequency)
* Selectable 12db or 24db per octave high pass and low pass filters by channel groupings
* Independent 11-band graphic EQ with global bass and treble controls by channel groupings
* Balanced subwoofer output
* All legacy video inputs can be scaled and output over HDMI at up to 1080p
* 1080p/24 fps video support
* Video pass-through mode with 12 bit compatibility
* HDMI sources can be format converted to component video up to 1080i (subject to Macrovision™ guidelines)
* HDMI 1.3a Deep Color compliant
* All inputs are assignable and feature input labeling, selectable decode modes, selectable triggers, etc.
* 0.5dB level trims on all channels
* High voltage, low impedance main analog outputs for uncompromised dynamic headroom
CONNECTIVITY:
* 5 - HDMI inputs and 1 HDMI output.
* 3- composite video inputs (RCA)
* 3 - S-video inputs (S-video mini DIN)
* 3 - component video inputs (RCA)
* 1 - component video output (RCA)
* 4 - stereo analog audio inputs (RCA)
* 1 - 7.1 analog input set (RCA)
* 1 - 7.1 analog output set (RCA)
* 4 - coaxial digital inputs, (RCA)
* 3 - optical digital inputs (Toslink)
* 1- coax digital audio output (RCA)
* 1- optical digital audio output (Toslink)
* 1 - Stereo or 2 channel analog multi channel mix down output for fixed level monitoring (RCA)
* 1- stereo analog variable and independent Zone 2 output (RCA)
* 1 - stereo analog fixed level record output (RCA)
* High performance AM/FM tuner with 24 FM and 6 AM presets
* 3 - assignable trigger outputs Movie/Music/Amp (3.5mm mini)
* 1- IR input (3.5mm mini)
* 1 - IR output (3.5mm mini)
* 1. Microphone input (3.5mm stereo mini)
* 1- USB data input (for software upgrades only)
* Size: 17” W x 3 7/8” H x 13” D
Site web du constructeur : http://www.emotiva.com
Une très belle machine avec une gestion complète du matériel associé (HDMI, Bass management, calibration, EQ 11band par canal (y compris pour le sub), etc...), Superbe décodage avec beaucoup de détails et d'ampleur (surtout dans la profondeur du grave). Pour la partie HiFi, très transparent, donc pas grand chose a dire si ce n'est "parfait!".
Une bien belle machine pour un prix exceptionnel
5 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: shoowie et 47 invités
Petites annonces pour Préamplificateurs HC multi-canaux.
[Réservé] Emotiva UMC-1
- LeCaribou007
- Inscription Forum: 20 Sep 2007 14:45
Alors qu'est-ce qui motive la vente ? Le MC-8 juste au dessous ?Le caribou a écrit:Commentaires :
Magnetar UDP800 / Lumagen Pro 4242 / JVC N7 / MicroPerf'Oray HD 4K / Anthem AVM90 / 9 x Focal, SM6 Be & 1000 Be + 4 x 300 / 2 x Subs DIY Beyma 18LX60 V1 / Amplis HPA / Etudes, traitements & calibrations pros
SYLEX - Administrateur Suppléant de l'Association & Délégué Editorial
- Inscription Forum: 11 Oct 2002 13:47
exactement!
- LeCaribou007
Un MP
Vite, vite !!!
Vite, vite !!!
- jalatrix
- Inscription Forum: 25 Jan 2005 23:31
Vendu a un sympathique forumeurs qui vient de repartir avec après écoute. vous pouvez fermer. merci.
J'ai vue ma boite mail saturé en 1/2journée! désolé pour les décues, La marque à l'air de plair a beaucoup de monde .
Donc je rappel que les UMC-1 seront en vente d'ici maximum 1 mois normalement, et que, comme dit a certains par téléphone, je motive les intéressés à ne pas hésité sur cet excellent produit lorsqu'il sera dispo car il jette jette un énorme pavé dans la marre de tout les autres constructeurs avec des performances et des fonctionnalités jamais vue a se prix là, et plus que largement à la hauteur de bien des produits 3 a 4 fois plus cher...
- LeCaribou007
5 messages
Retourner vers Préamplificateur HC
